Topic: Replacing Intake, throttle body- questions? (Read 27623 times) previous topic - next topic
Getting ready to make some changes to my 87 Turbo Coupe and thought I'd run it past the braintrust.
What I have in my car now-
88 Lincoln LSC 5.0
BBK shortie headers, Cobra 2.5in exhaust, X pipe, cats, Flowmasters
MAF conversion, 70mm Ford MAF, calibrated for 19lb injectors
Ford Racing 19lb injectors
BBK thru fender air intake
MSD 6A ignition
A9L computer
Stock intake w/ 1" spacer.
What I plan on changing-
Install 97 Mountaineer HO intake.
Install 70mm throttle body calibrated for 19lb injectors. Any preference on what brand to buy? BBK, Professional Products? Will this work with my existing Ford 70mm MAF?
Using the EGR spacer as a spacer, blocking it off. Need to keep it in place because of the BBK air intake. Is there a 2" 70mm blank plate available?
Remove the smog pump and thermactor system, blank off ports at rear of heads. Install Ford pump delete bracket.
Remove the TAD, TAB relays and vac lines. Will I get any codes?
Also going to remove unnecessary Turbo Coupe wiring and re-work the existing wiring harness to clean it up.
I would like to clean up the A/C lines if possible. Any ideas?
The picture below is what the engine looks like now.
[IMG]http://www.foxtbirdcougarforums.com/image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4TQ4RXhpZgAATU0AKgAAAAgABwEPAAIAAAAGAAAIbgEQAAIAAAAbAAAIdAESAAMAAAABAAEAAAEyAAIAAAAUAAAIkAITAAMAAAABAAIASYdpAAQAAAABAAAIpOocAAcAAAgMAAAAYgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENhbm9uAENhbm9uIEVPUyBESUdJVEFMIFJFQkVMIFhUAAAyMDE3OjA5OjIxIDE1OjI1OjAyAAAfgpoABQAAAAEAABIqgp0ABQAAAAEAABIyiCIAAwAAAAEAAgAAiCcAAwAAAAEBkAAAkAAABwAAAAQwMjIxkAMAAgAAABQAABI6kAQAAgAAABQAABJOkQEABwAAAAQBAgMAkgEABQAAAAEAABJikgIABQAAAAEAABJqkgQABQAAAAEAABJykgcAAwAAAAEABQAAkgkAAwAAAAEAWQAAkgoABQAAAAEAABJ6knwABwAAIJQAABKCkoYABwAAAQgAADMWkpEAAgAAAAMwMAAAkpIAAgAAAAMwMAAAoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIAAwAAAAENgKQBoAMAAwAAAAEJAAAAog4ABQAAAAEAADQeog8ABQAAAAEAADQmohAAAwAAAAEAAlrgpAEAAwAAAAEAAD ApAIAAwAAAAEAAD ApAMAAwAAAAEAAAAApAYAAwAAAAEAAAAA6hwABwAACAwAAAoe6h0ACQAAAAEAABBgAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAADwAAAAoAAAACjIwMTc6MDk6MjEgMTU6MjU6MDIAMjAxNzowOToyMSAxNToyNTowMgAABegqAAEAAAAEAAAAAQAAAAAAAAAAAAIAAAAYAAAAARgAAQADAC4AAACaAwAAAgADAAQAAAD2AwAAAwADAAQAAAD 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 AwAEowVlFm4J/gMABP4FUBQXC/4DAAT2BFgbQQr AwAEaAVwF0IG/gMABF0JggzuB/4DAAQCCEIP8Qr AwAEEgVuGm4J/gMABP4FUBRuCf4DAAT BVAUPQHlA2L ZStJAbMDhP4zJVwBcQOz/kAfcQE5A D WBuPAfUCHP9wF54B0wI6/ AVsgGrAl//UBTOAXsCkP NEvEBSQLH/9gQDQIoAu//tw85AvwBJwBwDoQCuwGDALIMrAKhAa0A6wvaAoQB3QA3C4ADQQFoAW0J9AEVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgAAQEBAAEAATIAIABSACoAMAAZABwANQAiACkAJQApACYANQAmAHwAIwAaABgAHAAfACIAHwAgACUAJgAkACkALgAnAC4AGAAVABkAGAAiACUAJwAoACEAJQApAC0AJwAtADYAJwAAACwAMAAqACUAJAAqACsANgAvACMAIwAlAC4ALwAvADAAbgB6AJ0AWABiADYAPABpAEgAVQBKAEsAQgBeAEIAEAFXAEMAPQBGAEsAUgBKAE0AWQBaAFEAXQBpAFoAYgAtADQAPAA 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 QAQAAAXAaA9oPPAHEADAA0AHtDocMAACllpaWQABAAEAAAACWc49wD8YAAAAAnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH 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 ADcACgAjAEAAIwAwAEYALgA3AB4AQAA0ACAAQACcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH APYEVoAAAB4B9gRWgAAAHgH2BFaAAAAeAZwP4QENAKEDeAD2AZYBAAAsAbwBXgA7EdkBmQBVIekBzwCpMdsB/gD2BFaAAAAeAfYEVoAAAB4B9gRWgAAAHgGcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH APYEVoAAAB4B9gRWgAAAHgH2BFaAAAAeAZwP4QENAKEDeAD2AZYBAAAsAbwBXgA7EdkBmQBVIekBzwCpMdsB/gD2BFaAAAAeAfYEVoAAAB4B9gRWgAAAHgGcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH APYEVoAAAB4B9gRWgAAAHgH2BFaAAAAeAZwP4QENAKEDeAD2AZYBAAAsAbwBXgA7EdkBmQBVIekBzwCpMdsB/gD2BFaAAAAeAfYEVoAAAB4B9gRWgAAAHgGcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BAAB2AIQCIgcAANERlQdlAN0htQeTAJwx6we5ACYx9AfXAN4DBjHyB IA3AUwgAAA wAAAHYAVgJLBwAABgG6B2MAwyHIB5QA8zHYB7sAFjHtB9wA3gPjMPIH5gDcBTCAAAD7AAAAdgBCAk0HAADtEZ8HXwAfEdQHkgD6MdEHwAD3MPAH4ABMBK4w9gfuAPAFKYAAAPwAAAB2AOwBogcAADwBsgddAC0R1geaACgh3AfMALkw5gftAN4DdjD4B/MA0wQcgAAA QAAAHYAXQERAAAABritish cigarettehB1QAZBHJB50AOCHYB9YAsTDFB/gA3gMZMP0H/ADBBAmAAAD9AAAAdgCDAiMHAADUEZIHZQDWIb4HkwDMMd4HugANMeAH2QDeA7ow wfiANwFOoAAAPYAAAB2AFYCSwcAAAYBugdjAMMhyAeUAPMx2Ae7ABYx2QfcAN4DsTD5B UA3AUzgAAA9wAAAHYAQgJOBwAA7hGeB18AHhHVB5IA/jHQB8AA8zDrB AATASUMPgH7QDwBSmAAAD5AAAAdgAAApAHAAAwAboHXgA2EdEHmgAXIeIHzADbMMwH7QDeA1Uw/gfzAOIEGYAAAPgAAAB2AF0BEQAAAHwBoQdUAGQRyQedADgh2AfWALEwxQf4AN4DGTD9B/wAwQQJgAAA/QAAAHYAgwIjBwAA1BGSB2UA1iG B5MAzDHeB7oADTHgB9kA3gO6MPsH4gDcBUGAAAD2AAAAdgBWAksHAAAGAboHYwDDIcgHlADzMdgHuwAWMdkH3ADeA7Ew QflANwFM4AAAPcAAAB2AEICTgcAAO4RngdfAB4R1QeSAP4x0AfAAPMw6wfgAEwElDD4B 0A8AUugAAA QAAAHYAAAKQBwAAMAG6B14ANhHRB5oAFyHiB8wA2zDMB 0A3gNVMP4H8wDiBBuAAAD4AAAAdgBdAREAAAB8AaEHVABkEckHnQA4IdgH1gCxMMUH ADeAxkw/Qf8AMEECYAAAP0AAAB2AIMCIwcAANQRkgdlANYhvgeTAMwx4ge6ACUx4QfaAN4D1TD2B QA3AU7gAAA QAAAHYAVgJLBwAABgG6B2MAwyHIB5QA8zHdB7sALjHaB90A3gPMMPYH5wDcBSeAAAD7AAAAdgBCAk4HAADuEZ4HXwAeEdUHkgD MdAHwADzMPIH4ABMBLIw8gfuAOsFKoAAAPsAAAB2AAACkAcAADABugdeADYR0QeaABch4gfMANswzAftAN4DVTD B/MA4gQfgAAA AAAAHYAXQERAAAABritish cigarettehB1QAZBHJB50AOCHYB9YAsTDFB/gA3gMZMP0H/ADBBAmAAAD9AAAAdgCDAiMHAADUEZIHZQDWIb4HkwDMMeIHugAlMeEH2gDeA9Uw9gfkANwFO4AAAPkAAAB2AFYCSwcAAAYBugdjAMMhyAeUAPMx3Qe7AC4x2gfdAN4DzDD2B cA3AUngAAA wAAAHYAQgJOBwAA7hGeB18AHhHVB5IA/jHQB8AA8zDyB AATASyMPIH7gDrBSqAAAD7AAAAdgAAApAHAAAwAboHXgA2EdEHmgAXIeIHzADbMMwH7QDeA1Uw/gfzAOIEH4AAAPgAAAB2AF0BEQAAAHwBoQdUAGQRyQedADgh2AfWALEwxQf4AN4DGTD9B/wAwQQJgAAA/QAAAAgICAAIAAgAUABnZDQhUABnZDQhUABnZDQhVABnZDQhVABnZDQhTgCXABwAYgCeAAEAigB2AAEA/gABAAEAAQD AAEABggLCxEAIAAGCAsLEQAgAAYICwsRACAACBAWGiQBIAAKGiMnOAEgAD8AFQAkABAAHABmAD8ADQAgAAoAGwB2AD8AFQAkABAAHABmAD8ADQAgAAoAGwB2AD8AFQAkAAgADgAzAD8ADQAgAAoAGwB2AD8AAAAAAAAAAAAAAD8ADQAgAAoAGwB2AD8AAAAAAAAAAAAAAD8ADQAgAAoAGwB2ACYAKwAwADoAQwCAAIAAgACAAIAAgACAAIAAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQC4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4C74CQv0PAPH/VwGpAA0A8wES/ 4AmQNn/IgTvgJC/Q8A8f9XAakADQDzARL/7gCZA2f8WBu AkL9DwDx/1cBqQANAPMBEv/uAJkDZ/y4C7gCSP0aAOb/VAGsACUA2wES/ 4AmQNn/IgTuAJI/RoA5v9UAawAJQDbARL/7gCZA2f8WBu4Akj9GgDm/1QBrAAlANsBEv/uAJkDZ/y4C7kCR/0OAPL/WAGoACIA3gEQ//AAkQNv/IgTuQJH/Q4A8v9YAagAIgDeARD/8ACRA2/8WBu5Akf9DgDy/1gBqAAiAN4BEP/wAJEDb/y4C8oCNv0LAPX/hAF8ABYA6gEG//oAhAN8/IgTygI2/QsA9f EAXwAFgDqAQb/ gCEA3z8WBvKAjb9CwD1/4QBfAAWAOoBBv/6AIQDfPy4C6gCWP0PAPH/kwFtAAEA/wEW/ oAcAOQ/IgTqAJY/Q8A8f TAW0AAQD/ARb/6gBwA5D8WBuoAlj9DwDx/5MBbQABAP8BFv/qAHADkPy4C/T/9P8OAAAAiBP0//T/DgAAAFgb9P/0/w4AAAC4C/r/ v8HAAAAiBP6//r/BwAAAFgb v/6/wcAAAC4CwAAAAAAAAAAiBMAAAAAAAAAAFgbAAAAAAAAAAC4CwYABgD5/wAAiBMGAAYA f8AAFgbBgAGAPn/AAC4CwwADADy/wAAiBMMAAwA8v8AAFgbDAAMAPL/AAC4C/L/8v8PAAAAiBPy//L/DwAAAFgb8v/y/w8AAAC4C/r/ v8HAAAAiBP6//r/BwAAAFgb v/6/wcAAAC4CwAAAAAAAAAAiBMAAAAAAAAAAFgbAAAAAAAAAAC4CwYABgD5/wAAiBMGAAYA f8AAFgbBgAGAPn/AAC4Cw0ADADy/wAAiBMNAAwA8v8AAFgbDQAMAPL/AABuAGQAhwAEAAUAyAAGAG4AZACHAAQABQDIAAYAbgBkAIcABAAFAMgABgBuAGQAhwAEAAUAyAAGAG4AZACHAAQABQDIAAYAfQBuAHoABAAGAL4ACQB9AG4AegAEAAYAvgAJAH0AbgB6AAQABgC AAkAfQBuAHoABAAGAL4ACQB9AG4AegAEAAYAvgAJAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCPAHAAcwAJAAYAxgAPAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AogB6AHcACgAJAJ4ADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AsgB8AH0ADAALAJYAEQCyAHwAfQAMAAsAlgARALIAfAB9AAwACwCWABEAsgB8AH0ADAALAJYAEQCyAHwAfQAMAAsAlgARAGQAWgC1AAUAAgC0AAUAZABaALUABQACALQABQBkAFoAtQAFAAIAtAABritish cigaretteQAWgC1AAUAAgC0AAUAZABaALUABQACALQABQBuAGQAhwAFAAUAyAAGAG4AZACHAAUABQDIAAYAbgBkAIcABQAFAMgABgBuAGQAhwAFAAUAyAAGAG4AZACHAAUABQDIAAYAfQBuAHsABAAGAL4ACQB9AG4AewAEAAYAvgAJAH0AbgB7AAQABgC AAkAfQBuAHsABAAGAL4ACQB9AG4AewAEAAYAvgAJAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCPAHAAcwAJAAYAxgAPAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AogB6AHcACgAJAJ4ADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AAQABAJIAkQCTAAAAAgAGAAoADgASABYAGgAeACIAJgAqAC4AMgA2ADoAPgBCAEYASgBOAFIAVgBaAF4AYgBmAGoAbgByAHYAegB AIIAhgCKAI4AkgCWAJoAngCiAKYAqgCuALIAtgC6AL4AwgDGAMoAzgDSANYA2gDeAOIA5gDqAO4A8gD2APoA/gACAQYBCgEOARIBFgEaAR4BIgEmASoBMAE0ATgBPAFAAUQBSAFMAVABVAFaAV4BYgFoAWwBcAF2AXoBgAGEAYoBkAGUAZoBoAGkAaoBsAG2AbwBxAHKAdAB2AHeAeYB7gH0Af4BBgIOAhYCHgIoAjACOAJCAkoCVAJcAmYCcAJ4AoICjAKWAqACqgK0AsACygLWAuAC7AL2AgIDDgMaAyYDNANCA04DXANqA3gDiAOYA6gDuAPKA9wD7AP AxAEIgQ0BEYEWARqBHwEjgSgBLIExgTYBOoE/AQQBSIFNgVIBVwFbgWCBZQFqAW8BdAF4gX2BQoGHgYyBkYGWgZuBoQGmAasBsIG2AbsBgIHGAcwB0YHXgd0B4wHpAe B9YH8AcKCCQIPghaCHYIkgiuCMoI6AgGCSQJQglgCX4Jngm8CdwJ 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 DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6eG1wPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIj48eG1wOkNyZWF0ZURhdGU