Topic: Power Antenna (Read 2112 times) previous topic - next topic
Power Antenna
I found a power antenna in the shed I forgot I had.  If I installed it, is the wiring in the dash to hook it up, if I also installed the switch?  Anybody have a power antenna switch for sale?  Thanks.
Power Antenna
The switch has the wiring for the antenna attached to it. I have some of the switches as well. I'll ship you one for $40.
Power Antenna
50RACER,
Where does the switch get its power from?  Is the connection for it already there in the dash?  Thanks for your offer.  I'll let you know when I might be able to buy it.  Thanks.
Power Antenna
X  The red and green wire that are together go to the antenna. The two black wires that are in the same connector, I believe, are the ones that power the switch and they plug into  another connector in the area around the back of the radio that is part of the much larger dash / fuse panel harness. You probably have to pull out the radio to locate it.
Power Antenna
In the 86 EVTM, looks like the yellow/black stripe and black wires in connector C303 are the power and ground to the switch.
