Topic: Dash board lights out (Read 2476 times) previous topic - next topic
My dashboard lights went out in my car yesterday, but them came back on later. Then they went out again. I noticed that when they did work and I used the dimmer switch to turn on inside lights the dash went dark again, but came back on when i turned off interior lights with the dimmer switch. Does this sound like a bad headlight/dimmer switch? I did have a turn signal and headlight out, but i replaced them and this happened after. Any suggestions or advice, thanks!
First thing, what year car are you talking about?  buttstuffog or Digital dash?
Mike
1988 digital speedometer but buttstuffog guages forgot to add that.
Check the wiring for the headlamp/dimmer switch. Sometimes they burn, causing weird issues, since the power for the lights runs through the switch. Also check the ignition switch, especially if any other weird electrical gremlins are present.
I took it out and there was a bunch of blue/green powder residue underneath the switch. I blew that off and it seems to be working now, but still shuts off the panel when i turn the done light. What is that part specifically called that I would replace? When I have looked up the headlight switch it doesn’t look like the part that I saw.
Quote from: thunderjet302;464966
Thanks for the advice.
