Topic: C4/FMX Question (Read 2517 times) previous topic - next topic
C4/FMX Question
Hey all,
Been "years" since I've been here, so please excuse my absence.  I hopefully am about to purchase an 86 Cougar with what sounds like a burnt-up C5 trans.  I will not be financially able to afford a rebuild on the C5.  I have found both C4's and FMX's in my area for pretty reasonable prices.  I haven't found any C5's.  Oh, and it will be going behind the 3.8.  My question is, are either of those a good candidate to swap, if I'm on a tight budget?  I've read that the C5 is basically a C4 with a lockup converter.  Would I need to swap the flywheel?  I don't believe that Ford ever put a C4 behind the 3.8 from the factory, did they?  Anyway, I appreciate any advice.  Glad to hopefully have a reason to return to the site.  Take care.
C4/FMX Question
Do a 3.8 t-5 from a 94-98 mustang.
Pretty much bolts in. Swap pedals, add a flywheel/clutch and buy the trans for $150 at a u pull it yard
C4/FMX Question
What was the total setup to use that v6 t5?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
C4/FMX Question
Use 94 up mustang parts. That's pretty much it. There's a sticky here somewhere with a full write up.
The driveshaft will be too short.
C4/FMX Question
IMO if deciding between a C4 and FMX, I would choose the C4.  Plenty of shift and rebuild kits available .
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
C4/FMX Question
I was actually to find a C5 somewhat close, which I assume is in good running condition (the CL seller didn't expressly state what condition it was in) for $150.  I'm not going the hotrod route with this car anyway (which I still haven't purchased but hope I'm close), so I never plan to modify the trans for that 120HP V6.  The C5 should be a plug-n-play install, shouldn't it.  Does it matter what year or car that the C5 came from?  That's probably the route I'll take if I get the car and the transmission seller still has the C5 when I get ready.  Just out of curiosity, would the C4 have gone right in the place of the C5 without any issues?  Need to swap flywheel?  Bolt patterns line up?  Thanks again.
