Topic: Manual Pedal assembly (Read 2612 times) previous topic - next topic
is the tbird manual pedal assembly the same as the mustang?  Was wondering if I can use a mustang cable and quadrant as I am going to a 10,5 clutch on my 2.3T
I'm sure they are different. That would explain why everyone needs a Fox Stang setup. The Fox uses a cable, the Bird was hydraulic for the clutch
You will need a different Bell housing that will allow you to mount the cable.  One from a 4 cylinder mustang will work
All of the Fox Mustang pedal assemblies are getting old enough that if you go that route I would suggest replacing the bushings on the clutch and brake pedal shaft assembly.
https://lmr.com/item/LRS-2471A/79-04-Mustang-Clutch-Pedal-Support-Bushing?gclid=EAIaIQobChMI-P713byv2AIViCSBCh1S1A2lEAQYBCABEgLIHPD_BwE
