Topic: DIY exhaust (Read 7701 times) previous topic - next topic
DIY exhaust
this weekend the oldest boy is in to install various parts to replace his exhaust that came with the car when we bought it from Privateer member here..
2 1/2'' pass side ready to be mated to a store bought 2 1/2'' axle pre-bent pipe.
we need to repeat this layout on the drivers side
get everything hung and then mark for the H pipe just a little bit to the rear of the trans mount.
add qty 2 bungs for O2 sensors on the pass or driver side.
add qty 1 bung for the other side.
this allows for a future wide band 02 when the eec is chipped.
all welds need cleaned up but so far its seems to be going ok.
the cats are fake.
apparently in VA his old "turbo chambered" lers were not legal, yet this fiberglass cherry bomb design is!
DIY exhaust
got some more done yestrday.
next we add the cross over pipe to for the "H".
the section for the ler on back will be clamped to make it removable.
the actual inside diameter of this pipe is 2 3/4''
DIY exhaust
Going to be a little loud?
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
DIY exhaust
Quote from: tommym;466204
yes it is,, just finished.
not my thing but mason likes it.
id rather have at the least lers on it!
everything fit and went well though.
two solid days of fab work
we have under 250$ in it
DIY exhaust
Any sound clips of this?  DIY stuff is always the coolest!
DIY exhaust
you dont want em',, sound clips.
i can see about it this evening though,, mason is in for the weekend.
we did not get pics of the final completed product but two pipes are bridged to make an "H"
its just ridiculous in loudness
some would say it sounds just fine but sounding "like" your running open headers isnt my thing.
DIY exhaust
now i will fess up....
all this pipe is 2 1/2'' EMT  (electrical conduit)
had to do some learnin' on what is pipe and what is tube.
"tube" is made and sold by total ouside diamater.
"Pipe" is made and sold by total inside diameter.
The emt is considered "PIPE"
the summit "tube" stuff is about .071 '' wall thickness
the EMT "PIPE" is about .076'' wall thickness
but if you buy stock single exhaust from the parts store like what came stock on my 20th anny,, rock auto supplied me with new parts and that "tube" material is about .035'' thick
so..... is it appropriate to call it exhaust "PIPE"-  NO  Its exhaust tubing.
DIY exhaust
Is the EMT pipe coated in some way (i.e. aluminized inside and out)? If not it'll probably rust through pretty quick ;)
DIY exhaust
i got a sound clip ,,, will get it on here real soon.
to be honest it sounds better in than i thought a few weeks ago.
