Topic: Dual Exhaust (Read 2522 times) previous topic - next topic
Dual Exhaust
I purchaced a 1987 Cougar 5.0L . It came with single Exhaust,..I want to put on duals...Anybody done this on your 87 88 Cougar.??
Dual Exhaust
Throw some stock Fox Mustang headers on it, a Fox Mustang H Pipe, then have the rest added at the ler shop. The H-Pipe and headers are a simple bolt on, but the mid pipes and tail pipes are different from a Mustang.
Dual Exhaust
+1... Stock mustang headers can be found cheap.
 S O L D
Dual Exhaust
Thanks......I want full duals....will see what I can find next week....
Dual Exhaust
It bears mentioning that the HO headers and H-Pipe setup will require HO oxygen sensors, or 8 inch(?) extensions; as in that setup, the O2s are in the H-Pipe and not the manifolds/headers.
Dual Exhaust
You can also lengthen the car's oxygen sensor harness (that's what I did). Be sure to solder the wires and not use a crimp connector.
DO NOT lengthen the oxygen sensor wires themselves. You'll ruin the oxygen sensor that way.
Dual Exhaust
the o2 sensors need 600+ degrees to start making thier own millivolt signal,, how can they do that if they are so far down stream
is it really that hot on the hpipe?
Dual Exhaust
Late 86 on the o2 sensors are heated. The 4.6 mustangs have six catalytic converters and pre and post o2 sensors, the post o2's are near the end of the h-pipe.
