Topic: No reverse lights (Read 2027 times) previous topic - next topic
No reverse lights
just got a 88 cougar with 35000 miles. Reverse lights don't work bulbs are good fuse works everything else on its circuit. Is there a switch
No reverse lights
Quote from: Jeff;466765
Is there a switch
Yes.  On the transmission. What transmission do you have?
No reverse lights
Quote from: softtouch;466767
If stock it's an AOD.
No reverse lights
Not real sure 3.8 motor
No reverse lights
All 88 cougar had an aod.
No reverse lights
Pic:
No reverse lights
Thank you I will check it out. Son needs them to work to take his drivers test