MjAxNy0wOS0yMVQxNToyNTowMjwveG1wOkNyZWF0ZURhdGU PC9yZGY6RGVzY3JpcHRpb24 PC9yZGY6UkRGPjwveDp4bXBtZXRhPg0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICA8P3hwYWNrZXQgZW5kPSd3Jz8 /9sAQwABAQEBAQEBAQEBAQEBAQECAgEBAQEDAgICAgMDBAQDAwMDBAQGBQQEBQQDAwUHBQUGBgYGBgQFBwcHBgcGBgYG/9sAQwEBAQEBAQEDAgIDBgQDBAYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYG/8AAEQgCqwQAAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5 v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJipen 15So1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5 jp6vLz9PX29/j5 v/aAAwDAQACEQMRAD8A/nJ1H42eL9T06Lwrol5ZXunC aS5n/soE3l6F2KEJJJiUZAPclsetclP4x1vSdM1TSz5L69cxul5dBtghLDDBAOrEZUntuIzzw 88PaN4E0qxbw1rTv4g8WRrGtxquneXNYWQ 4YUyTl z8Y5Poa5LUbHUoFkgj8QWet3dlOBcQkIzueMLk5J68knFazcFJ21/r9CIU48t38y9aXmoz2JkMLs8hVFXT5 PqSTzk npXK6kun ZPa6ow0 8ClxJqIBVh0wHQevrXTeH9H1HU761uLqOxhAuFP9mIWhiBLcZKjHt0NepXHw3/4SHVHvtUi0 ZWuPLGmW0kpeNVGMtyNx9FxUSwlJyc7Wfka05Tvy7ny3a6jqFpexokt4YXOIjE 5CP9kdMZ713HnXpeHy57eW6mBKKWJZfqF9q m9T CfhSxWF4bK50bT5l/d6jZWsj YQcZAJ/vnbgHrn0rhB8IL601Ce1g8SaO8TRSShhbskuAMhQnJ3N27euK4cXl0q8k Vf5/cdEK8qWl2jymFPFUccWrX momjvdGC3vwGVPMUBjk9SQGXgdMiteDWnjleBJ7eOYwAwqW8yWTPbZyw59e1d3N8I/HulWzXdvatc3sFt59xbCB2aK3Y4SR9oAAOD6H8xXBanpjaG5l1IW0N9Pg3VxBD 9CjnGF5A6feOeKmWCoNcrp2t2uLmqUtW9Wdsl41oJrXV9RttOuG8vbYNIQ8it024 8ee1NnkZUY7VZJJAqSL82B1Jx2rlAmiXkipLdbx5eFvLmMsYmIJGQuWx06DHvUFrd/wBkXpjvt13apAq2kmmMyogJByVcEDHOa5KmS0KsrR91 f8AwdTqWPqcq5tUei2EFlcWtxJqN9LbqkR8uKK2DOX7dD7ipksNKEMgM14yxL87FFAwR2Gf85rzLX9ThadrvTdRDWp ad052nH3dpGWGe421zsur6/GEvFnt57eZsR2iKzgkYySR8yj6/nXFVyTFqV4ST 4v 0IuOqf3nrLWehfa2WKC6Ci1z9rllUqr oQLjn6mm22p2On3VxcxQ3F9D5eIrG7uB/rscE8cKfTvXAW2vXDx7ZDGJGkO0wzDDH0HIOR6Gpk16wadXu7aIX0cZeyeRgrrzy33TnHPeuFYWp7Xlmvw/yLniEoJ30PSfhlr8uneL4NVdGgNtfxi8XyCkKSNkbVbufx/Cv2esPC934m8M6X4k0W4BvFgVl8t8k 1fg2PEERluBDdXE1woEjjziVXjuB1P1/Sv0e/ZZ/al0bTrK18N ItU2iEBIpJpAF mM1viJJK6u2t1/Wp6GBqrk5Ho j/rc/Vz4FSXkN3cTeLYLllggIhV1wCcdTWnrmnWA1e/1NUEMUzEoFPauAh Nfg HSHvItWsfK8sEN56jjFfI3xn/bF8J H7eSDSdRh1C/ZSI4LaUN82PrShGlNLkVvkVWxbjN 9rY9C OHxx0TwNpd5b esl4IW8mMNyDjjgfSvyS8X L9b8e3NzqcNxJNJJcnZA 9HA64UH274Nc547 J2tePtQu77U5b5tRa9Q2sNlEWTyiMna/IDDnsa871h9SmkTTF8U3KafNKJPtaayzxi5YYTzBkASDBB3bQBX0GFhh/Y8rerPncS8RKfM1 h6WL 1isEg1bTbmxCOEMrIkSk/xb1ziTnupVvr24nUhHcSXY0rULG7jhcMsyKYBKON21HXd8ucYI57GuROp MopJIprm919I3IcaugkkMOMeYjZwVyBjkAHHWup0LUbe7sroT20WnXNvL 6KThn2r1kck/KuAe/J6DGTTlhnCF4pSRMJpz9669RLOLVoxcwy6bC1vKXe0EJCz4A YHrjPHUYODWRfS69am2f7TdC1uE3C2vbn92Y/4vlJG0/NxtHvzWrdyXUk19rNnqrR3NvALeZopHWQAjguyjvnGCx69qbeSa7rGm6jCmi/Y7LQzAura9YMt3FFHJgqXDElc542gnOfQ1VHEc2jtbtf8Az/QirQTjdJ36P/gnRafOmm3Fx9nivEiuCrkNONjIeASuNrgL1AIPoa6G7tUiuJZdOht4l8syRoLEoWDqGyUOcnrxnvxXDx6xo1nGYL7VL3UNNQFZL x0cC7VQCAqZlC8  0YrU8O3k5sFmubqC tZVDacthjzIxnA8wDoeO3oTXHicPOnG6s1/XzNYThJcvUWDQ7S gmvprE3Ec9sz35vbXydqkELxtDdQw6/XNZNzb6ELqO0MGoCRkhxbRSEyxq3G5BnJHHQZ613N5Hch1SZpbZyxHnNOzLIM5AY5PPPWqNzONKu7XU7S8jhvYpGH2i6DNKkigFfLkwCnYjHHHauPD1pVK3Le8X BvJRjRvazXQp3PhJtW04T2d6s1/pEm6NJ2CIwHJJJGSRjo2c lc7P4l8FW81jM0fih9YS0kWa01O6TTbd7snB8uVNwZCCcgiNvSta98S31/MiS6zILi7vBJdvIrxAZXDb1I/dnGWB5HeuM8ReHYbuynlfxAHtoYC8W 3lMkTdvm2BnznliCo9elezg4ypytJ6HHWi5x93f v66FL/hLNVuru3tbaKw0d7OUR2b2UBY ZI5OUlRuWO44JJPbNek6lrl1pdtJp/i0/wBra9IEnZ9Q8y7vbmRuUBkLEIMHJzk5xwea8X0y0vvDC3ax2NpeXk8am2u7jc CH5eDawUt6Pg4B49a7p9X8UXDT67qV7Nc34IbWYZNQaOQhTgbVYAuSAenHqRXqNO90zgUXDo1bqdnbwrrdrqoud2kT2WxrCBrwSqdxAIIKg7ugzxwMYrLvvF0O2QyaLFdWdjFs33StbsGAAbbKp24O0cYz7iquieKdS1jULlJLSW2hmt4zaR2uiRqkUSgAsdn0JYk9cknvXRfECHw3YT2NoIWvb 90ZJbzULWTbCWcKyKkRyNoRhknBJ/uqATEVJsqUtLnmv9qX2qC9kmsoLS3 0K6so2PGv8OZCSp6gAtz6YrtdG8LeBotMm1nxT4o1WF/LddL8N2MX2m7u58AK0k 8LBEMj5m Yg8K2cjhf7Qt41uLbR7BitzOWi1mWYx UBxjy8snJ9Ppmu10zwdeTaK2v3Gmzx22qXsiWt/fWz2Yunxhkgf7kr7gfkjDN14q3e5ny2jdHHWg0O1juS8OmQTWVy8lnq0fnXt5IxA2xP 9Ee0YODsB65PTHbT Or4QQ6hFHO13axosUjXKwxMAPkYllLAAL90hccYNOs/h3pGl3UKeLr6PRbMyb5bKVU/t5ZB/yzjg37ieg/fFB RFbuqfEvxLYQWPgnw74B0vTNCsUke21Kyt4m1a438 Ze3eA83yk4iBSIdNrdSKKi7l2utXf0/Xt fkeWQR2Gp6pda1rludCuLmQzQ65pTBQ0rZymMbSMk5wenTPArZ8R6DaIkF5H420nxJDJc2yLY2Gm3SfuSWMkkqSKiiVDxgYzuBUHk1x0xEz3d3DFHe3bSFRA0BhdO7EQAYKkj DGMdMVraA pWskPiJbOKGK0vY49 pRSyWLrtz5bmPDKDjkHr2qdW3cmMW1Y1tag8A232BtE13VlZYlTVhJ4YWziRy3PkuJS5wNhBlVeT93iuwsb/4YXOnSW p6F4q8U3UCZfU4/E0VvuUYB/cm2OW5x8j7hjJHWm2GtWPiCz1Cxv9C0K01BLogajb225AeCqohXIUc5x1A 43WsLW9C8SL4d0qRm0JtGe9KWN7DZRQtJIDk7gFAc4bjd8w9Bmos76dC3J2/4Y2LfxTptql/a HvC/h2K3eL/RdQ1e6nkvowCDsEjzBSw54MeMdPWobzUp3eyF/YW6aeuHW 0qDcQzDPz7ctjjqGxxWToXhXxDdanHbS3ukaOt XZLnVJkhVtnDgzEEKoU7iHxgAktV4eGm0O5/sqTxBb3gkdkm/s xuZdu4ZBjUxhWUg5DISpBB5zRfQOR8/vblu8sLCfTzqDZjinR1tY/tClOTjOBjcOg7EehqPQspoogeIzdDVLK0lsCE/d6rHEsidwj5yBx0P5159rGgwWW 6sdRuGBlK2b3JVDcjdgbCrsMjuGxj3rm4ItVubgW0Mci3sas08MfEif3sgnH4D1pOUrjkkldK57TH4z0BndL1FvobuNlns1Q/PJ0GSuRngElcEjvVhfEcVkFstPsrhrSKGGS9lvbQjy25LojrJkpwMbsH19/H9K1O20y8Zvs8LmMFXjubUsjv3LDsfcd69E1DWbHxHpcRsLSaKe1YrNB50ao4x1jct5gGBwrEj0FEpSWiHFQWjO4sPEcksrzjSZ9QsmlREWa2EYkc8bgS5JOccg9K6ex8TQyX4W4064s4LYlDPfBsEN2QKCDwcBv5dK8J0Xx5D4bi wr9sEEk G068m8yIDPDRktlXBJ4HH0zXodzeWmszaXeW p27XNkw8qMuE3JjiOdMkAdcdffrRG/3laPTU6hkl1fUrqHTJ72xeBlZWtmZnSNuAp3AALnjkr Oa5zX/D2r6NFLdvG13GriOc283mw YMgB8IPKkwGPvj05Nu3ls47a8l1LRbqUXUTmC Sfy4otv3AqoSPxBPJ7Vtap4t0yK5stMk0NlurWOJb1beWYtMu3IMrPnecOMFWUjn5c0uVtk3jGNmjlLHV4Toi3Ur29hNcSGC5vjFMWt1ZgN7ZYnGCcsFbHTGaI9S023uPI1HTLzU98iixkl1RPs02B/rBmI5zjg8g57Hiuol0vQNQtp7iyvotGvvIZm022t5SsIU8bnV9wBwOCFHT3rzny9dljub1oDd29iF zrJeYUMecoS Vz6EY p5FJK2wO60Og1HVdL1uO2sE0CDSdSs0dbaSORwJgGz84ZQoYDoRgEYyCeaZZaNZTTPEL9tO1K3lU2dxf6mlrEpwdyl9hIJOBjcAcnNc7p99bavLH9vt9UFyQsdrJb3ChXYnlWAz vp1rspNPitWa3uYL0JPIIYrYTcwjqTgEgjOcgnis2tS1eS12Gx2KXz3Ews4tWkZY45INLmNyMkZYREbjnJGUyR16Vn3HhW5tLy5gm0Ui3itlke3naSO4jjfBV/LY5K/d3KcHnt1rWm8N2tul1eaXANY08RNFcfZlKPBMwIcMUGSADnGSK5oXN9o8elPeB72yVmRtuqbY54w4yv0wAMcEetU5NR8wtomdTbp4gYrBaQ2kSxxolrLpmrKWSBjkkRFyzxt/FjBXnI4p q2k2n35vrlgLeUZt0tEP7sgnG1iCWC5IIOcZ54rzq trB7kzadqVzFC4QBVuGRluGByBnAXPTPKn1OK3tD1WfS9S wXUV3rGmwMI9Qs5rUo74B3pw3yNknDjBHbAyCL3dtgi38zo9Mv5TBdTS2lrqenoM3EVxeEy5BBZohgBGA7d/erB3JELvR7mFbO4iDOk6EKZOP3T5A2uOcHgNtyKxrbSXitpZ3hsjaQXPlRWtzN5V0jKAR5qq25cjoTkE52nggWFWSydL5hFbJdIVeymjLJKAfnRl27SBx1PHXrU 90HyvsP069mjkmeU2UsqI32hpo/3hU9Qwz8w469a63w/41m03zNNG 4sLo7msbe6mVfNAOx0OcYB9vxHWuMcWskvnWVpcxeVI2xri5DiND1VlCZZcHG7r6jtXY6C k3MM n3KSpqEkIWzt7MAbhjLtEzYJb2PJxjIrRXm9DNKKVpbHsPhH4jX1rqLX4t9Evo7S5AabUNIQtId2WWUE/NgHk9SPzr0Gb4t JJpNSbRX0HRY5Gb7fDoWjxxlo92RIjylyvJIBXBHAz0NfMUFprixfa9Haa5FozPdyw2WYpYwOjMPuvx0Pf04z2ugtHBZXWpXFrrCT3A8lFlhTzYgwyxRScvjngEZ/GqUV03CMZK3Y9LvfEM2v3CazrWo6h4l1udVxf6xevcOybseWynBDDthiOc81UuIruwv8A 3rS4j0ua0ZJ7VRIoeOdc7SgVsBh6gbh19qxfD9pqDoX1DVRbrHD 5MkLMl0jk7QVwcH8yp6ZrRijsbe5eXWoJJoftSInmXBiuRuBLO6BD3Aw2PTPWlzJMTpq1itc MvGtlqEkmneLvEQvNZlZbi k1uZLi6kbqsmCA6kH5sjnnOeo4/TpbjWJGaxs3KiffeJNeszwzA8OCDnaT3bOfXNdCUe9ltrp4ZLe40y 22rtthjnWP5gRgbt47Egfl0x38vStc1LVrlbqBb6LzrKVLI TuyCY5MYAz0784PfNNcy FhyQTR0jvqbLNf3TWltdy2u2K0EiXKv2JOc7cgg89D NVo9c11Hshb6qIrbTHGG3AGNhkYKhzhSCQSuMjrVe4utD1LZeWqtppvJk 06XGCFtnCDPLszdRuYhiOeMVDeaOLWUeUbW9SSAmVoXdjIvdkfjkcd /XFJc3ca5WtNyS71K/wDKubUPFGHuiZoJ7U7ogDncM87STxyOaxb2cXck32z/AElYXVZH/s90Z04/eBTyfQ4/wq3qGpJc2kUX2Nk1XTgYprizvnaS4t2/vxgMCcdSPTpUWmWra1B5SXFjbzQLzcvDK8lx24XseQDgDBHSpSV9RRkpJWVkVIxLBdTzi9u/s8KAbELq3l qnrx RH5109rrcR06XT762u7q0uGaXTr6BwkkTAYzliQ647cZz1rzied4GEFvYGS8icGMeZJG5QnG1gSc9DwB071Zhi0/UrvbeTy2ipGzR6ZakK0cmRhHEgORwcgYppK5Uk29NGbl3o1zfabPqejyQXDQN88Vq4LK2PmD7eBgd nvXm08Go2F7BeWNvIsrfM8guFIkBPKMFPGfp2rcurh9OlR7K/nEjyhro2yN5RXgFni4AGMj379KZNa2csd3bJeXktzdRNJDBOERHJP8IL8jkYHH0p25le5KcXG3U4i80l7qU3FiJyskbyTwLco/lN0bguM8569KoR2Ny03lm7tppQwiSxj2gmMjJwQTkitW8tjZwCOaXT5JEj/ANISGVwWbPQgkfMM9h09aoW2narbxyaorQKm/wD0S8W4dghwfk3fdDYBOCearkl01E1KVrI1tXt9c0aPSLi4nlnjmnME1vEJTPFFtUiRzjaIzuA69BnpT7mHUpbSSKWPUFjSLEcxkEwRTwpz0C9eMjtWMg0GaS6m1aW5S3ljMiX9ppsTymccqjEyrtQj0z9Kfp/i3Vrr93Dr2r/Z44kjs11S7byGiQNiFt 5cgYwDkdfWnOLb0RKUYvbYoWmj3Vpd29wWureOKQBZIkDNIMYOVyODyDz0rO1dmUMI3e5SE71CxHYE/HJ444H0rv77x9HMxYw2V/FgedMdLihbb3RcIN3JPt0rlbm6iuGmkH2OGCZmeG1gjSQqpAGcEA9DkAjBwfSpUUncqVnJJosXS7tH0yS3jt5Nu SW9s7Axyb5ADhmzhtvQcDvnOa1NNkjnsWsTdWN/qUODatfOsRVRnMexxtYkkdDnPSuCtpNTliX7UWJCf6NJLLsA9BsU8dOtUdQcRQiC4t/JeY5MU7fKSP4gSd2D9cVei0CM3Jao9uh0bxH4fkg1LRdT1fw5fzLHLeN4e1dklnjODGfs QXXspooge8pGO/XhNTm8QX2patqmsCxuNsvnX8bP5F1NJxvYK5wXbrhT1JwBV3wj46123t57eHV7q0 yWBTT0aFJY3QYJiYFTuTvznoPevQI/iBpU2nLp/iLwdBqVstiT/bOh6jLBdrJuX94YmZo2KgsNo2D5hnpWTjzPUrnjfa1/wCtbHl n6j4Sv8A7faJ/aWmXaSf8S5ryPeohCklHJO0H0GeOlbEV7p l3sDeHPiJpMsHnW4lk3y2mXKBmWWN0UkI2U3Y2kjgkEE yW hfBzx9DZWZ8Tab8MdddhH9p8a6XcWccZUZWSaRRNEyvuIyHQDuAMV4d8QfhZd/CPxJLZ63rnhrX7aazhng8UeCtXiv7KeCZQyATQllbgjIBJByCAQRSdOSV0atNr3Wvnv92jNbz4/EGsyCXxVo1rqYkkRIzMlrZO5JYssw2x45PfHSprfTZTfz6eL3Qr632 