Topic: Cougar and T-bird front (Read 2458 times) previous topic - next topic
Hello. I am new to this forum and I have a dilemma. I own an 87 XR7 and cannot find headlamp assemblies. I want to replace my whole front forward of the fenders and hood with one from a T-bird or Cougar that houses the sealed beam glass headlamps. Can anyone help me? I love this car and want to keep it.
I’m not 100% sure but wasn’t there a Lincoln headlight that matched up? Maybe the 89 model? Others may chime in that know for sure. Try Rons Performance Garage on EBay. Good luck with the search.
 S O L D
1988-94 Lincoln Continental headlamps were the same.
As far as the front end swap, technically it could be done but the molding will not line up correctly, and you'd have issues with the headlight wiring harness not being correct.
The front end will swap, no issue from tbird to cougar. I put a cougar front end on my 87 tbird, everything swapped over
From two to four headlights is a different story, but it can't be all that hard or different.
I can rewire headlamps with no troubles.
The dealers have looked and the 92 was said to work but the part numbers are different so no matches so far. Best chance is an entire front assembly swap from an earlier Cougar or Bird
You can get good headlight assemblies off ebay
88 Cougar
88 T-Bird
other cars that don't apply to this forum
prices have gone up, but here is one.
https://www.ebay.com/itm/NOS-Lincoln-Continental-89-94-Mercury-Cougar-87-88-Headlamp-Lens-Light-LEFT/273065776615?fits=Year%3A1987%7CModel%3ACougar&epid=1240462006&hash=item3f93fd15e7:g:RZkAAOSwhzRafK1X
marker light
https://www.ebay.com/itm/OEM-Ford-E7WY-13201-B-Front-Left-Inner-Parking-Light-Lamp-For-87-88-Cougar/182296357856?epid=1111275423&hash=item2a71b5abe0:g:5WQAAOSwNRdX7IxH
Gotta be patient, they will come up.  I would rather polish and buff good used pieces, before swapping noses.
Type search E7WY occasionally.
Search Green obsolete sales occasionally.  Have some outer markers, but I cant/wont pay $175 for an outer marker, yet that is.
Mike
both pn's per my diy link..
Ford Part # E80Y-13007-A and E80Y-13007-B
also,, an observation from vinnietbird here said he did not notice the dull effect on the Cont vs our birds/cougs.
I dont mean to give anyone any bright ideas here but....
when you take the lens off your housing,, did you know that the 83-86 glass lamps drop inside perfectly?
Quote from: jcassity;465517
Sounds sneaky.  Have you considered it?  Wonder how you could make it look "factory"  ??
Mike
