Topic: [Found] Looking for a rear end for my 87 Cougar (Read 2310 times) previous topic - next topic
My Cougar went into the ditch last weekend and it has at a minimum snapped one of my axle shafts. I'm looking for a replacement rear end. If you've got positrack or a Turbo Coupe rear end with disc brakes, even better. My Cougar's the 20th anniversary model with the quad shocks, I imagine it's the same on the XR7.
The car is at my mechanic's shop right now and I'm going to be out of town for about 3 weeks for work, so this would have to be a local sale (Detroit/Dearborn area) where either my mechanic picks it up or you deliver. (I know it's weird, but I didn't pick the timing).
If you've got any leads, PM me or give me a call: (eight 4 seven)-924-3286.
I have my old 7.5in rear. 2.73 gears. Non-LSD. Complete from drum to drum. I have the parking brake cables too. Located NW of Chicago.
That's close enough that it's tantalizing. My parents are north of Chicago. I may have to bother them while I'm out of town. I'll send you a PM.
After speaking with my mechanic, we are looking for a quad shock rear end specifically.
If one doesn't turn up...well, we'll see.
Still searching for a 7.5" quad shock rear end. Anything available anywhere in the midwest?
I have a 8.8 with 3.55's and a track lock here in Fort Wayne, IN it has the quad shock ears on it still the brake shoes and hardware are all new and it has the 10" drums
That rear end looks nice to me, and Fort Wayne is not too far of a drive either. Is it straightforward to go from the 7.5" rear end with the 9" drum brakes to the 8.8" with the 10" drums? Does it bolt straight up and use the existing brake lines, MC, etc?
Yep. I replaced the original 7.5 in my 87 lx with this one. Went 5-lug a few months ago with a complete axle and ect. I don't have the e-brake pieces anymore but yours should work. If not just swap your 9" brake parts over to it.
PM'd
Hey 87thunderbirdBlackJack, did you see my latest 2 PMs?