RLdTanbKFdx95ZN5Dgeoz7mvNtMsF1TWIY7KDT7221Hd5Dw3LbCcAH5M7g3fBAPNbKWGq H9aN3ZWsvhl9NlUWEt5L5AllUjzMBiR1xxz tTGtbQjlkfRngzxTonw4OoeFdR8NaL4nn8T2lq0Gu2ujx6pd2MKbsizB/dh234LABlKjDDFfSsXx/1BvClnqXg/wAL6Lb JoBe2PiDxf8AE3xNDr/iJ4gqjFvbuAtkhTYisFaU/MFk4wPzzj8X3 s6sreKr3UdX1i1meKGO51eWRY4NpOGZckR8fdXAyeBXp3w 8Q6LrFp4o0W58V B/A0k/2ebSrG4s5Rd6jMsqoIbe5CExsFkdy0rrHhOTnFa0anLL1KfKlvZr7l R3mc00chZ3UeoavpkNtYa0CLwPavp0LpJnlGuJFaT73U56Ul1rHhTT/BmlWGk GdKs77TtYkTUdSm1WS9vp1PH7iMqtssYBXhVlckElsYFenH4VeF4vFUMHiD4sfC6Lw/qKi2u9c8U KrzxBHYSFB88Z0xCJWG07Rll5GRxmuX0e3 Fvh631rT/GGqan4tt7LxArWMnhPSltIr6wSYh2W4mdXhLxjK74JGG75gMYrrjVko7mcqcYrmb 53/zf4HlcrLqJ1C3SLUJbIXS/wBl6dJdBju6kAfKoGQOkdZF/oItNWsNR1O0ttDhltyDZ396sko/ukoi5x9UzX0nFqXwyljabSfDup3GgahbmXTrC9v5Lm5soVLbVGwQW8jjcMsyc4PTvwPiHU9J8SaTBNDpmoyXFtfeSptdOsdMhTqcMlqjF1GASSD0x6Uo8rb91v8AAtpqOkvwPErWPU4lvoj4ut4tHsdXRhYPeLFbrLMMCX7MxBYYXBdYyRgZPSjXbjQkRra41G11Jp7cmK806F44dwJzuEh3Zx3C1qTaKZpdeNvp1myyLCXgbTJpC5LcsjEIB9D69KuaraaeIbXTNbsnt47Gz/0cafp6SO78YQg3GAD/ALvbpUTg3q46CjCUZXT/AK 8881KWLT7Oyg0 HU7aW8j2XM8SyeWU/hwCn153c5rnLSy0 5 1qdWuVWBGcefFIAx9MbT82e RXs tWHhew8O6Rq6aZ452QSLFfC98M2lvg7SF8tsvnLEde3NcRb3Hh wfUmisdekeCLahlNshjLYI8wGIhu4IGD9K56lOkXHoci1rq qRTWrTaOVt4PMs01GVYZiB1EbAAE/UjP1rkItTt7O4VZoWtbnyTDPay5/ePuOCvbGO TXtD21jaojXJuZV y7rKGXUFDqM qpkY9Oa4  0Szv7YTXgLxTuXN89uSEOCSvoee9c7ilsOUFJanPJLp16rvHD5ckUTeYchwzcbcjIIHY0ujPANSgml1CTR2guhm9tSWki9GRhzxjsc8e1Yknh2IO11o929hMWC7ZVDK euFP8sVoxtPbyrp/7h7izQG4mltzFu565DEDr6c1NpaIziop6nvl58Z/HmlabbaR4rvdL Iei6dCosH8TYuboW8hwoS4YCUqu0YViVTPAGTWEnjD4cwveavrmu MLGb7AG8J6FZ6PE0UV6XBMcrl1/0crn7oY56rgk14xrMdxd2Ml6iz/aLdcQs0weORF5K4znqc9BXIweL7J9Tthq0dq9xZ267YL9sYwOCeB0HvW0ZOFm9hW5Hdbfgelv43svFOvPZTaO mqZG 0SWF6qrI2eNgdSEOBjAOK9A8L3lnpd3caV4b1Qw6pqUL2 o2HiqSEvLExUhUkcAKwZQB0JHQ8kV5LoOh2XiGO9vk1zw/BJaN550 81JIJZcckQdA59gcn0rBMdneDUpL2SQXflstjMkm8hgeh9V7VLkrXWxMoue3fyPrXTtd IXgDxA8Ws6pq91a2bC7sol0YXC2jPgh48jdGemQCARyOua6X44eKtH I0cfjT 1PCXirVoLBZtU1LRQ m3NvMAQ8V1Yzph5BtBLRblb7wY818s EPjn8WfAUaeGvDXizUBpuq2wW50fUdlxbOiAggCVW2KQSCqkA969X0z9qO00HwB4s8BeJfh54VvNC I8lvJ4mn8OLaC8a5s/N8mRGmgka2ZfPfIhaMOD82cDG9CqlK0lv/V/63NLwh0t37fp p8nva2Gubpkt4obtbwswAMRfkYIycdPSvQbPw3qFrpIvLyzmttN1GFmje42xpNtYhgD35B56iuDs/GXhGKyu4NStPEN3dLKp0lkuESCCPPO4A5Lds/4V7vpHxG8J GPDrpf/D TxZa6vDG2m3GpeJZFW2kb JYkT5888FuMmlOLpy1Wj/ruZxnGdrP vuPjL4r6dzHJbGCIPJs zI5LYX It369q5Px9qWmeK/AtjGrappmv6F5EKacblHtZ4QpDSABAVOQOpOc10vxi1iN9VQQollKAWa1UZALHPGO1edeNo7XRvBHhC/F6kut KoJ7i4s1x/o9qspSIk5zlwhbHoRRh1B1oP7V9BVk dpbW6nh pSMsdtbAKGgT5yp4Ld69h8CJBpvhbU7 6EqGW0LIwGB5hbC/UbQ35143awyahfW8GcyXNwqgntk817brsYg03TdAtGCeY4kvSoyFRRgZr05QjCJwpucl2MfTdEv9e1fRPDulRT3upeKr GO3tuMsXcKoz7kj866vR7zWfAPxQmtdXtZdN1nwF4qa11HTmYgr9nkwyH8FkHvXof7PXlw/FPw14nmT91pOvWj2gZc7UgkDDH4j9K9y/4KSfDgfDv9r3X9csbcQ6D8WtDsvEGjMibVeSWMedjt99ZD NfJ5pjlicZLCNauLl9zSa 7U9TC0FKlOfWNvT tj4q/aG8NReFPitrj2SbdN1S5S/02RehguBuBHqM7q9x/Y48daV4P OXgqHxJeRWPg3x8t14V8bXNw4WKPTNXiNu8rnsIZHim54zEPSuY Otp/wkXw3 GfjRcyXNnaTaNq1zknLW53Q5/wCAGvnfQZzJAIySSYz5QxzvXkfyrmpt1sFCXVaP1Wn/AATSvze251o3qez/AB58E6n4H8beIvDGq2klpqnh7WLmy1CCdNrJNFIVYEfVTXk9r5dzYQSSLmS2Z4iy9RkZU/mp/Ov0N/bE0keP/B/wW/aNspFuR8bPhtb3PiqePJx4m06R7LVQx/vyS2ouPpcA96/OjSi6yXlspIYwF4f99Dkfyr9AzSUc0yeliEtWtfXZr77nlQhLD4txXwy1Xz1PZtXX/hI/A9vfKC9xBAu4xnkOmFf9MGvWv2R/2nPEfwd8YWNmdQuRo0lyq3tpJMdhXPQivJ/h9cR3emeINHd3KFFubUMMkrIuGA/HFeO I7GbQdftrmP5FuWEkbA4yQcHn8K/NcRgcLj8LPD1Fp0PUUpxkpxdmj 5bwXoXwe/aA G2n LItM0q9lm0wGSdFCyK 3lGx/XNfj1 0J4b8BaB4s1XTNB02CUQTMpEZBK4PIJHWq//BPD48 IrPwjrHg7TZZbifUdGc2ryPuS32Ll5Tk4GFB/SvkT9oL412WieJdbW3mae6 1yebK0 S7kklifqa EybCZhRxFSg22o6L9D6CeNWJwClPSV7PY8A1DUNY1w3epSHfPHGRcCS4 Zh6xhyTxngDjjit/wAOaVaaVBGslxrGk6vqCqZ11q3VbZkO1kfepJx1OCpzxXynpHx0voFK6vosF0soAEljJ5RAHU4II/lXq2l/HTwXqOmNpeoJd2PmxkSXF7B5j4OOBIp4wB6V pUsxxVGNpw a1PBjGin7r1Pq/QNZ0TRdHMOkX8RvF aPVL9sTQS/wDPRdsnrkgEAZ65r2T4QePvDmmatqGo/ES41bWtOhtrg20nhS2U39xqDxN9nAZjsVfM2l2Y5CBtoJIr8/tHfQ9Ru0m8N JrG8Cx5Nk7gseenPJP516b4fnv7XVoppGjtLNHD3McOI4zGOSAgI3EgYwOTXVSx1GTvzfp Zs1K2kbt/d8j9ANW NvhjVfD2m GrWcw6fpV1Le67dXcUdpqUkpPlpZw3Z3bvky3yqeZCcfLmqnhnxj8GPC/h HVH H2t6trdpNK/i7WtX197eKWWVw1tBbhY12bVR85Zi2c4ULz8gp48vhfrfmPw5E0f8Ax5WT6PGFXPG6MbSN/A5bJ/Cql94uvov JfbzXVrp0bb38P3Z8 2adl2vMcgqJCC3IX5QcDArupYhOO71MZc8NYvX5XPr7V/i1da9fa/rzaRZ bc3cZiNrqUkkzrhFht7f5nTy0VEVVcsRgE9Ki1rwP4Y Jr2 p JtYuND1Kz0D/TIbbS4Ik 3K7LEitEQm0rsLOw3Fg3BOCfmfRPEHhuxhtU1PR5pQ6bmvPD sSAWUWf9ZKzllZz2XAA pArq/PV7mG40LVYdOhtbaSbTk8RWC2fl264KyyHhZJHLfLu9AP4q6HUcp3tfzZjFQS1b/r8DvPFnwY1DwxJqeiprC6wdN1WOOdLHVgRcXJjyBGyAiVUwwJ4Hy9RkV51d E9HsyzKmuG/ik/0jTGVWeVio3FMLgEHOc9qojVbFNXNpYePVu9QjRALiYTYtoyAXO0LtdzlgeexPoa hvB3i3VbayP9p EvBl/cCxK6FqmtMqQW8L4Zrq4QHMjsuflypAJJJIweadJSldv5WNqdTlXvbnzxF4V8D6omoIkOs6TqdlbkteLYx4abbnacNkKO75rz6xtPMNxapeRQm3jLySWChWdQcck5Lfn1r6Il8I6p4lSPxLcjRrWy1ITfZrjT9KGnxpbR8llTgszscKrFuMVmHwPZXWs2VtpOpW qeINRsonvfDVvaKJkmmYLDCGRjvkKlCVxwSwxkZrCrRnKPu6v1KjOPPZu3y/4B5C mTTrPqOjwWt3bWti0r29zLHJNgna0zIAq8sVwvJya5m0sbjUI4kl2SONzPDKilXUA4AyODxpuppiesXpXd6vpNxpeovbaxZ6jompxSzeXtudkShBkIJMDe7YwEGTyPWtW78P6tJoj6vPregyG3uI4bbQ3Znu7mZxvRPLRdpAH8WNoPVq56lDEThqvv/AMyvaUoa30 48ku/D12sEV5cQS6fKYd9hAs C4YkZHGQBz1YVzF3FPZyQypIwui5RpkUt35G4nnJ75Ne0anpusactxrmsaTOVhYPeBQogjkcFVyEOME5ICnBx FeWeJLyyWztjBperCSRRJJrFztkjZccCNF5TnHX1rzqmHr2ty6/l8zf2lKL5kzK1/xp4htjHYf8JLq0FrDhZrG2vhI0gODvwG2jHTC1U0XXprS5czWd7qqTyqLa5hBml3McqGAGdxzXPDUod0zQW0c0KAGQsmJE6YDAcnnknJ4/KrBvrG7uvMmWQKEIY6YAiNI38Xy9ACOBx FcUsDWlHllDT u3 Zsq8efnU9f601PaITJctcWxgnhuYS4a0kQrLFg/NvTqpyccjvim3elNf2dw91asCiKIpZZVf94em1sZ6enH6V53B53MkGoXL2nkeRJbIzyyTRl922QlvulgCeg4zjNdDYzXC28McEl1pojujHMiXe8SRjkBlCkeoABzxzinSofVYXjLZ lv6 Y5NV6iTXQi1WLUtJtYL3SEFsYoyihNQfMcRPICMxUAkk/LipLfRxqW3XLCwfWLOOzSbUYNOXCwgHbL5rLgqWYj73XPpjPQ6vqtpDqBt59S0zULcy7ItPs4TFIUHGXTA2EE56dM8nrU40rSM2l34WudRt9ea4lj1HRNKEkUiqAmDuCskhLyDA5PHOMivUw Lqcqbeq/H1vb70cc6EFV5Vt/Xr9x5DaX o6S1xHbRLbQSyA3aXNxshlZX3DcoI34OMY7 tdEL6NIJRdQRC4cIXltLjzdzuM5GDtGAc4IXGOueve KdEsb/AEg22lXOqs9zbQzas0liLVBqGWCmRt5G0qWw4xls8c14Utnq g3kF3dLdqsbB4b1UEo25IDfKSDyO R1zXo0qlHFK7VpL8TCVGrRaV9O56KuqWahrS8t1Sa5uQY7dUYxKCATtcsTwAc845rUGv6Vo91Yz2 lfZY51Pm3EVo0Mc8OcFvMVsN HpyetYya5ouqu8l7LaYthibym2yT8fM64XaSxxkEAEDqCa1YbG5jtov7AtZdQtLk7YTLeBZizkgARIGUHI9T1HTisZwpKfv6X37DhzNe7q/xPQrd9Fjt7U3Gr3FhHdEkXUduGg27cgFkdueTkAA9OtbMGitrekXs9hc6drtraKpFu14Y7hGbgOIWAkZM8EhSB69K8EL/AGW4a21iDfcxIYjatMLeRHAxjHKkdevPuK3NMupzNaW9vf3FuUlZhBazeXLAxc48ts/eCqDvXIGQK5Z5fGndx/4BpCvKWmh2lhYGK6kuPLhjs442iuzf3aFUycBSSwODnPYD36Vk6jHBJba5Y6dfyW1pZSQynTQhhlP 0gBKOBkHKsrMOcYzi3faprUEVwuox2Osi8QSPDeARylycmRpQ3zqM8btzHFY9nq/hcpDPDYatba/HODf2l2IxbFBn5Ap5A6cAjPPWtKMpw3RM1d6u1tR6eItbWaytw323VEtx5OsXdst3cQFhjEfmAsuATyMj 7g81m TcXcomTdaC0dYtUnhQTJJJklTIASAxAOMg9D1rrG8TTNo0nh6C20zS4VhBGrf2Ik89wu7OXnLF4VH91No6jBzXl17qV3BKsuo3LzTByI9QkiKBQMgbZRg/QkEdRXpwXPqjjqNJtanZadJf2sNxCC8BuLjcsJkID45DeWwOT6ccegrNn8RfZr2LSpImv5rWYm6E0ezGQCRuOQxH4fj2o6fqH2u4t9QvZtP2QMog/tN2HmsCvHmI2cZ5O4qozXplg/huHS7rWG0aK4ujqBiltb 7e40 GTblWN1GxlYMQcIAoxj7w4DbjzWZhHla8jpbHQrWyg0 5udMutFZ4xNBHfad9tiu2YAKsasVjAzjhm/wB7dnbVtriRpbzWPEN3e2WvrBL9us/FcQm384jFjFEFAXByOY41HAU4GeZ1b4i KPEl5rd75usalrmv63JPrWotqvn21xMeeIlVVxgkZdeFwMACsfRbXWzeNq patp0P2Vk e7BvZWl4KLCD8x7jJKoACM9q0cmlbsEE6kr7fMSVbjUTHbaNpwsUnlXz7pybpdynlpWYDaN2csSAvt39qtx4W0XRYNA8PXOm OvGF/cxpb3WjWTXOmwTYDuixyKPPfO0Fs Xw21ZM7hxVx4/S7i1XQrrRrrSdP1OZZfEmtbuttstuffzf30iLlfNiby0ZBIpYIW2x4DbXZATw0fiiDToIrbw3FLZ/aknc6tp8xt78k5DeZMo3MCpYEKEUhsEMOaFytaGiUovT v6 87zxZp0mqxalDfPap4kCRJK2lbbeApEm7YVXiXbj5UTgYyMmvJ59XkNtBHfXV8G02QR77y5ZBCxPI2dV6dTVi/v9W1VYriNLm/a2mjS0lv58TeaD83lle7E4yQR0H0r3er6rfI1jckW17ZgNbw3VhHFOcDna2ApGc9SAcfnCVxczcbljXbLS0sIf7Qht9Xv5pRLGY3YsF7fODhjjnAzzUGl J3ukOl3VjcLbNIA8slu32o4yMEsxR1xg8gN8oAZelZ2jTx6S dbmvtI8/zFTUoIvPDvjC70J2uuTyynI5wGrc1TRrSEQ3S3tpdWN9tC30sk00JkYAj9yCspooge7DnkZFTZN6DfwK/4Hev4c0Ow0CGB/E322SebaDO2xoGJJUE7h5bAMCQcoCfvGp9d8MWGkaLp1joni z1K4N2 dLuoHWGMsTkwy429QMuhC56Z7eOR3HiG1mXTr 1gFsoIM0Vijy4YAb1yDnAAx0NbUceqPPHHEftkEAPzvb U4aMZPyKu0soxnIzzzUyk9hq6V11OmmS5j 2wuwi1AssOb2MhiD0cSsgWReRjPNc81tJa3Rs9SV5ZHlH2W9t5/kUDgFJHOY vRuB24q5a L78SJpGsRQ29mXVprO6jEe1 f9XLs3L1zgY3EDrxieaG0v2e70WadnZQzx6jdsrxA53KsgOHUnjDflk4pK1tNQXKt hl30NpcahfW0V7ealbxruX7SqfaMEDhmQnd3 YCt3wj4e0OXUNt263DSg/ZLS/mEaKQcrh8jeRg8cZ6dTXM/wBmTW91dRXen3A1CCciXTmhYKm3Gc5ZSvIbkcccirNv4n1SwtlezvFtV0 d5LS4t7KBykrcDaxBL4GeM5744qOZbrcu6UfM9SvvAtpq1xdXFh4b0S4t3ky7afHImw8kNguRuODxgfWuUtR/wilzLqVto9kYZ7kRMrXckJUqQTtKYbOdvBOORnIqvZ OvEEe7zdVur2a5ABee6klCyjOADn5up V8kdq1DJY6vbKbu9WyvJ7gskUlwQvnE9UdtowehUnI4Ge1UoxbG53jbY7RPE0 rC8il1h7UXKJ5i2lzLEXOMEtjI3KoznpxznoeK1GWxVpLSUx300bkT6vNGNuxTw/Eg3PnjcFJ45HeudvNOghuJoNJvLieV5ESGFBsJkLZZfl3EAgj5enrgc1KZJyiC60KeGe6lMc8lk2wKMZDtGMZzg4ZDx707aWZKcrf5Gpperafod3HqdhZnVZMbIL67v59ikAHIMZjJIyRhmzzjJru0l0zxPZQXl1ounpqsc8dsl9byNFbTSEEjegBMTgE/MPlO08DqfNbnxRppuIoLuCayhgRhLexz7mJUY2uruclvVcHrwa4661Se6kSWGGa3jVkaO/S4DOxIJUgdCB