Topic: deck lid wouldnt stay open (Read 3406 times) previous topic - next topic
Had a strange one this week.  Got my 83 out of winter storage from my buddies barn last weekend and when I was putting the car cover away in the trunk the dam deck lid wouldn't stay open.
Ever since Ive owned the car I could hit the trunk button and it would pop open on its own and stayed open. After car sat from Oct to March untouched it wouldn't. I actually had to move one of the torsion rods up a notch to get it to stay open again.
Anyone else ever run into this? Just seemed strange
Brian R.
88 2.3t Ranger
I have never seen that issue. I did install gas struts on my trunk lid and did away with the torsion rods
Quote from: vinnietbird;465149
Pics?
are the hinges greased? ;)
Pics X2, I wanna see how you did that. My deck lid falls shut if the car is parked on any sort of incline.
-Kyle
I made mounts for the hinges from steel and added the snap on ball adapters for the strut to hook on to. The floor mounts are just L brackets made for the struts.
Thanks Vinnie.
Yeah that's pretty slick! I think that's gotta be my next project. Tired of getting hit in the back of the head with the trunk
I did similar on my '96 XR7 only I welded the mount higher and out of the way.
X
X
adjust the torsion rods,,, and wear gloves.  move one side i think "down" a notch.
or check lube on pivot point.
