Topic: Stuck slip yoke (Read 2485 times) previous topic - next topic
Stuck slip yoke
Alright, so it seems my drive shaft is stuck at the slip yoke. How would you guys recommend getting it out?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Stuck slip yoke
Not sure what you mean.  Are you referring to the yoke that goes up into the transmission?  If so what do you mean by stuck?
Stuck slip yoke
Yeah, it should travel in and out when the suspension goes up or down.
Take off the driveshaft bolts, and gently tap it out with a hammer. Iver never had one get stuck before.
Stuck slip yoke
It's stuck pretty bad this coming week I'm going to use a slide hammer to get it out. Also I have another question are the auto and manual yokes the same length?
88 Cougar
88 T-Bird
Stuck slip yoke
Yes and no. I reused my aod yoke on my t-5. Really, the answer depends.
Stuck slip yoke
I measured and I need a 6" slip yoke
88 Cougar
88 T-Bird
Stuck slip yoke
I've never seen the splines get damaged. I've even chucked a driveshaft out at freeway speeds, pulled over walked back and picked the yoke up off the side of the highway and reused it after.