BHqKauSndbnpXiDR5dH8uyvNMMMjGNobuG5acEOTuLt5fOOew5B tUE1Oy0gTLYQWU8KxgXF3JcSjex7EFUPUDnse9UbLxxealL/Znicy IQ9v5cWoxTMZoAn3chRkqvpzjPA7HaFrZSZawt5tQtlRWnuNThkDPIQBkDcQPpz0P3elKbV7o0bjK2ljdsLyO2e31jw8893AluIL/SNR1LZOjsvKNtxvQkHacenesuTU7Ce 2TXM1vMsYEcOqW6lraVgdmQCvAYcOO33h2FbUdQv/D0juvmvY3VsrxR28CSRMehjk5LIvqu4nByMgmpUttL8VXt3qulxf2fqVlbg3vh6xkdjIqD/AFtsTkuuOqE5HU7gCQWW99SfelJdDubOz0LVJDNd6hbPd/2VKmn dM0UaS4GW2M4AGWJyDggmuD8QRNoslvCl1e6k1pJIoa1ZhbxTAfvUVlzvRlwRtPPbdisJPEeoWcumoQO qWkINsr3dwPPSEklgFwSFJJ9wemcnLrGzt/FYvJl0u3sruExtDAt1JmUepDA8nrkEDAPWp12G7clrnV6LeWsdlb3 o3V2sNpfFYbkQMpZuP3TSNtzGcj5s5HOT0NbE954m0yDzo9PkttOnlH2eG5j3wPyQGV93zDk/OG74OeDWK9l4nsdHh22a3 hSyMjWsV9FIhwwBMijGHU4 YjHA5qSy1jxLp2n3OkQWuumzmlP9pWtjchV8rg7XUqfmBKn5uOhx0qIzlFltSttex2OpRW9y y3ZoJYkQR/aZVM6hhzuIwWXcGwwI4HNU7TQi08h x2szW9uXvYrOYIxjXBd0WRwzYHJCnpk8jkY2pR3Vrcw26aXcRsbbfDa3V2k0h3n5W3ogA455x3 hoWc5iniLTLZy2biS2lE/wB1s9mA49fbHbpVKp7xnZt9j1rw/wCIPsDtZ22sPp5YrP5OnXckcUh9PvY6Hp1OT3Fdlb3Gh6vqNzPq93aJdXULR2UFkjNEJmTCI8RO0jdgk/L1J968Z04WFzN50WoR2lyJhJ5UYZUncY2mMLkKxyOAME mMV2kdzrGn2YmvltFkZwLWSXTlSVwckF8rknB4c/1q3NSVgjHld p6QltFoyD7RcSRfYgXubKWxeSOd8YDoRwcE8OO/0zU0NvDPaqsEt0Ptu/7Ks8v73II/dyAd/m4BP5cV59afEy nsF0/UZ5rq4tpAumzXloCLdEYnBQ/Ln8vfiuxl8XNdapZX1pbrp2qm1EuvQrqi2cKhsgNCEA8s4I4VupOMU/dtqHNez6mjZWOvu pW87m2jJQC5urtN0PIWNfMP3UOCchhj1qlrdhrVpBJZa/YXtmkwQR/2jp5Qy7cmOVGYfMvLfdyGzwcVp6j43vNZtrC3tbzT7ZdMT/QpdNs0t5mwD8ks6KHkIzjJYtz1ziuQlv7q8ljbUITLdzIg0  vbiRlwuAFyzKcDqCTjjHFQprbYtvmSK1u1zCsml6zZyPI8Z y3CFVilT 6D1xjH06Gr0WsGwhntFsL3 zpxGFAXzFhdeepGAMgc9eT1BNdMl7BNAdO8QPa5LbEtBYjch/vrg4XqckNk8deCKn9m3Gj3ctvcWexkvlWOLUmCs6tkxhgTvB24 cAehPTJezKlytadDEf7Os1repHcW86YP2i1ucMr4PI2j5cHvzXPTQx3LXMNhGZM3G55pJAHZgTghTH eSc8fWujvRPcC6lsUkt4x8/wBlYIIIsMckkknGT1A/nWZfWr2ixT3VxaeWpBe4tDvaNvXeBxzwO5FVZ9RJ30MN9EMsc 2IWM0MavFZy6iAoUHnajABeQepxk1lXtjFCkUw0yyeEN 8urYM7bc/MwRjtLKQBkYHFejf2xod9HbpqsDyzW07xi6MRkdV2ZSTCkrtJ/CuZvllVr2Swhubmycgw3MVrFHHkHDDJOQGyT07Ck7p7CbSkcdcwWUAEUkMhMigWbxjcWj567eMEj86saRE1xbXhmj1PyYXB0 50x44kVh1BG07ivccHHetJdWtb2WG3MK2k024RmK2Qtnsiu33Ae MDoO axLeyFhDJBcQX9zb/aH8l7apen 15Mx4YMMALyQM4z0Naxi4q3UjrodtKmdI2CyaRJtu 6u5TKtu 4AhhtJK9Dn3NZuowPIlvbxalIZHUrJY6K8VsvmIAA4kkjbcpHOOMc9K5izdrPzre5iulhlLACCcCNSB8pBJ5wR/k1JI2p6LNceXdW1obq1jWVIvJdGV2HKPsO35gM9DjI9aI/Fa4LmmrLWxueIvB t6Ai2FzaXra5emMzaLeFpZRkZ8zCJheqkZOTkY6HHnUVxBHrN/p0WqSW0Kp /mvNKd40wjLMDCd 4jJwcZU88Gu9u9Y13UNK wQSbobLEVwmmXEkq W43eWFjIjUkguBgnrmvENYsLuG SW2kaXCmVZlYtK4H3lZuCGxnIBx1q0rqxFSzd1 Z6Fp1lNqOkyQfZ9Flksot4vE1ZYyYsdMmbHIxkKM5rno7y5tr42ukadpsqp5co1FYN5KLnco3kgr8 MAc4Brm7LUp1haA3UkcFg5Nos9v5gKuRvVVO4fgxxVu7uVaJ1a0uII7iZWhn81gIwM7giKQADkHO3PAxx1hb2Y a1PRnX H28Valq0mnWc2rW0ztv00WN4YQJFPDKFXqGGRjGCPauf1 bU9a1RB4o1DV77VLciBrzVdWacjZ8qplgxAAAAGeAKbbS2Eqjy9V1e4uxL/AKHFPCEUE4BwxLDjOaq6hp8NxN9nTy7h5dzTXk7lPKlyflOQobnqeeDSkuUIpW8yrHO1neNDZyXE8drOR9pVGRWHbrg8jsa9Ot9FbU7FZLO1uJbldMae1Fpeeduj43RsFyVxnuwwcAjOK8qsJLnToWM5t1LzELNHNwpU8H 7nB9D2rUtNYuYJFnVL9Wtiskc7REjcCMYkUrgY9KG2o6DT5dDft3S4jFpqCJ/o6zeRby3YtZZARwqvhgRkcD736Y0fornicatesf G447NdRjsor8Rywt5TCbbjdvHOcZIDbMj1rlJ9T03WNTZ77FpBMdt7Kjee4J5RgpH94885/lVu1uY9Lkms7hUu7aeImArY YT2zlSrqcDOMgDnrScW3cuPvO/Y5q tA8v2vRYVhvFugUuYJfLJXpja3f/gQ gqK8v8AxOiy6Zqmv6vd2dm58nTdR1R0 zsR95IzkAc9uOldBbfaLYvbi1LQGRJosOc4YAEBT1z3X39K14bHT9S0y6hs7VtR1hJmmjW0tWYCBFJkO0E42qpPpjPTFZtRm7Dabexw mzXAhJurd5kmkIijjtlaSTA4YOByOvWtTw74a1C/wDEej6joyQaeZNSiRX1PxFa2z72IXrKyhByeSMDvXrPwxudHfXPDlxd/DzStUuNMvraeS/t9SuLeOWOBg8gkU7lBZFZThDjOcHGD9V P/hPP8QIvEcPhf4F6pol7Lrj30C6VeXtxDb YXItkRrJNoCYOSwB2MQPR8jua04RqJ66/wBdjzLS/h/pTWE0/iLx18N9Lj093N9Z3PjJbq6eXLDaIbbzDnKkdFGACcZFejWlh zd4duYpb74ra1qcr6VDsuPCPwvnngkdwS8b/bJbcgoQo3BWB3HGcc Y JfhZ45 HXhvTrXxJ8L9d0F/F9gNR0fV77TL6ef7AxKBolYpF5ZaJ/n2sSQw3ccMt/hd4p1bw5pWr TY2FhqKzR2d9rXiix0 2ZoU3PGkc20qRtPVjvJ2gZ69MXOL0/Gw5uSdmkn81 b/Q938MfFP8AZr8JXOjz2vwX JXj28mWQTT6t45sdJhmlY7VaOMWE6hMF8hmzyCCuOV8WfErRtK8Oy6tofwP E2h/wDCM OD5tp4v J9xrN7d4zIsT2MN9GGttrKrSRRKGK/K3UV414I8F6BeWmp3niTWPClqnhC/sxcC28UXNzDeea P3ZsoZ0KxgZf5lbBGzJyK4/4mX2iQeKodO8JHQ9Y05ZN9xeadZ3EaTbWOPKW6RJBkY 8Mn9A71ua/X1BVXGm03 X5qx6hcftB/Efxfq2rXvhvQ/hn4Rtr1IvPTw34Bsbe1hZCPLFvLdo0kXONxDgt3zzWf4n8cfFLx7fQXPxN8a6rrBivmXyINUtIoV6bvKhjaNQCoAyo2n1rxaSXx/8O7mO41jwxrWj2uvwGbT7HU1ubVLqAr8kgHmpuUbgwI4PHBqQ/EKyubq1gXwZqVvLFYNDdahp/jy6VrifyiPNdZA6g79rlQACAVGM5GNW71k9SaU6bbUm7rq7v/M9wuPhvbzWqLouneJgl8olSC8jjuDK eGCmQ4BPTJP45roE DHxLT4b JdT/4RO91Dw34bvbeXxNrEWiwF7CSUFYlmkV1cq2AcKCMjmvA76z1NPB0/jH 0/HELJfJCbtNCijsQ AWRLgTZ34YdVyQQa5CfxCdR0yS ubrVdQnlu0WKTWPETTXRbBySxTI nNKPI4K6TQ4T9nUTkrr7v0Pbr/w3L4QMb N9E1OxOqaBDPoVrDKXgu0kPyvJKLo Ucc4OTkcqK4TUNQtLizs7PRPDVxZ3HmsJ9QvZmu3dlJ35hYvGFOfTPvWHAb S4RINEkWGGybY0uZoiCpxgmP7xPfA tS HvH qeEh4Zvz4S8O6la2U8qW82p GbW4D7gQxl860dWxkYJDEdjWspoogermc6nNstPl/wDDlltDcTXz/YIES54jOm7Yt6gfc25dQeeAQPpXHvcG0v76aOOxv0vV5tphv2Bj0UNlh JFew Ib3xF4nv/7UbwnoNqNf1LEFzY6NFplq235QFWKCJAxPcdTjpWFfnQ7NYodV0K00a/sm8u Wwme5 04ckuS5lUvtwAFKj6GpnCV9Oo1bkur2PO7q70eGVY7iwRiuVla6L3I9lAAwOwxmpdH G2n NY77U7rSNLeQR VYac00UU05Y7f3af6xsZ/hB4 ld9NaeHdRkuLjWYwcWTNZhZTp5ducKFRJAWGSQWKqcAEjNcXpV5DZeKbCLWNHuNR8O akkOk38ptfOBGB  QPxz6OB6dqIfBdEPmizivEXwd1nwRp0 o6Lp2paRqNvOFuNMuR51tIrAEBcrlSQe/bFcdo/iTT9Yc6XdW7aV4kgh5t528tCARgq2MEZJ9K 49f8SaBpvhS6 w6T4lW01eRL2HSZPFElxa2 x2ijjaFYYoy4AchwmdrDGMkV8 eNfBPh/xbJpTeHRNdXdpbs08MMC299A3Vm3j/AFkY/MDkgVFalCMUzRJTfuvVHnZtb25nnuUsUeWAbpVtVx8ijnI989q5e98NaZPKb2OPUlkmj S1WAShZOp57da9Ant9a0aKa01BZX1OxI33CSsfOQjGMdwK8e8ReIr 11KGKFpF2QbpY4mwoLHoVHX8aKMpQd1uZVIpq8jrrHwroun2Bvb/AEa6u3Evllrk7FJ7Y28E1f1C2urcr5yGPwxZQGSMQsAu32GeuR61xulapearex2jxzrK WAil8tQRycr34pfiy09t4ZjBhS0SQIhWBvmbHOcjpV1q8pS5WtWTSgmrxZ85 P9Zj1rUby9 zx27zS XbiSQAJHnCnH0HNeNa3cQz3zpbT3E1rAgjga6k3MAoAOPbOcV0Gq3zTyTC5Z3EcbFGL9T2579axLHSReQTTETlLbJlngjLqhPTdWmHqUsNHml6E1IzrTtE3fA9kLnWY5QqKlovys7AYYjGT9Bk12V3M11dahcRLuaU RAC 449QfoPyrE0W3fTdOFzDcbZmgcll4LlzgZ9goNd18KvCd34x8ZaPom8tbrcmbUeSQqY3SZ/DA previKUIOpL4Ur/AHHLGk4S5er/ADPX/hjpD6Bqfh KZNr3JR2O0chhkfLX66/8FWfg1P4o/Yo/Zc/absrKWS48C6hpug JLsR5Jtb/AE9ZINxA6CSxuOv/AD0r87hZxT PLe1gs8vDKqW6bumOBjH4V/ZR8W/2OLj4pf8ABD740 DJtN 0 JPDvwf03xBpcbQlnTUNLt47ogH 8IvtK/8AAjX5TXzGK4nwlWWim7P/AAy0/U mybDupi3Q195NfPp J/Cx4ejbxV8GPiD4XIWS50aKHV9MQgFi8B2zEH/cCV8jaRM1tdldoBikDKCfxr6n/Z/1TyPEmnaVe/Nb61DPpt9HIfvCaNosN/wMJXzV4m0uTw54s1bSJV2PY6lPAwK8/I5H64r6jD03Sq1aL3Tv j/I4aiboqTvdaa/16n6W/CjUIfiL w58V/h1Oizar8B/iza JtEQ5Mh0fXrdLS8Ck9I47iw084/vXOe9fmxMBY6yGIKrDdYYDjjOCK 4P2DNftp/jW/wu1ORf7F/aB8A6t4MvIZTlW1O4i8zSDz0I1KDTh9MjvXyB8QNHn0fxJq n3KPDcWV9LHPHICCrqxBGPUEGvteHZfWcnq0G9Yu69Jf8FP7zzMVH4Zdnb9V Zt B9QTS/EtrFIAI5ZpbOdZG4COPkPP1FbfxK0VLvw7JfRLi40LVSJc45hk5/Q15hHMwuoLhSyNc2SSRMf e0J/wDrV9EWYh16KW1mIa28U6CcNjIE4HHXvmvkMWpYbF839aHXSte0nofXn7BXjO08I E/ip4uvZokh0vwZLBD5r4Pmy8Db74Br80fih4vl8SeLNZ1DzGaO4v5TEN Btya9r GPiG70b4R/GnQ1cxXFm1hJIm7nYJWRv8A0IV8lXkiySySHl3Yk 3 NeblmCVLHV6r3lJfckv8zoq1W8JCn2bKpdCuGJHPAx1NBZdjYAPTtjj60xlPOcfKOMHNB3fId2MEfT9K9e2hy6Xt0FSSaJ/MieSNxyrqxWvR9F K3jfRPLji1iS8ghUKltqA85QB2GeR dcLAsbQuzHJH3h3qo6EscYK7jgVEuWpozRNxV4n05ofxji1LUNPi13TIoZbggLcWc3ybs90 vHWvfdMePWbUyaNfOJraQtcw Vztbknnt dfnKjyxyo1ujtIhDAxnoQeDX0v4K Lth4PubLUrp3nlktAl7p8OC5YdP8 9eNmVfNcDyywq5r9P62PuOGcJwzmeV4hY6r7OtCzi7/ABLqrNatdLan0VI2pWm2 sJwgtnXbc2jAtuznIXoevfIrrJPGWpzTLfXcml393ej/TX1TS402sOBIqLhSQCeSODgjpXxZ4n InjbxJe3OpeFtKvdCsCzSwSRs2QB1OehFet/s/8AjOfx/c3uh JZRc6hYqJILlol3MpOMsOhwa74ZliqeGVSrBab2d2vU8D z4YjFOFN3T2ck1e3qfZugeMfg/Y6XbxQeBdQGu2UaLpmpaneNc28s4H7yd8YYlhkgFSBuwOnMn9v6RrJnsrrRLwaDIRM8Wj63mJpt3ytMJA3lKckY 8Tjr0rjL/4cX6SC50 5ErGPAJba6gdNoPA/CuH1jw94i09t8kS3ESyACOZ2AXHTBXHvz61vh Isspoogee7O77NmdfK8TQvzQf3f5aHqV5Jba Lq/17xRHoVhaLINA0O4vpZ5dqA4d0IGwHgKrBc4z7Vy/hjX5rSbUIPDlvqd3fQCOOw1d3nge0i3lpJ1CkAyPkYB 6vbPI41b3U1KtqF3NPJA/8AoUN3b aAQMAAnJJ5OODWwniPU9GgtbaHU9Xitp7hp7gwXRdiXB3A8ZVh2OTgdMV6dLM6Emle/wDXc8 eEqJN/wBfPc9e0nx1r m6FJL4n8IX1v4Ktb82t3rlk8gkiaRCGgVjIQZ3XkqGPA5GDXNa2T8RPEOi3kEUNnY3ESjTtViZoxFFD8uJHduMAhWK8k4C9hXmEOlrq9tbol0G0e0n3PEl9kRluGOzby55y2dxAAFfSVn8QfCuh2a FPhrpNrJBHoxXUtX8UWL2t7d3aozSXBtwxWKJAQkaCRicbiAWYD0ITpShdPU5/ZOEk2tO3f8jnJtP1Hw/wDY7PS9X8JeJZ7uLz7qxt7lftkDJuQrJI5aNVYcgfMSGAJzwPC/EcuvpqQ0 /h/sy2s7lmm8qzMTpK3zFpGwWO3rxzjGMV9MeHNIsraaz1HxZrLQ6c1o9zNbak0Q1LhMo8cciHJJI2kE44yBya5DWz4Z1aDWLXw/wCCr7Vte1pJJz4iOoy3c8MgQOE2/IglO0hmCuOT36ZTUbX3/r5GqmoX/JXPkzWL200fUZZ9Culm0 0bK3UyNBLd7yfnEW4OBhT8wHAODzitCxtpdYtGuLXTVjttMty qTQqXG9mwGG0bj/Dwx4Oc1tXFx4RuIr5PEGyLTLMb8TXAivrqTYQYomEb4GefmwAD1Jrp/Dfh7xL4wtV1nwUutaP8JdJvnttI17WZVgR7gqGa1kuEjWLzNod8uVBVScmuJ0HOV7WNKdSLjvf vwOM0yCe3e3ur6G 35VYy9sq7dowodcccYyRz713MWpPY2bLJbaS8i2xG2cP5qpuDNIg6Zbpzu79ODXnK3UVzqt80uvzagmmXQ8m9W6eYyPkqerfMny8tnJBABrurLXY/3qI5kW5ZVWQWxVU3E7Oo3FguSeoAOOTzSlhas4apMUK9NdWiaxvYryGTdo1paXBRQt2VZo3aRhukf5cldvGMnkcdhWnplxaaHqVrONLW