Topic: Brake Booster Replacement '85 TB (Read 2055 times) previous topic - next topic
Ok, I am replacing the brake booster on an '85 TBird V8 and the last top bolt is being a pest. I have  remove the plastic panel under the dash to get access but it is extremely difficult to access through the supports placed up there with a ratchet or getting open end wrench ratchet in there. I haven't pulled the brake pedal off since that also looks to be a little bitch too. The last bolt is loose , but just not enough to grab with fingers, let alone getting a hand in there to even touch it. Any suggestions or mechanic pages available on brake booster removal?
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
Put one of the bottom bolts back in to he
Old the whole thing against the firewall.
Get a set of harbor freight wobbly extensions. They make all the difference in the world.
You mean universals for a socket ratchet wrench. I think I might  do that, but I will need to get them for a 1/4in socket ratchet since I can barely get a finger to the bolt.
1988 Thunderbird V6
No, wobble extensions allow for some articulation. Not the same as universals. And pretty sure when i did my booster, i only removed the lower bash pieces and stop light switch.