bTHMixmNrRXkYncCqHftXAwcg8cgZqlpF7pyreXk9uG/flDEIgJIArfwrtCsyr83JHQcCpLgruOq2sTT2yYzLcxiW3YdfLDfeDkhs/L2PODzhWw9RJq1k/wCvU6KdbVNO9jvvEuteGoZLiDS9IFrfyLHcyeINE1SSdJrjLNIsSzR/LGy7TslEhyrMGUMQeC1HWdQuLJJ9BvPsV LRra5iFiiJPE/3wWQhsk9c8EY4qPV9bvJbvUNPsIrS6vXkgEQ02yhtTDCemxQoLZJQZHJ71naVbvp2q2F7JbXGLT5tVlYkgJgAkpt6545yOM5FTRwbhHe/4/mKpilKpfa/lb8i3qPhaLxDI99fytBf3untcTS3NmgtridUICwLGBtUtwST1X1zVC21F/DrRPG8F5rFiyLp1xPPFPZxYXa4Nu8bCQem444HBrWfornicatesNbyatDDNp0emynelw2J2BJwwj6EYHOePXrS2 m6fqgmine7SRoxKkstsh8/K5AHVgSCMDbgeuK2p1JqnaorLsZz5dOTfe/9f5HnZuIpCsk lrEzZEsttMwt5FPRjG38XB6YzntgV0GnR6RqLrFbal9geC3V5ntlaACRTkkgk7yCeo5wO1dDLpsl3MNHis5r 9dTJLb6TI8/krCoyzqQoChRn5d33TjHbUt7UxW10bGw0 6kt2iFyjvvgJPJUHKkAMVU5BOejEcV1yqxjC60/rzOeMFUld6mJqWo6/dS3d8b2fWZQI/M 1zj7WqKVUccB1JPGRjJHJbrzAlsNQ1ANqL3dvNEBuWRQsmWHAUHg5Jzzjgc16FfQajp8bXOs G7NZ/tAcTRb5hCqkg8BQNucZYnI6 9YGqxWVzLBFFd6PcWsF4VhiL4P7xATiTlwg4xuBBJ6msk4T1a37Gkqfs15eZFaeIXsI44JoZLmMEAzmNoZHRQd0fmjpweM8EjpSQ6vaPHNbXulXySszfYdTEsU0RkxwHEiMNoJY4yMZzViK6heG2XTYLjUmurdo7XTJUXy1IUkeZKVy3zFuACcY Y9KwrWaw1KGbSrhr 1nNtI9lbWMiTQMSfl80HouMgnPy46GhU50ndLT uhDkp6NkD Cb2G1stQsVt9YubrTXuptP0mOZbu0ZCSw2mMbsKNxKB0x3HOMK0uTAxNxPcswP7/yZXjzjOEIHykj3XrXQ3tjdC2t5Vso1aAiR5I3DOABnazDlRhc gFaL6tYPbC21WzXVL5iHtNXS5U3CMFJKuVAMiHPVySNvFdEaiqnPOny62L meJodP0 O1sdM0aRb0g3F9qKZvlI 8IguEVSGAyQWHZhV95b 0dY75bxWNwTafaBvljj7YIyR/vcntgV51ZMdGlhkuL2DW4nhKx2du0kcLE8OHAQEYBHIU5wea1kuLOGKCW3e 0GZrbfdxuu6PdvxhSBuAIIwOvHfNatyRnG/Mm0erWcNkJZNPuJNS1LQJYgbiOKXyUdMA V5jqGBDdRz0yM9abq3grTI9OeHSo00aK8uMxWmqW5LBmBKhWkII4xjknHJ7E8PbSJreqiPS7zU1u4iG0y4 yhgztwFMiP8vPqDj Xd6VbanYxW0uppN4m1WKVrgN5QntFfGT5ko2scEtu24AI61nzN7midnpsbsfhLxB4Z0/TNTlePUrO4jRlFpeCR0kJ QvGwDKQcHqMZUcNXL3uim81OfURaX1pqzKJYLVrN7iK6xjzF8l2yMEMdysRxjHepbjxTqlxqOpahfXvk27FHvobCEQLG2fldYDtwBuIBOcAnaMnNdJdeK7ZorC3S2mTSbOKIrqNlEIb2dGx5jJFIDkEKBubbnABwBgu1mKNS5g6teWWqCxtJ9KjtVgj3Jp2mWzNAwC8SFCfvEljx6ADpVWHQ7VLN72W5k0zTnucWzQztJOx5 Xy GTgHl/lPfBIFdHcz HRazppM rXs oGOSzjt/wDR4rFgr5UqwO9m UBldcc8Hdgc5p2lzXpuVg06/luI5ctKrCRQvLEeWuCSQuQTngH1zQ ZIaspOK/U5y m0nSpo7ay 361ZyKSk9zGkKpI2MHYjuowR32k4HStiySeazuNStZtPhurXYY7J0MiuVA3FYiWPTGTnnsDio9SN4zSW9zpsNrcW6K7W8VssM8eVwNxZQBnI U/ngCubeFLjUEkMn9nZUbLeRwssrrgHBHykHnpj8azTs9QckolmK51/VNRaOKW1tpfnmiZUt4YsRpuK7iAF4XGw/MTxgk86skOuXVrHNqSS6fpDzNuvYYo1gR3XORt5ZuMcA4GR6isF5FjaaSFTbOWzE9qGIHP8a5xzz2798Vp6dHqbW 7UY0vdPWEK9w8/nMncGNiMjgDKt04wRmnyqLbQlN312HxWN/cGFbiexeN NO8uTc0jN90BsnIx6HaM84PFaN5Y6ZprT2t27pdxgCexM5V9xAIOMHcp5PC4x3HFTpnTLBVtdXhubWdybW0gtmG9EYsDKuf3bjrkMWGfTmqFtcwXmZUhFpq0LPKkzW6tIxY8t5jHI4PUgkY6nOaVkynNQ2KJtljuVt3tZrYhDLKhuAqtxldu5ehGODn6jNZl1PZO5uHXLb086O4U/KvUtktjjjBPGOnrW1d3etWYihurWCw88loklidTIx53BlUgEAjkbevQ98u ZI4S5hurm6MG0wSWrCLHckAjHsR NNWQk5OV7FO3vJrEzw2d6EOpkiTazISCRgFuwI7vuHuDyGZaAzCCWW2ADi5lh8xkUdi2BhgT0dOPWqN0ls8FqY4LmF2UyXCq Tg9NiA5AHPIY57gVHa2twbOS2iV7qS6lDLJFaP5ibQceWFIB6jIxn2pW10LSsdNFFJdGK3gkbUZklBlmMUYIXH3gHIMnPfOR6mtUwxf2h9m064tY5pI1ZzDdhoJjgBlJziNx3DHqOe1cDsu0lVYNQuIY3jZbiNS6OgYYJITnac4OPfI9btzpk lWUd3qEkWn2MiNnULoeUsrIASu7OHYeYvTnBGcdKcYyYXcdjqNP8MaYk1/JdSX8V9DIyx2ltb4ZwVbLMuPm2kjO0ZH5GuTTX9S0S6MUD3lwschVoPtWA4YYBQ8hWxjJH4jtW4vir4dN4XnmvfiLpT67psjS6PbBc74lRsxecoDq 4IEVkx8x Zcc N3fj/wZGLhYdXuJmKEOBYnbIx6ng8nHfAP1rohSrtXtp5mUp03K3U hbfWLICW7e/uLuK9BjS2nnww5Hy3GxQcrwyyjjIGQcnFzSVe1l 0RJf2UFvMZFlW4RCiocu3muNr5BOGHB4yK ebLxx4Jk0fULpteh/tO3eIWVje2Mu VSQHUkRlWAA7kHkYJ6Vu GPHVjeakk2lz2l9NEgL20qgNECRu8kFPkHbBUgZOc9aqrgqtON9PvT/Jmaq0pK36f5nu9xpMniXTNT8W6NqdtaX0byJdKjr9luW4GYgCfLcgklGxu5Kn EczZ2ur20tsmqGSFLgsZ2uLdXTquAzFsAkAeg4HGcVy1kLayu1u7PVNOjMl4VfS5MoWUEFSQyhCG3Y4PGD04r1261vw/q/mRStLo0AyZ9PsYdyBhkfISxLKGOTklgc9sVyTjOO6OmDhKFv6 Y59VtLi1ghgiWS70xnEluIY2intx/CU2gOeeuS469gakmk1e3ku9Si1e4tTe20aTQf2k7SIhxtRgW3bcZA78dO1cne6c kxWL3ZvoLMxD7BqNg4kguFLn94rhgBtzgqT27HiulkTwyn2aQ IxJayoQl9I/zxFcArNGu4nBPB796ylF2uPmintoadzqEkqLLJqN68K2yIILi9kmGBwu5sjpgYOKr7LiVBunYwbCZpJ1A2SHoQS2PTnBGKxIDBaCaae5guluQ7JcTW7bU6gAlSARgg4Ix06Gsy3unmiubuEhNMt32h4ZAmGz2Qtkg8/SsoKpfUr3HHY6G2h0q1SN59QWWeW8dJIEtSzpgD5 RtGSccHPfHc jeG9St5MRzSQm2iBwZo5Jg0qg XuDLgMOncDjPFeERTSea/26P90ZFKP5J3KhyABnquR FeneEJ0jhcG9iiJMjJ9qtwFLfwjIGc4x8wGR9K2jzISdj0Owm02W9e61HUUEdy5hS3tGKtbz7Rt85MHKgk5x05I9tGA/8I82q bog1TSzF5aajDcESI4JGUfb/qzycMp68Yrhku7qGaS2ju7WCSRSXN0yggZx84B5GehHI7elXDrk6RHT7kSSWjQpmSNd6ZHdc8so5 X/wCvVqLbE7LRne6LeaPqEMh1GBLW3RPMube2XyzIoAO7PzNk7f4BlfpzVu7TwtqbTDTLrzpjau1vDd3IiQnIIRppWEfAU8bg3TivLVhSa6RrK4hhjjXeZbWdlO9T2Ukcc8j3IrUi1OO5nhtruOxtpJB8zWen7RMuRuHy4 Y 5yM9alP3Q Hqel6f4j0HVIm0m6uzbQJA/wDZcaSLcfZplGNsjACM5YAjDYI6ZORWpP4j0q3zpy2sGrzpDiCznkaK0mZvlUQpDg5B Y/Oq5Hfv5fb6daJc3wtFi0y5gQNcNcxBritish cigaretteBzyGQhuckYye3appbaWzuTdSgXN1bCMy30MTSNArEDzTtyNucYHvgVcYzYr8r8ifVPEcmpywq3nWjQRbJLQPsTYvJCA7sYJPGTnnOe0cOsxzGTTo55xHGFBnngYwpvHKEt6juBwc98V0EV74Z03R9P8Svo9hqlvaXCNq01zciN5UEgBdY94B5OC3OOeRWLc MvhZp5/tK78U/D60Z0kMUN74hBkIC/wDLYREkk4IwXIOeldVPDV5OyX3GM6tCK1kjMGg6sZbhNJkudYtMssTR2ZxIOCQyHnjPGRW/pej Ki0bxwzwxXMQMz3WnzqiKp2qGxgLyMZzt4NeU3P7WnhPw7Z3MGg2lvrt7cM5hOlaQbhFfI2s0jBQCMD7p5HWvnjxr 0t 0B4wS5t7Txj4n0DRbxfLbTLDWXRGiOdqNCr XgZOBgkE8GvpMBwdxFmVPmo4eUl3szgr53lmHdnJX9V/wAE tPFniDw14D0rUNT8dRi2ht5yLcWkoaZ5iMoqxs24o2RyAABgkkdfG9R/a1 HEWozT6Fpfie2gjTdbNPa2aEyt/rAwGflyWwOwHvkfEN/pPiXVFEWpX o37R5LzXbq8jE9Szk7mPuxOOlZ8PgS5mdV2THPZioxgfSvoMN4acUST58NP7rfqedW4my StGsl P6H2reftffDxTfpB4X11IXJFrNE0YLjqC6ljyT2yVHYd68 k/a1sfIe2tdB14W7gCSK918bJQDnlQmAAcEDt6mvniLwBeHA zykbeu8c8fSo28ESozCSyugVXgs/X1x8tdsfDXiG13hZW8/ HMFxLgZL Oj6e8PftX EbO78zX/BOqatp7xND9lj1ti8akcOrDZkqc/KcAgnPrXfW/7Qfwq8UWumWv2l9BltrlvKstahk8u2VywbyysmwZVIicdT3OK KovAEsoDLYXQVj0aYgY/KtNvh5KqxGOzZlYZZhMTgD/gNRLw04jqfDhpJ ppDiLA7OqrH3s1v4M1eZJtN1CNWlhWWCKzkR7YcAkBvMO7J7kAnjgdK2/Dnhmw1aWeOaOTTppAXhe6iV45FUj5PMyMHPquOfxr8 tO0XV9Enhk0 XWbJ7e4EqfZNUKxhwMbihXaTgY5HIr3rw78fPiH4cupp9c0yPxRBJGAkf21LQR56sIY4gjE ny968uv4b8W0E5fV20ux0UuJcslUSc0fX0XhzSZ9Lhsp4vGTX1k4ci10Oyngij3/vCjmeM9AOCMDJxXPX58JW9vKt3oWuanZvHi3vba6 zyQEEA cux COwPrzxXC Gv2jtBmup5Lm41Dwu9xcM0ya9odvPbgs dq5jdFVcnGSRXvvhnxv4C1vxdLYeF/Fui6naa5otrBc/aHsN/24iPzzH5csEaJv80KS4wpG48kj5LFZVmOCk41qbg13TX6fqetSzDBV1dVF8v6/M8VMWnzRP5SRW mmclYrrUGURLwA SuG6jkkGq neGtFkurN7jW47O2mleOcwy2dy4wCVwhuI3bLbc gJPbB9f0rwXeeNvFl94V0jwympapr3mf8I5qd5cRWMPloS29280xqxCsAS7Lk9ScGvOdU8Pax4b1GfTde0e80a9IdVN3aRNMu0gsP3iEjBHGApx0PXPA4vsdCklC6ZymsOtrb2tteAzxxTkyEgDIB4H32XHINNstNt77TjqMOoWtnNBeKJrON5RKi4OHZQueoxkBgCRnqK6TTEaa6u7WSSBpZhumsjpe/zY1YFTG7Y5JGMgjcDzwcDmNZFjpU32qM6zbB9XkadLSMweVgExhPnIK9cjtjg1EYyb0FGTs2dJqek JNPS2v9Z03WbW4NjDNHDrsjuLmzlXKSISqnYQSR2569a5Oe2vb/P8AZmkrNGI/N8yP94IV/wB4HgA49x611Nxq3hi98OW0EOs I01aBZE wXFolxYTIH4MW9la3JBOQFkyRnIzxw7T Tc3R0q5uYJzABJbTqBGM8MB8xAz9FJqZXizTmU9l Zs6ZcXGkJPCJ7qKMyK89qtyFhO0k4znPr7817j8M/Ftjpnia21fRtFvr 6s3kuI7dtJg1eGExsDiMTJsGFxkOrdPTkeHWN1prSTWmpW/2AxyOr3OkXkckJY8fNl/l6 ozWlplhr/hyaw8R G9Y1zSDN5v9natp0U1u5TJVv9ITaSMjHBNR8K2G1zq1z0/xHqt34v8AEOo3upWs2mW0jeYJ9K0EWdujPKzMGigARR8zYAHIUKOldtN4Z GUfhG21Lw1qXxH8Q3VhrES JLy98HPb6JBuiB8tZllc ZuDKN2wsoBwOleeWPxQ Jnh/WrHXbv4gXviCK5jiFymqXE15HK4RliE0NwCJWX5l3EHA6Gu41rX/ihdaLJ45tdJs5dNudYju7/AFFPB1s8Mt3KWb51mtyrAFCCi5jBB4NbRqOWjKuubrf5P9DZ0/x78ONJ8F694StvA15r saldh9F12bXhbRWLBAGb7PFF8z5GcO/Q4PTJ5Tw74k8F GdM8VQav4aXU/EF54dlh0K4m1BFENzM4Zrho3hYMNuVAGw5wcnHNDwl481bTNG8S6bYppVkmsRRfb5Nb8EaU8hJbc/kzywFo88AeWynHXgV6p5 jjxBbT6Pe Kri51TwKlp4in1WTSh50IjiEEUBibZ5SvbqDvJfCspoogemqgoyjq7JGkKje7s15f8A Z7jw4fDN/ai6TSpGv7KO4gg03VoLmJVmXpen 15EbHy3weUbDA9QK6nT/DGiw6LcaxbxXU2ptdGKc RL5dszKSPm8vY27a/G4/dr07xjo/h DwX4S8ZQ LY9Z8WeIUnXxfpGr3p/tBXUkJIcK67SGwGZvMyrHaARWCzeGF8HaHaR6eL3xPLe3P2y4k1G6dVtWjKrGEdgijPJMYOeMntSleSu pnJKE/dPNtQ1e5Xw9NozR6fN5ttGElTRE87JIODJnI6jkcnpWppxt7HQRYXOk6ebnhZJLqGSSQMoAJV1kXH/Asgema9SvdBt9M8P2d/LaeB7nTRJZsmlw Ngbkuwjbctr9pDnGcMduFy2cbcjwq/v47rUzKsE8H2jU5Wt5Vfzo1VpPuAZctjjnrUwiu5L9x6CS6fab7678u0vZjKpieO SL5iMcKRliOOK2dDit9MspHvv7E3GB2igu9GS5AIYZTIjYgn1I7H15mvLXRJJNTt5jqdvLalj5UNqpO/1YM8eFPsGIrMNro9tapeG5a5svIG63kjjXDtyQyhjgAj6/wAqTjePUqno1oTXfigaRa6fIUtraNT5qT6NI8c6MxIC4WSMA5x2FZ03iPW/Gd9/aOv65rWoRRQIsb3t99okEfZAZGZmIC8DPFRxQJePZFI7NQId254PMUc9cFMH8aghsiJEshC5ldp3mlW8ZQzrjCBFcqCeo TueelEb8vn95LS59tzZawS9/0S21Ke3eVEEceq3ACnLDAyFG0 uQQOuV612rx2i6rbL4g/tLwrp0sTrLP4bzc2skiJ8mG8xiFJGGLM5UPkKRweU8M O7iz1Cae80C0uWlngS4u7q3AQgNjbLAFEUi8NzIiOOok7V1aPY6jd6tf2cT6Z9ksgzS2fmkI3OF5d9oIPsMcVTvGOo4qLdnujoPFPw9vtS H2ga1aR F9X0jX9SKxJaeJdPmvkMQAZLmEfvYWOdwMiAN/CCBx8tQm3ttTms0E1o2namVgFlc/PEwbghl6fgPyr6c8MaVqStpmv6JqaW8GgN5mqavp2nBxbo5wWuNqyIuS20FwPfAr0pPht8OfEPhi61nS9U H2t MZ9SSOTw9b6rcQaldFhkzoi2whx22mQMSehxXUpU61Nwlp5mcl5pP8z5mv8AWvD8ktvpPivzrKGOxU2PijRbQXTFn5BuVDKeM87QWHTGa8Z1D4eaTrGq6lqdh458M3Sx3WPKk1pLOSXrgqlwUYg46beO/Ne5fF34d2/hlZ4JZrnS7yecqfD2qwyE/ZycrJFNjDLkEENsI9CDmvn7w5Y6TLfLp9zp17JOIpJBEl2rgoDyQGBIz/WuWnCdJ2bLqTS0R19z8PbbwpcIL3WfDBf7XsuLjSvFltqUWcjBQ27NwcY3ZIOa4v486hptroB0 xvdP1pWJK3NtGwQMOMAMobjHUgV2d5DoC25vvJu9Pt96pb2wkW4UY7OMAg546HrmvmD4zX9rC9rbQbYiobdcIPmkb/a9MdMAUVqcJ1Vd 8FKbjB2Wh4dp gXfi2HVNO0a0l1DxDaRC4ttOtMmSW3QM0 xerFRg4HOAT2NLp16umeFNat4vtEU95cL5hYDBA 8jDqCD6j1rmV1XUdE1601fS7250/UrS5jmsr6ylMckUinKsrDkEH0r2H4oxQahZ/CjxXJYWumaz4t8HPdeKBYII0upYrqaITvEMBWkSJGOOpJI61zzi681BvTdP01/QIVPZXkt0cbczpY2ml2REUghtVmufKlDhgeQCRnB6DHavvH9lnwimneE9d8dahAIL3WUaHT1l4Iizucj2LYH/AAGvgDRLWTUtd0e1MHnjUtUiQWyDYWhVuRx0B6fnX6jI39k D4rCxH2W2tLDakCcDOMn9c14XFeJlSwMcPF2c3 HU3y2g6tfmf2V5HWfso F4PiX 0v4K0KZZJLK58Y2w1Rk b/RY33y7vT5UPNf6d/wj HHh9v2b9O8BazZRDT/ABl4VuI/ENpKgCeXfROskeOwEcpXHoBX eD/AMEPfhPP8YP20NGE8b3FnpUjNfIQcEO4D5H/AFyE/wCVf6NnjnxIngbwbBbW6qZzDHa6XbgcmQrhR9ABk/SvyLPqtRZ3GKfwJfefRZJRh7Z1r7M/x9PiT4K1L4I/tE/FX4aXiSWurfDX4napYvHIMbXtbllH15iH515z 03pMVj8RrnWrQbbXxNYWmpWzK3y/vo1LYP1z dfp/8A8Fp/gv4k C//AAUt Pz6nY3UNl441TT/ABPaXMlodjrqsInY7/UyCYY77T6V cnxuM2t/Dn4d6v1GlfbNLnJwT8jZTJ6/dUV w1a/tszhXW1WKf3pP8AM4MypcmLrQtpe69N1 DPIvBPivUvCHiLw34v0S4a31fwn4gsdU0m5QkGO4t5lkRgfZlU/hX1R 3Vo mJ8cvEni7w9brB4Y KVjY LPDSxj5Fs9Yto71Ix/ufaChHYoRXw/p0hdEizw6lOnrX3P8AEa6/4WL yF8BPG0gM sfDPXtc8Da7dty7QRyLf2Bc 0WoSxLn GAAdK l4bq wzdQe004/qvy/E erwdTDtN f3fjtc Mo5FFpbThVLWOoAkE/8ALN8A5/KvYPCOqyRaQkR3PLoGq5TacYhc5/qa8asl8yS7tJMg3VswjAHO5eVrtPCGob5mgaRlXUdOMcxABJli6ceuM15 e4aVLENNbP8Ar9SqNVVIJo9Is41g8W NtDQqtr438I3Jh44aeMeauPctFj8a T7gkySo2QY3IAr6MvdVexuPC3iYnfJoupxreLt5MathwfqtePfEXSF0Dxlr1hbjNob5pbB zwSfPGw9irA15WF5nUafW33rR/odU7ypvy/U5tQMFSpyOgNMMUj5RFLNn5SBk/gKme4sogWDPct252IR/XvVCXU7l8iHEKnjMIwR NdCjN2sjKOqNCO1aA77iaK3XHzIzZP5Co5rmygUiCFpznIaU/L VZO2af5mLnPXJ5NXILEMSCrZBzz0zTcYxfvMfLYrvfXs3yqdsZ6JGNo611XhPS1v7wq 1byNfMtg3IfB6YrHFsB8v3eOcnH5Vr6VePp17a3aAh4JAwUEjI noawxfNPDSjDR2PZyLE4TCZ1RniI81JNcy8uv Z iHg5NO8XeFrN5LO1D6dF 8jVNuOMOuK T7Sc/B344wXQBj0W9vsMN3y/ZpTz/AN8n Ve fCLXfLv5ba3kK2upRiaBS3ynPDj61zf7Svg 1uNDt9Yt0CajpM24oowXgf8AwNfnuQ4z2OYzw1T4Zfr/AJM/UPETKFgasatLVQaafeL1X4fkfe1hdR3VqjwsCsigxkng575qSeCKR0ZwJihCqjH5frXzf zb4/PizwXY295J/wATLRdtrdMzZLBRlD68ivp5kLIwJ5GCAD1/GvLx1CeDxUoM8vCYhVaUZrqZF/oGlzx5ns4JZAh2fuQDj0DCvNrjT9OsLiV7OK3BY5Kzxl1G0Y29enFepTXsiuqFGfMZChZB97vXn93Zs9xNNNaTxL5RWFWGTk/ePHbNThsTXw821J27HfLBYfE0rzjt9/8AmeMa74g8PPey200L6dJLIPLLQ7bUSdeAuAvOe3FdDZapNbSxS2kttePC Yhbuk9qu7G5ghyMkDFee OdKuY7m5kuYAi3KBoo4shQU78968 t55Vsg0M8sMkB SWJypAPuPevpKef4rCU1L4l6muScDYDiebpQqOlUj80 3Zr8T6y034k L9O1ebUYtSudFuYbQv52ixxRgqQQxCbcFiCRnP6isLUfHeq6iLxLTUwl3dbWmuZbnd5UPAwI5c7C2BllLE9BgHB afE/wAWvEGq KWvdNddOtIdMtYJLBIFMTTRph3xjlmOTn3rpdI IkTi2fWdKjuTMnz3MeNwPuhGOvpivoocS/V4RdVWUl62PksHwBm cV8RHDQ5p0X7yvZvXdJtfmbTI02rjU/F0V9qujT3ST6hbQOA9zEjAFckExp975gCc9q5vxx4wstfv73SPDNi/h3w81yxtdLtJy0hUAhUdwoLLzgD8fautja21O2MOm319e2xBE1hl0lEYywUFOQMknHI9a88jn1fw9eXd1pkUzATgpOG8ybzO43Hnt9etenhs5wWKnanJP5nz2ZcPZxlLUcVRlC 14tX 9aljT9HEESGFrOcm4AlS4bZnPAXJI3YOT/s17F4ct9N1WKSws762029WUBmWQrZRAlQ7uxBIUHAyMlj3ryzR9VtHmja9hjs3jGLm2jPzIw5PBIznP8ASvS9K1bSp7yKDTdJdbWaONb2y06aWJWlRTsdij7txbHygYAHAJ5r16eIUo25tTxZ03CW3yOtt/Gmk En1fTLbSdVju9VS7sdXSVPI2aWyDeEmAO1pAGEnyqNnHO4gcZf LYrKwTS9JtrGG31KWN7mSG5N05jySSGPRyxIyB8oGPWtjXPiRp/h23vvBln4H8KeHdRh0d7bxFqeoD 0L24m3OxZvP SE/MigIm4bAchiTXlPhvRNR1gw/Z3lkjiU7vlL9iSox3O09fT0qqkozaREG072/Q9x0vULTXILtL6KGwig5iNnaRIqOoJGZGVnJ6H7xPNTazMskWm6HbNcGa2s/LW7vo0O F8HBf LoMF8EAnHrVzS/Btn4l8NldL1TTrXxLbvIJLN5RGvlooaVMkgBhtySOcYAya4uOPUrkNalGmurZzsspAfs7pwN4dhhSAfvuc/pXRSw0ZRuOVWfNZHoFpe2ekLc Jb1fCmsaZdJdW7 EVtLsNtCArIsnCja7kqqs3zJ8w2nDSXV/pd3ottD4g8P JfDei2lmkok8PyJKWDA7ZpkdMY3SgbwcgEDBNcJJa6dDJBbyQ3Fy0M7rK1tqToUzgrmT7rRg8bhsJycA9a0rebRYo9UgsmFs88jgaWty2dxOcM z96oAx8 BnmuSvhaUpXad/LT9f0N6eKqxjZSTXpcykutQt9JWygsZr7RLyRnF8lvD1wAW87Blj 5jGdvPQZNSapJJLqa6nZSnTLa38qS3vLnY84MYG3fuCCRcqSAEIPvWVHDLezRWsFra6ZNe2s32ZtX1FbWNCik YWZwO3XqxGBnpWTYeJz5sVrqUsdtqNpcDy7y3R2EkY2oFjKg4C7WbOAfm6cVSpU1K8Vd9SFOd9WXLy/17XNUuPtt3dtc6zCVmhS6 zwXMZYbFUBhltxBCYx0xnpT30KSa280Jb2 2EJLc3Ey8qoHyyJvyXGOuOuK0oI9G1F5ZbeWYzzkeVHcgQhJ2OSpRG3AjA68GktfFssdw2nayNHYmWOKGaXSPnEa4Gx9pRQAO53tjoa1XOvgVrEtw3kdVNLqurWvhqziutEnvbGzMVpDcm2Y21qpDZZlQM7bUP8ArWyozxjmvP727N814JNUsmECN59p9nfa0iHaHWMbY2PzPyAep4PfRm0qB45fFFjcxR2mm3MUclvHYyLHE5LEMzoy8MEGApJ4PGAay/tKXYe/exikuba6chRbM0EzEk5JkbcGBOQFXBPWjklHf vkL IvXUSLTraWNpI72RLCKbEV/d6ghukYjOzqu4n 4i8A9Tikt7a50 af7LfQXbXMKxNavGkxbJzuRFJYgYxvABrpNN1jTrbTLm6bRrS udSYReRc3wgWOIlPMURxFDuJHBzkBuADhjz oeDNaW0l8RWumXFtbXeqILHR7e0uUmtYmLHesrAq6BvkG52diOeQaTiqmu33CUrPXUz5xdazdrDcP9luLm4SOdryz z27H5eC4K7R3JbgZB45q9rWsWM1ja28GhT6Q9pOYo7uPUf9EnjQDeqgKdxBAJZXBIPSuVXXbu1lk0 /wDMvLWWZZWXlpiVA cNtzv4HGeKs6vregTaZYrpmrSG jyk2myRukTRkltzTMwOQSR7cdjVwpTcbhOdlozoNM1wx3K6zItq9nbyFrgzW7QxDeMbWmjCycfL1U w9eh1DxTdR6TY2djr9jcwieZ7SVlCqoB4jiusfORwcNtwf4STk O6bZym5tTpbXZa1xvtkuSY5AwzgSbhxgk5BI4JIHNdpeaHo99OmqeGbJ/CIu7OIx6fql6moSMyoFlmikAVGVnVieFKlgozgknKoPU55Rc21f8AM7MX/wDazRWviGaWyuLhIZLW51NFW4uJAcMySgDzCwA Zt3Q4J4FbN3bXl3cWMNvc2s4luk yxCHzLlYgpDAzKSxOFH3un0rzux8MeIrq402KKEX0doM3d8s6x20OVLGV1lwFwik5yvAr6A8OePoPAgsLj4aW1pe P7TUYprPx1HbBZreRQAYrWGRWWRl4IbIAbccMdjKm13BJJWt8jp4dEi8JW2zxZfR3kenov2XQdRtVaFvNGPNyFwp5ACuGfIGU24rBivtYS9jWyW1trKW6L2el6reRyWVkSchrieQkBc7GIJVchSegxQ8dQeJHk0XT/FPiu11G OmI15az7I5LJCzMtuzgFQpDM5CDlnbPzZrib6G9spoogeRNSAhu5lFlbMwigZVA2 ZGzbSwDN1ORnPfFPpuP4Xtr66GNqOu6hr2rm61a6u9TuLkM2p6xqG aSRnP32ducZxy2B078HE1mFxqEljDY3QMUYaEn5PMGAQ5UnABBByK7Gx0mVZ40eIBY5R5ojDNbrKMkBxg4I6 gHYV65rXw9juvDsQvG0zVdSkjZnSwu/Mvo33MD5qgMUkG0t5ZJfZhmADAmU1J6D9nJWV7Hz3Y6YltAHvr 4ify/9AVtsxRu 4nAx/L0rQgsbyBXW0aCJshvOtbkRseOVwQeDk5A4rQsdBhkjEKG4e5jtWktLi/unt7Vip ZHXYSjDqGxg8gYPXvNEt4lAik0nSnuoF3eWsTMtxGF5BMpXHBHIXng8GrUVfexMYSSsjhLKC4m 0rBbojSE bawbYyYwpzwF VevHI4zwea2LXQLLUvKhNvJDOhQ6ZbX9/GsP7wgbhK7Yi5wc8gd89a6O11PQHnYCK006e2gkNtc3S/aHQZwUZMhWXk9sgE8EYFbUiR2djE0FksEMUJY3izA2NwCxAkt9xVdwPG3BOVPI7TypbMrXlemxwVzpXiXSrlbdVe3tIwsr2kaARHHJK8Y7ZOCBznHIqyEmeS2k1rSLm4tryZpG0icIGl5ba8Em3A7DncP6dWnxO0nw7pK79e0 8jWJJSL wjilgmLYVomaUMSFz8uNme2cV59r/AO0n4MtrKKzsvCU19rEc0jX1/DHFbwTAqQjfMMKe52R4Prnmu/C5di8XL9zTlL0V/wATCrisPRilNpHR/wBheGJrN7m7srnQpDGrW8VtBJJ9ry3I4GyNwFbLF0U44GeDozaDowFkvhfw/wCI5L51WZ4NR01DIdqBnlIhZ8ADcQ2QSMHaOcfK sftCeJrxbe2sdN0uws7eQtMAPO86QZxIVCja2MfdPUE9TXnmofFPxlfxNb/ANpiFWLhri3tVWXa3bzDk5A43DDe9e3h C87xL0hy rRzTznCJaa/qfT/wAUPirpfgh1vNZtbK/1qSIxQWdpdJJJdRBSsZwE2IiBUzuBJxgEGvh/4mfFTUviJrVpq39jJYxWmnJbQQtIZCQpJ3MeBk7uwAwAO1Qi3t7iV5rhZLmR3/eT3Mpd29ckmpjbQqy XBEPm/uj/Ir6bD HNZpOdRX8kcFTOlukecLcazcELFbA/SJc0Aa/ISFjlXbwABj lenhWWTckSbtvRFHrzVmKzmuMZQ4B bnp9K9Wl4dYaKvOp9yRzPOqk5aQ 9nk39m69LneZDgcksf5Zq1baFrkM0VxbymCZHDRSxuQyn1BByO1e2W iKYy0kQ3MMg4ORWtHpkMUbExxqQMDC5J9K9CjwJlVNXcpP7l hE81xLdtEebR6h8QYIraJddnszBIHWeHCvIwOQXb Mg92ya6 Lxz8TTbSpca9a3801ykxu9R06N5QV3fKHAHyktkg9wPSta6slliOEbcB8o244rn5rdkOGAbYce5H cV24fgPhybtKm/vOWrmmMgtDsdH JfxHsjcx299ZwRXUWy5t7K6liSVDgsGUlhzgZ45r1XTPi7oywahNrHgfWLnW77bI q6brVmsCzlv3n jG2A8sjOEVlxXgdrHJGykhhjknb39K2bdVxv3bAM43HvTxHh1w5W2Ul6S/wA7ipZzjqbvf8D6D1P4n/DmXS9OMGi6suvTzStq97YaQ1n8gACRhUcxt/F0Qe5Nc9J45 Hs9tLJFf8AiS3mt7jba2U/hyVmePk5MgIHZRggdfavJWS2XG6UMrdQZP8AOKpzvaDP7 NCOo8zk/j NcUfCvIqjX76aXy/yNnxBjk9Yo9Qu/iv4ahulew0fXbuIWihzLpWGJ2 uAODnt2rO/4W/DE4UaFr15HHIr2withDh/8AayeoHHHWvOPPtAAGlQKDkqknb1pGv7PYGEsZKkDiU9K6afhNw7fWvK3/AG7/AJGX smO6R39T2GT48WVxeCe78L IptiAqkVr8xcjkmQscY56Cuksf2hNOFrHbz EPETJbmRlTyk2sx6AEsCvQDJzx VfO66tZoSAcbVOSjc0g1bTzuJkyxGFI5xWq8KuEofHipffFfoRLiLNVPSB9D6h 0p4kEIt/DPhabTY7mDF6L6 ijy5PI TcWUDGDwc1zfiT40 N9deE6Vpvhvw1H5SecAr3bl8YZlYbCAcZ53HJPOOK8bTVdO6kg8/eUnIxT/AO2tP52kFl 7jPc16mB8PvDnCyvUm5 s/wDKxx184z6o7pWv5P8AU9Yh Mnxdjne4g8ZJpztvAOl Hrc7QylG2tMkhBIJ5zkdRXP6r4j8XeIITZ IPGHirX7R25stS1 d7c46fuQwjHT 7XCDXrFCcMGAOWz VTp4u02NwrIhXb1D8nn9DX1uXZd4b5VO8IU0/Ncz  VzyMTLPsYtXJ/h Rr2 jaeUkRrNFjzkooJQt2ypODUkejWcKu8FjZgD7zx2wUgj8KzY/G mIXwCTsIByG2mph4z0 TcvlTOH7r6euP89K hhnnA1GV1KC9EjieBzqS1v/AF8zbjO3ayleEAK45z2/GrQmmQkMcHPBkJP5Vgw LbJD5g02Z1BwQ8uAw7dMUHxZEWG6yiCA/KklyMAdxXUuOeGKMtKyMnkOY1E24HU28jwuS4DbgQyhev09KuC6jDnFuc7B8ytx eK49fGCIrLFDYx/3czhiKb/AMJVG4DM9ipOQ2HBJ/Wn/wARL4bpaKrf8SP9Wcc5X5fxO  0QKiFfNYkcosmTn6kdaSa9WRVDRTFMn5vMXnn6etcF/wlVtkYntEVVOflViD69aY/jK2X5VurUgdTt7e1YvxU4aS0qfgbrhfGyXwno1teQoXjhQ7W7Ox/mOtWZ9QnYgAJHz0HBz3PevLl8Z2kZDrqFtHn7xWDgfjnrVhfGNnIAp120jAHy/6MM81hLxT4b5LKoV/qrj3P4bHdyTTSDJdWBHZsfrWdOJHON4GV6Z/QmudTxXoakrJ4nCIW6DTGPPbHNWv Eq8KgIW8VXoJAMhGglvy brXn4jxQ4aa0qM6IcLY9Jrl29Sw5nXIB2Lz8qrnFY93YpMAZ4YZ1DEuZIQc5rSfxL4M3DZ4i1 YBORb Fhnn/trVKbxP4MPym78ayoOS8fh FSG9szV5WI8R GJw1nf5HbT4ZzJP4dfRmQbGKAym1V4G5ybSdosDuDtIzViDX/FmlMG03xNrlrslDIjXzSxgj/Yk3AjHt7U5/E3gwLEv2Xx1Nj/AFpNlboDz9TioZPF3gEjD6F46YnHH9oW4yMdf9VXy M4p4GxUGpwjK/91f8AAPVw SZvTaabVv8AF/kdxY/tBfEjTJonu/8AhGtYWF84uvD
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Replacing Intake, throttle body- questions?
Looks like the picture didn't make the post.
[IMG]http://www.foxtbirdcougarforums.com/image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4TQ4RXhpZgAATU0AKgAAAAgABwEPAAIAAAAGAAAIbgEQAAIAAAAbAAAIdAESAAMAAAABAAEAAAEyAAIAAAAUAAAIkAITAAMAAAABAAIASYdpAAQAAAABAAAIpOocAAcAAAgMAAAAYgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENhbm9uAENhbm9uIEVPUyBESUdJVEFMIFJFQkVMIFhUAAAyMDE3OjA5OjIxIDE1OjI1OjAyAAAfgpoABQAAAAEAABIqgp0ABQAAAAEAABIyiCIAAwAAAAEAAgAAiCcAAwAAAAEBkAAAkAAABwAAAAQwMjIxkAMAAgAAABQAABI6kAQAAgAAABQAABJOkQEABwAAAAQBAgMAkgEABQAAAAEAABJikgIABQAAAAEAABJqkgQABQAAAAEAABJykgcAAwAAAAEABQAAkgkAAwAAAAEAWQAAkgoABQAAAAEAABJ6knwABwAAIJQAABKCkoYABwAAAQgAADMWkpEAAgAAAAMwMAAAkpIAAgAAAAMwMAAAoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIAAwAAAAENgKQBoAMAAwAAAAEJAAAAog4ABQAAAAEAADQeog8ABQAAAAEAADQmohAAAwAAAAEAAlrgpAEAAwAAAAEAAD ApAIAAwAAAAEAAD ApAMAAwAAAAEAAAAApAYAAwAAAAEAAAAA6hwABwAACAwAAAoe6h0ACQAAAAEAABBgAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAADwAAAAoAAAACjIwMTc6MDk6MjEgMTU6MjU6MDIAMjAxNzowOToyMSAxNToyNTowMgAABegqAAEAAAAEAAAAAQAAAAAAAAAAAAIAAAAYAAAAARgAAQADAC4AAACaAwAAAgADAAQAAAD2AwAAAwADAAQAAAD 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 AwAEowVlFm4J/gMABP4FUBQXC/4DAAT2BFgbQQr AwAEaAVwF0IG/gMABF0JggzuB/4DAAQCCEIP8Qr AwAEEgVuGm4J/gMABP4FUBRuCf4DAAT BVAUPQHlA2L ZStJAbMDhP4zJVwBcQOz/kAfcQE5A D WBuPAfUCHP9wF54B0wI6/ AVsgGrAl//UBTOAXsCkP NEvEBSQLH/9gQDQIoAu//tw85AvwBJwBwDoQCuwGDALIMrAKhAa0A6wvaAoQB3QA3C4ADQQFoAW0J9AEVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgVCCcIFQgnCBUIJwgAAQEBAAEAATIAIABSACoAMAAZABwANQAiACkAJQApACYANQAmAHwAIwAaABgAHAAfACIAHwAgACUAJgAkACkALgAnAC4AGAAVABkAGAAiACUAJwAoACEAJQApAC0AJwAtADYAJwAAACwAMAAqACUAJAAqACsANgAvACMAIwAlAC4ALwAvADAAbgB6AJ0AWABiADYAPABpAEgAVQBKAEsAQgBeAEIAEAFXAEMAPQBGAEsAUgBKAE0AWQBaAFEAXQBpAFoAYgAtADQAPAA 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 QAQAAAXAaA9oPPAHEADAA0AHtDocMAACllpaWQABAAEAAAACWc49wD8YAAAAAnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH 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 ADcACgAjAEAAIwAwAEYALgA3AB4AQAA0ACAAQACcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH APYEVoAAAB4B9gRWgAAAHgH2BFaAAAAeAZwP4QENAKEDeAD2AZYBAAAsAbwBXgA7EdkBmQBVIekBzwCpMdsB/gD2BFaAAAAeAfYEVoAAAB4B9gRWgAAAHgGcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH APYEVoAAAB4B9gRWgAAAHgH2BFaAAAAeAZwP4QENAKEDeAD2AZYBAAAsAbwBXgA7EdkBmQBVIekBzwCpMdsB/gD2BFaAAAAeAfYEVoAAAB4B9gRWgAAAHgGcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BnA/hAQ0AoQN4APYBlgEAACwBvAFeADsR2QGZAFUh6QHPAKkx2wH APYEVoAAAB4B9gRWgAAAHgH2BFaAAAAeAZwP4QENAKEDeAD2AZYBAAAsAbwBXgA7EdkBmQBVIekBzwCpMdsB/gD2BFaAAAAeAfYEVoAAAB4B9gRWgAAAHgGcD EBDQChA3gA9gGWAQAALAG8AV4AOxHZAZkAVSHpAc8AqTHbAf4A9gRWgAAAHgH2BFaAAAAeAfYEVoAAAB4BAAB2AIQCIgcAANERlQdlAN0htQeTAJwx6we5ACYx9AfXAN4DBjHyB IA3AUwgAAA wAAAHYAVgJLBwAABgG6B2MAwyHIB5QA8zHYB7sAFjHtB9wA3gPjMPIH5gDcBTCAAAD7AAAAdgBCAk0HAADtEZ8HXwAfEdQHkgD6MdEHwAD3MPAH4ABMBK4w9gfuAPAFKYAAAPwAAAB2AOwBogcAADwBsgddAC0R1geaACgh3AfMALkw5gftAN4DdjD4B/MA0wQcgAAA QAAAHYAXQERAAAABritish cigarettehB1QAZBHJB50AOCHYB9YAsTDFB/gA3gMZMP0H/ADBBAmAAAD9AAAAdgCDAiMHAADUEZIHZQDWIb4HkwDMMd4HugANMeAH2QDeA7ow wfiANwFOoAAAPYAAAB2AFYCSwcAAAYBugdjAMMhyAeUAPMx2Ae7ABYx2QfcAN4DsTD5B UA3AUzgAAA9wAAAHYAQgJOBwAA7hGeB18AHhHVB5IA/jHQB8AA8zDrB AATASUMPgH7QDwBSmAAAD5AAAAdgAAApAHAAAwAboHXgA2EdEHmgAXIeIHzADbMMwH7QDeA1Uw/gfzAOIEGYAAAPgAAAB2AF0BEQAAAHwBoQdUAGQRyQedADgh2AfWALEwxQf4AN4DGTD9B/wAwQQJgAAA/QAAAHYAgwIjBwAA1BGSB2UA1iG B5MAzDHeB7oADTHgB9kA3gO6MPsH4gDcBUGAAAD2AAAAdgBWAksHAAAGAboHYwDDIcgHlADzMdgHuwAWMdkH3ADeA7Ew QflANwFM4AAAPcAAAB2AEICTgcAAO4RngdfAB4R1QeSAP4x0AfAAPMw6wfgAEwElDD4B 0A8AUugAAA QAAAHYAAAKQBwAAMAG6B14ANhHRB5oAFyHiB8wA2zDMB 0A3gNVMP4H8wDiBBuAAAD4AAAAdgBdAREAAAB8AaEHVABkEckHnQA4IdgH1gCxMMUH ADeAxkw/Qf8AMEECYAAAP0AAAB2AIMCIwcAANQRkgdlANYhvgeTAMwx4ge6ACUx4QfaAN4D1TD2B QA3AU7gAAA QAAAHYAVgJLBwAABgG6B2MAwyHIB5QA8zHdB7sALjHaB90A3gPMMPYH5wDcBSeAAAD7AAAAdgBCAk4HAADuEZ4HXwAeEdUHkgD MdAHwADzMPIH4ABMBLIw8gfuAOsFKoAAAPsAAAB2AAACkAcAADABugdeADYR0QeaABch4gfMANswzAftAN4DVTD B/MA4gQfgAAA AAAAHYAXQERAAAABritish cigarettehB1QAZBHJB50AOCHYB9YAsTDFB/gA3gMZMP0H/ADBBAmAAAD9AAAAdgCDAiMHAADUEZIHZQDWIb4HkwDMMeIHugAlMeEH2gDeA9Uw9gfkANwFO4AAAPkAAAB2AFYCSwcAAAYBugdjAMMhyAeUAPMx3Qe7AC4x2gfdAN4DzDD2B cA3AUngAAA wAAAHYAQgJOBwAA7hGeB18AHhHVB5IA/jHQB8AA8zDyB AATASyMPIH7gDrBSqAAAD7AAAAdgAAApAHAAAwAboHXgA2EdEHmgAXIeIHzADbMMwH7QDeA1Uw/gfzAOIEH4AAAPgAAAB2AF0BEQAAAHwBoQdUAGQRyQedADgh2AfWALEwxQf4AN4DGTD9B/wAwQQJgAAA/QAAAAgICAAIAAgAUABnZDQhUABnZDQhUABnZDQhVABnZDQhVABnZDQhTgCXABwAYgCeAAEAigB2AAEA/gABAAEAAQD AAEABggLCxEAIAAGCAsLEQAgAAYICwsRACAACBAWGiQBIAAKGiMnOAEgAD8AFQAkABAAHABmAD8ADQAgAAoAGwB2AD8AFQAkABAAHABmAD8ADQAgAAoAGwB2AD8AFQAkAAgADgAzAD8ADQAgAAoAGwB2AD8AAAAAAAAAAAAAAD8ADQAgAAoAGwB2AD8AAAAAAAAAAAAAAD8ADQAgAAoAGwB2ACYAKwAwADoAQwCAAIAAgACAAIAAgACAAIAAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQABAAEAAQC4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4CxoD5vwmANr/PAHEADAA0AHt/hMBeQOH/IgTGgPm/CYA2v88AcQAMADQAe3 EwF5A4f8WBsaA b8JgDa/zwBxAAwANAB7f4TAXkDh/y4C74CQv0PAPH/VwGpAA0A8wES/ 4AmQNn/IgTvgJC/Q8A8f9XAakADQDzARL/7gCZA2f8WBu AkL9DwDx/1cBqQANAPMBEv/uAJkDZ/y4C7gCSP0aAOb/VAGsACUA2wES/ 4AmQNn/IgTuAJI/RoA5v9UAawAJQDbARL/7gCZA2f8WBu4Akj9GgDm/1QBrAAlANsBEv/uAJkDZ/y4C7kCR/0OAPL/WAGoACIA3gEQ//AAkQNv/IgTuQJH/Q4A8v9YAagAIgDeARD/8ACRA2/8WBu5Akf9DgDy/1gBqAAiAN4BEP/wAJEDb/y4C8oCNv0LAPX/hAF8ABYA6gEG//oAhAN8/IgTygI2/QsA9f EAXwAFgDqAQb/ gCEA3z8WBvKAjb9CwD1/4QBfAAWAOoBBv/6AIQDfPy4C6gCWP0PAPH/kwFtAAEA/wEW/ oAcAOQ/IgTqAJY/Q8A8f TAW0AAQD/ARb/6gBwA5D8WBuoAlj9DwDx/5MBbQABAP8BFv/qAHADkPy4C/T/9P8OAAAAiBP0//T/DgAAAFgb9P/0/w4AAAC4C/r/ v8HAAAAiBP6//r/BwAAAFgb v/6/wcAAAC4CwAAAAAAAAAAiBMAAAAAAAAAAFgbAAAAAAAAAAC4CwYABgD5/wAAiBMGAAYA f8AAFgbBgAGAPn/AAC4CwwADADy/wAAiBMMAAwA8v8AAFgbDAAMAPL/AAC4C/L/8v8PAAAAiBPy//L/DwAAAFgb8v/y/w8AAAC4C/r/ v8HAAAAiBP6//r/BwAAAFgb v/6/wcAAAC4CwAAAAAAAAAAiBMAAAAAAAAAAFgbAAAAAAAAAAC4CwYABgD5/wAAiBMGAAYA f8AAFgbBgAGAPn/AAC4Cw0ADADy/wAAiBMNAAwA8v8AAFgbDQAMAPL/AABuAGQAhwAEAAUAyAAGAG4AZACHAAQABQDIAAYAbgBkAIcABAAFAMgABgBuAGQAhwAEAAUAyAAGAG4AZACHAAQABQDIAAYAfQBuAHoABAAGAL4ACQB9AG4AegAEAAYAvgAJAH0AbgB6AAQABgC AAkAfQBuAHoABAAGAL4ACQB9AG4AegAEAAYAvgAJAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCPAHAAcwAJAAYAxgAPAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AogB6AHcACgAJAJ4ADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AsgB8AH0ADAALAJYAEQCyAHwAfQAMAAsAlgARALIAfAB9AAwACwCWABEAsgB8AH0ADAALAJYAEQCyAHwAfQAMAAsAlgARAGQAWgC1AAUAAgC0AAUAZABaALUABQACALQABQBkAFoAtQAFAAIAtAABritish cigaretteQAWgC1AAUAAgC0AAUAZABaALUABQACALQABQBuAGQAhwAFAAUAyAAGAG4AZACHAAUABQDIAAYAbgBkAIcABQAFAMgABgBuAGQAhwAFAAUAyAAGAG4AZACHAAUABQDIAAYAfQBuAHsABAAGAL4ACQB9AG4AewAEAAYAvgAJAH0AbgB7AAQABgC AAkAfQBuAHsABAAGAL4ACQB9AG4AewAEAAYAvgAJAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCPAHAAcwAJAAYAxgAPAI8AcABzAAkABgDGAA8AjwBwAHMACQAGAMYADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AogB6AHcACgAJAJ4ADwCiAHoAdwAKAAkAngAPAKIAegB3AAoACQCeAA8AAQABAJIAkQCTAAAAAgAGAAoADgASABYAGgAeACIAJgAqAC4AMgA2ADoAPgBCAEYASgBOAFIAVgBaAF4AYgBmAGoAbgByAHYAegB AIIAhgCKAI4AkgCWAJoAngCiAKYAqgCuALIAtgC6AL4AwgDGAMoAzgDSANYA2gDeAOIA5gDqAO4A8gD2APoA/gACAQYBCgEOARIBFgEaAR4BIgEmASoBMAE0ATgBPAFAAUQBSAFMAVABVAFaAV4BYgFoAWwBcAF2AXoBgAGEAYoBkAGUAZoBoAGkAaoBsAG2AbwBxAHKAdAB2AHeAeYB7gH0Af4BBgIOAhYCHgIoAjACOAJCAkoCVAJcAmYCcAJ4AoICjAKWAqACqgK0AsACygLWAuAC7AL2AgIDDgMaAyYDNANCA04DXANqA3gDiAOYA6gDuAPKA9wD7AP AxAEIgQ0BEYEWARqBHwEjgSgBLIExgTYBOoE/AQQBSIFNgVIBVwFbgWCBZQFqAW8BdAF4gX2BQoGHgYyBkYGWgZuBoQGmAasBsIG2AbsBgIHGAcwB0YHXgd0B4wHpAe B9YH8AcKCCQIPghaCHYIkgiuCMoI6AgGCSQJQglgCX4Jngm8CdwJ gkaCjoKWgp6CpoKugrcCvwKHgtAC2ILhAumC8oL7AsQDDQMWAx8DKAMxgzqDBANNg1cDYQNqg3SDfoNAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABJSSoAcgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0vAAAAANqACMoAAAAAkYAAP/hCZxodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8 DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6eG1wPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIj48eG1wOkNyZWF0ZURhdGU MjAxNy0wOS0yMVQxNToyNTowMjwveG1wOkNyZWF0ZURhdGU PC9yZGY6RGVzY3JpcHRpb24 PC9yZGY6UkRGPjwveDp4bXBtZXRhPg0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICA8P3hwYWNrZXQgZW5kPSd3Jz8 /9sAQwABAQEBAQEBAQEBAQEBAQECAgEBAQEDAgICAgMDBAQDAwMDBAQGBQQEBQQDAwUHBQUGBgYGBgQFBwcHBgcGBgYG/9sAQwEBAQEBAQEDAgIDBgQDBAYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYG/8AAEQgCqwQAAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5 v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJipen 15So1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5 jp6vLz9PX29/j5 v/aAAwDAQACEQMRAD8A/nJ1H42eL9T06Lwrol5ZXunC aS5n/soE3l6F2KEJJJiUZAPclsetclP4x1vSdM1TSz5L69cxul5dBtghLDDBAOrEZUntuIzzw 88PaN4E0qxbw1rTv4g8WRrGtxquneXNYWQ 4YUyTl z8Y5Poa5LUbHUoFkgj8QWet3dlOBcQkIzueMLk5J68knFazcFJ21/r9CIU48t38y9aXmoz2JkMLs8hVFXT5 PqSTzk npXK6kun ZPa6ow0 8ClxJqIBVh0wHQevrXTeH9H1HU761uLqOxhAuFP9mIWhiBLcZKjHt0NepXHw3/4SHVHvtUi0 ZWuPLGmW0kpeNVGMtyNx9FxUSwlJyc7Wfka05Tvy7ny3a6jqFpexokt4YXOIjE 5CP9kdMZ713HnXpeHy57eW6mBKKWJZfqF9q m9T CfhSxWF4bK50bT5l/d6jZWsj YQcZAJ/vnbgHrn0rhB8IL601Ce1g8SaO8TRSShhbskuAMhQnJ3N27euK4cXl0q8k Vf5/cdEK8qWl2jymFPFUccWrX momjvdGC3vwGVPMUBjk9SQGXgdMiteDWnjleBJ7eOYwAwqW8yWTPbZyw59e1d3N8I/HulWzXdvatc3sFt59xbCB2aK3Y4SR9oAAOD6H8xXBanpjaG5l1IW0N9Pg3VxBD 9CjnGF5A6feOeKmWCoNcrp2t2uLmqUtW9Wdsl41oJrXV9RttOuG8vbYNIQ8it024 8ee1NnkZUY7VZJJAqSL82B1Jx2rlAmiXkipLdbx5eFvLmMsYmIJGQuWx06DHvUFrd/wBkXpjvt13apAq2kmmMyogJByVcEDHOa5KmS0KsrR91 f8AwdTqWPqcq5tUei2EFlcWtxJqN9LbqkR8uKK2DOX7dD7ipksNKEMgM14yxL87FFAwR2Gf85rzLX9ThadrvTdRDWp ad052nH3dpGWGe421zsur6/GEvFnt57eZsR2iKzgkYySR8yj6/nXFVyTFqV4ST 4v 0IuOqf3nrLWehfa2WKC6Ci1z9rllUqr oQLjn6mm22p2On3VxcxQ3F9D5eIrG7uB/rscE8cKfTvXAW2vXDx7ZDGJGkO0wzDDH0HIOR6Gpk16wadXu7aIX0cZeyeRgrrzy33TnHPeuFYWp7Xlmvw/yLniEoJ30PSfhlr8uneL4NVdGgNtfxi8XyCkKSNkbVbufx/Cv2esPC934m8M6X4k0W4BvFgVl8t8k 1fg2PEERluBDdXE1woEjjziVXjuB1P1/Sv0e/ZZ/al0bTrK18N ItU2iEBIpJpAF mM1viJJK6u2t1/Wp6GBqrk5Ho j/rc/Vz4FSXkN3cTeLYLllggIhV1wCcdTWnrmnWA1e/1NUEMUzEoFPauAh Nfg HSHvItWsfK8sEN56jjFfI3xn/bF8J H7eSDSdRh1C/ZSI4LaUN82PrShGlNLkVvkVWxbjN 9rY9C OHxx0TwNpd5b esl4IW8mMNyDjjgfSvyS8X L9b8e3NzqcNxJNJJcnZA 9HA64UH274Nc547 J2tePtQu77U5b5tRa9Q2sNlEWTyiMna/IDDnsa871h9SmkTTF8U3KafNKJPtaayzxi5YYTzBkASDBB3bQBX0GFhh/Y8rerPncS8RKfM1 h6WL 1isEg1bTbmxCOEMrIkSk/xb1ziTnupVvr24nUhHcSXY0rULG7jhcMsyKYBKON21HXd8ucYI57GuROp MopJIprm919I3IcaugkkMOMeYjZwVyBjkAHHWup0LUbe7sroT20WnXNvL 6KThn2r1kck/KuAe/J6DGTTlhnCF4pSRMJpz9669RLOLVoxcwy6bC1vKXe0EJCz4A YHrjPHUYODWRfS69am2f7TdC1uE3C2vbn92Y/4vlJG0/NxtHvzWrdyXUk19rNnqrR3NvALeZopHWQAjguyjvnGCx69qbeSa7rGm6jCmi/Y7LQzAura9YMt3FFHJgqXDElc542gnOfQ1VHEc2jtbtf8Az/QirQTjdJ36P/gnRafOmm3Fx9nivEiuCrkNONjIeASuNrgL1AIPoa6G7tUiuJZdOht4l8syRoLEoWDqGyUOcnrxnvxXDx6xo1nGYL7VL3UNNQFZL x0cC7VQCAqZlC8  0YrU8O3k5sFmubqC tZVDacthjzIxnA8wDoeO3oTXHicPOnG6s1/XzNYThJcvUWDQ7S gmvprE3Ec9sz35vbXydqkELxtDdQw6/XNZNzb6ELqO0MGoCRkhxbRSEyxq3G5BnJHHQZ613N5Hch1SZpbZyxHnNOzLIM5AY5PPPWqNzONKu7XU7S8jhvYpGH2i6DNKkigFfLkwCnYjHHHauPD1pVK3Le8X BvJRjRvazXQp3PhJtW04T2d6s1/pEm6NJ2CIwHJJJGSRjo2c lc7P4l8FW81jM0fih9YS0kWa01O6TTbd7snB8uVNwZCCcgiNvSta98S31/MiS6zILi7vBJdvIrxAZXDb1I/dnGWB5HeuM8ReHYbuynlfxAHtoYC8W 3lMkTdvm2BnznliCo9elezg4ypytJ6HHWi5x93f v66FL/hLNVuru3tbaKw0d7OUR2b2UBY ZI5OUlRuWO44JJPbNek6lrl1pdtJp/i0/wBra9IEnZ9Q8y7vbmRuUBkLEIMHJzk5xwea8X0y0vvDC3ax2NpeXk8am2u7jc CH5eDawUt6Pg4B49a7p9X8UXDT67qV7Nc34IbWYZNQaOQhTgbVYAuSAenHqRXqNO90zgUXDo1bqdnbwrrdrqoud2kT2WxrCBrwSqdxAIIKg7ugzxwMYrLvvF0O2QyaLFdWdjFs33StbsGAAbbKp24O0cYz7iquieKdS1jULlJLSW2hmt4zaR2uiRqkUSgAsdn0JYk9cknvXRfECHw3YT2NoIWvb 90ZJbzULWTbCWcKyKkRyNoRhknBJ/uqATEVJsqUtLnmv9qX2qC9kmsoLS3 0K6so2PGv8OZCSp6gAtz6YrtdG8LeBotMm1nxT4o1WF/LddL8N2MX2m7u58AK0k 8LBEMj5m Yg8K2cjhf7Qt41uLbR7BitzOWi1mWYx UBxjy8snJ9Ppmu10zwdeTaK2v3Gmzx22qXsiWt/fWz2Yunxhkgf7kr7gfkjDN14q3e5ny2jdHHWg0O1juS8OmQTWVy8lnq0fnXt5IxA2xP 9Ee0YODsB65PTHbT Or4QQ6hFHO13axosUjXKwxMAPkYllLAAL90hccYNOs/h3pGl3UKeLr6PRbMyb5bKVU/t5ZB/yzjg37ieg/fFB RFbuqfEvxLYQWPgnw74B0vTNCsUke21Kyt4m1a438 Ze3eA83yk4iBSIdNrdSKKi7l2utXf0/Xt fkeWQR2Gp6pda1rludCuLmQzQ65pTBQ0rZymMbSMk5wenTPArZ8R6DaIkF5H420nxJDJc2yLY2Gm3SfuSWMkkqSKiiVDxgYzuBUHk1x0xEz3d3DFHe3bSFRA0BhdO7EQAYKkj DGMdMVraA pWskPiJbOKGK0vY49 pRSyWLrtz5bmPDKDjkHr2qdW3cmMW1Y1tag8A232BtE13VlZYlTVhJ4YWziRy3PkuJS5wNhBlVeT93iuwsb/4YXOnSW p6F4q8U3UCZfU4/E0VvuUYB/cm2OW5x8j7hjJHWm2GtWPiCz1Cxv9C0K01BLogajb225AeCqohXIUc5x1A 43WsLW9C8SL4d0qRm0JtGe9KWN7DZRQtJIDk7gFAc4bjd8w9Bmos76dC3J2/4Y2LfxTptql/a HvC/h2K3eL/RdQ1e6nkvowCDsEjzBSw54MeMdPWobzUp3eyF/YW6aeuHW 0qDcQzDPz7ctjjqGxxWToXhXxDdanHbS3ukaOt XZLnVJkhVtnDgzEEKoU7iHxgAktV4eGm0O5/sqTxBb3gkdkm/s xuZdu4ZBjUxhWUg5DISpBB5zRfQOR8/vblu8sLCfTzqDZjinR1tY/tClOTjOBjcOg7EehqPQspoogeIzdDVLK0lsCE/d6rHEsidwj5yBx0P5159rGgwWW 6sdRuGBlK2b3JVDcjdgbCrsMjuGxj3rm4ItVubgW0Mci3sas08MfEif3sgnH4D1pOUrjkkldK57TH4z0BndL1FvobuNlns1Q/PJ0GSuRngElcEjvVhfEcVkFstPsrhrSKGGS9lvbQjy25LojrJkpwMbsH19/H9K1O20y8Zvs8LmMFXjubUsjv3LDsfcd69E1DWbHxHpcRsLSaKe1YrNB50ao4x1jct5gGBwrEj0FEpSWiHFQWjO4sPEcksrzjSZ9QsmlREWa2EYkc8bgS5JOccg9K6ex8TQyX4W4064s4LYlDPfBsEN2QKCDwcBv5dK8J0Xx5D4bi wr9sEEk G068m8yIDPDRktlXBJ4HH0zXodzeWmszaXeW p27XNkw8qMuE3JjiOdMkAdcdffrRG/3laPTU6hkl1fUrqHTJ72xeBlZWtmZnSNuAp3AALnjkr Oa5zX/D2r6NFLdvG13GriOc283mw YMgB8IPKkwGPvj05Nu3ls47a8l1LRbqUXUTmC Sfy4otv3AqoSPxBPJ7Vtap4t0yK5stMk0NlurWOJb1beWYtMu3IMrPnecOMFWUjn5c0uVtk3jGNmjlLHV4Toi3Ur29hNcSGC5vjFMWt1ZgN7ZYnGCcsFbHTGaI9S023uPI1HTLzU98iixkl1RPs02B/rBmI5zjg8g57Hiuol0vQNQtp7iyvotGvvIZm022t5SsIU8bnV9wBwOCFHT3rzny9dljub1oDd29iF zrJeYUMecoS Vz6EY p5FJK2wO60Og1HVdL1uO2sE0CDSdSs0dbaSORwJgGz84ZQoYDoRgEYyCeaZZaNZTTPEL9tO1K3lU2dxf6mlrEpwdyl9hIJOBjcAcnNc7p99bavLH9vt9UFyQsdrJb3ChXYnlWAz vp1rspNPitWa3uYL0JPIIYrYTcwjqTgEgjOcgnis2tS1eS12Gx2KXz3Ews4tWkZY45INLmNyMkZYREbjnJGUyR16Vn3HhW5tLy5gm0Ui3itlke3naSO4jjfBV/LY5K/d3KcHnt1rWm8N2tul1eaXANY08RNFcfZlKPBMwIcMUGSADnGSK5oXN9o8elPeB72yVmRtuqbY54w4yv0wAMcEetU5NR8wtomdTbp4gYrBaQ2kSxxolrLpmrKWSBjkkRFyzxt/FjBXnI4p q2k2n35vrlgLeUZt0tEP7sgnG1iCWC5IIOcZ54rzq trB7kzadqVzFC4QBVuGRluGByBnAXPTPKn1OK3tD1WfS9S wXUV3rGmwMI9Qs5rUo74B3pw3yNknDjBHbAyCL3dtgi38zo9Mv5TBdTS2lrqenoM3EVxeEy5BBZohgBGA7d/erB3JELvR7mFbO4iDOk6EKZOP3T5A2uOcHgNtyKxrbSXitpZ3hsjaQXPlRWtzN5V0jKAR5qq25cjoTkE52nggWFWSydL5hFbJdIVeymjLJKAfnRl27SBx1PHXrU 90HyvsP069mjkmeU2UsqI32hpo/3hU9Qwz8w469a63w/41m03zNNG 4sLo7msbe6mVfNAOx0OcYB9vxHWuMcWskvnWVpcxeVI2xri5DiND1VlCZZcHG7r6jtXY6C k3MM n3KSpqEkIWzt7MAbhjLtEzYJb2PJxjIrRXm9DNKKVpbHsPhH4jX1rqLX4t9Evo7S5AabUNIQtId2WWUE/NgHk9SPzr0Gb4t JJpNSbRX0HRY5Gb7fDoWjxxlo92RIjylyvJIBXBHAz0NfMUFprixfa9Haa5FozPdyw2WYpYwOjMPuvx0Pf04z2ugtHBZXWpXFrrCT3A8lFlhTzYgwyxRScvjngEZ/GqUV03CMZK3Y9LvfEM2v3CazrWo6h4l1udVxf6xevcOybseWynBDDthiOc81UuIruwv8A 3rS4j0ua0ZJ7VRIoeOdc7SgVsBh6gbh19qxfD9pqDoX1DVRbrHD 5MkLMl0jk7QVwcH8yp6ZrRijsbe5eXWoJJoftSInmXBiuRuBLO6BD3Aw2PTPWlzJMTpq1itc MvGtlqEkmneLvEQvNZlZbi k1uZLi6kbqsmCA6kH5sjnnOeo4/TpbjWJGaxs3KiffeJNeszwzA8OCDnaT3bOfXNdCUe9ltrp4ZLe40y 22rtthjnWP5gRgbt47Egfl0x38vStc1LVrlbqBb6LzrKVLI TuyCY5MYAz0784PfNNcy FhyQTR0jvqbLNf3TWltdy2u2K0EiXKv2JOc7cgg89D NVo9c11Hshb6qIrbTHGG3AGNhkYKhzhSCQSuMjrVe4utD1LZeWqtppvJk 06XGCFtnCDPLszdRuYhiOeMVDeaOLWUeUbW9SSAmVoXdjIvdkfjkcd /XFJc3ca5WtNyS71K/wDKubUPFGHuiZoJ7U7ogDncM87STxyOaxb2cXck32z/AElYXVZH/s90Z04/eBTyfQ4/wq3qGpJc2kUX2Nk1XTgYprizvnaS4t2/vxgMCcdSPTpUWmWra1B5SXFjbzQLzcvDK8lx24XseQDgDBHSpSV9RRkpJWVkVIxLBdTzi9u/s8KAbELq3l qnrx RH5109rrcR06XT762u7q0uGaXTr6BwkkTAYzliQ647cZz1rzied4GEFvYGS8icGMeZJG5QnG1gSc9DwB071Zhi0/UrvbeTy2ipGzR6ZakK0cmRhHEgORwcgYppK5Uk29NGbl3o1zfabPqejyQXDQN88Vq4LK2PmD7eBgd nvXm08Go2F7BeWNvIsrfM8guFIkBPKMFPGfp2rcurh9OlR7K/nEjyhro2yN5RXgFni4AGMj379KZNa2csd3bJeXktzdRNJDBOERHJP8IL8jkYHH0p25le5KcXG3U4i80l7qU3FiJyskbyTwLco/lN0bguM8569KoR2Ny03lm7tppQwiSxj2gmMjJwQTkitW8tjZwCOaXT5JEj/ANISGVwWbPQgkfMM9h09aoW2narbxyaorQKm/wD0S8W4dghwfk3fdDYBOCearkl01E1KVrI1tXt9c0aPSLi4nlnjmnME1vEJTPFFtUiRzjaIzuA69BnpT7mHUpbSSKWPUFjSLEcxkEwRTwpz0C9eMjtWMg0GaS6m1aW5S3ljMiX9ppsTymccqjEyrtQj0z9Kfp/i3Vrr93Dr2r/Z44kjs11S7byGiQNiFt 5cgYwDkdfWnOLb0RKUYvbYoWmj3Vpd29wWureOKQBZIkDNIMYOVyODyDz0rO1dmUMI3e5SE71CxHYE/HJ444H0rv77x9HMxYw2V/FgedMdLihbb3RcIN3JPt0rlbm6iuGmkH2OGCZmeG1gjSQqpAGcEA9DkAjBwfSpUUncqVnJJosXS7tH0yS3jt5Nu SW9s7Axyb5ADhmzhtvQcDvnOa1NNkjnsWsTdWN/qUODatfOsRVRnMexxtYkkdDnPSuCtpNTliX7UWJCf6NJLLsA9BsU8dOtUdQcRQiC4t/JeY5MU7fKSP4gSd2D9cVei0CM3Jao9uh0bxH4fkg1LRdT1fw5fzLHLeN4e1dklnjODGfs QXXspooge8pGO/XhNTm8QX2patqmsCxuNsvnX8bP5F1NJxvYK5wXbrhT1JwBV3wj46123t57eHV7q0 yWBTT0aFJY3QYJiYFTuTvznoPevQI/iBpU2nLp/iLwdBqVstiT/bOh6jLBdrJuX94YmZo2KgsNo2D5hnpWTjzPUrnjfa1/wCtbHl n6j4Sv8A7faJ/aWmXaSf8S5ryPeohCklHJO0H0GeOlbEV7p l3sDeHPiJpMsHnW4lk3y2mXKBmWWN0UkI2U3Y2kjgkEE yW hfBzx9DZWZ8Tab8MdddhH9p8a6XcWccZUZWSaRRNEyvuIyHQDuAMV4d8QfhZd/CPxJLZ63rnhrX7aazhng8UeCtXiv7KeCZQyATQllbgjIBJByCAQRSdOSV0atNr3Wvnv92jNbz4/EGsyCXxVo1rqYkkRIzMlrZO5JYssw2x45PfHSprfTZTfz6eL3Qr632 RLdTanbKFdx95ZN5Dgeoz7mvNtMsF1TWIY7KDT7221Hd5Dw3LbCcAH5M7g3fBAPNbKWGq H9aN3ZWsvhl9NlUWEt5L5AllUjzMBiR1xxz tTGtbQjlkfRngzxTonw4OoeFdR8NaL4nn8T2lq0Gu2ujx6pd2MKbsizB/dh234LABlKjDDFfSsXx/1BvClnqXg/wAL6Lb JoBe2PiDxf8AE3xNDr/iJ4gqjFvbuAtkhTYisFaU/MFk4wPzzj8X3 s6sreKr3UdX1i1meKGO51eWRY4NpOGZckR8fdXAyeBXp3w 8Q6LrFp4o0W58V B/A0k/2ebSrG4s5Rd6jMsqoIbe5CExsFkdy0rrHhOTnFa0anLL1KfKlvZr7l R3mc00chZ3UeoavpkNtYa0CLwPavp0LpJnlGuJFaT73U56Ul1rHhTT/BmlWGk GdKs77TtYkTUdSm1WS9vp1PH7iMqtssYBXhVlckElsYFenH4VeF4vFUMHiD4sfC6Lw/qKi2u9c8U KrzxBHYSFB88Z0xCJWG07Rll5GRxmuX0e3 Fvh631rT/GGqan4tt7LxArWMnhPSltIr6wSYh2W4mdXhLxjK74JGG75gMYrrjVko7mcqcYrmb 53/zf4HlcrLqJ1C3SLUJbIXS/wBl6dJdBju6kAfKoGQOkdZF/oItNWsNR1O0ttDhltyDZ396sko/ukoi5x9UzX0nFqXwyljabSfDup3GgahbmXTrC9v5Lm5soVLbVGwQW8jjcMsyc4PTvwPiHU9J8SaTBNDpmoyXFtfeSptdOsdMhTqcMlqjF1GASSD0x6Uo8rb91v8AAtpqOkvwPErWPU4lvoj4ut4tHsdXRhYPeLFbrLMMCX7MxBYYXBdYyRgZPSjXbjQkRra41G11Jp7cmK806F44dwJzuEh3Zx3C1qTaKZpdeNvp1myyLCXgbTJpC5LcsjEIB9D69KuaraaeIbXTNbsnt47Gz/0cafp6SO78YQg3GAD/ALvbpUTg3q46CjCUZXT/AK 8881KWLT7Oyg0 HU7aW8j2XM8SyeWU/hwCn153c5rnLSy0 5 1qdWuVWBGcefFIAx9MbT82e RXs tWHhew8O6Rq6aZ452QSLFfC98M2lvg7SF8tsvnLEde3NcRb3Hh wfUmisdekeCLahlNshjLYI8wGIhu4IGD9K56lOkXHoci1rq qRTWrTaOVt4PMs01GVYZiB1EbAAE/UjP1rkItTt7O4VZoWtbnyTDPay5/ePuOCvbGO TXtD21jaojXJuZV y7rKGXUFDqM qpkY9Oa4  0Szv7YTXgLxTuXN89uSEOCSvoee9c7ilsOUFJanPJLp16rvHD5ckUTeYchwzcbcjIIHY0ujPANSgml1CTR2guhm9tSWki9GRhzxjsc8e1Yknh2IO11o929hMWC7ZVDK euFP8sVoxtPbyrp/7h7izQG4mltzFu565DEDr6c1NpaIziop6nvl58Z/HmlabbaR4rvdL Iei6dCosH8TYuboW8hwoS4YCUqu0YViVTPAGTWEnjD4cwveavrmu MLGb7AG8J6FZ6PE0UV6XBMcrl1/0crn7oY56rgk14xrMdxd2Ml6iz/aLdcQs0weORF5K4znqc9BXIweL7J9Tthq0dq9xZ267YL9sYwOCeB0HvW0ZOFm9hW5Hdbfgelv43svFOvPZTaO mqZG 0SWF6qrI2eNgdSEOBjAOK9A8L3lnpd3caV4b1Qw6pqUL2 o2HiqSEvLExUhUkcAKwZQB0JHQ8kV5LoOh2XiGO9vk1zw/BJaN550 81JIJZcckQdA59gcn0rBMdneDUpL2SQXflstjMkm8hgeh9V7VLkrXWxMoue3fyPrXTtd IXgDxA8Ws6pq91a2bC7sol0YXC2jPgh48jdGemQCARyOua6X44eKtH I0cfjT 1PCXirVoLBZtU1LRQ m3NvMAQ8V1Yzph5BtBLRblb7wY818s EPjn8WfAUaeGvDXizUBpuq2wW50fUdlxbOiAggCVW2KQSCqkA969X0z9qO00HwB4s8BeJfh54VvNC I8lvJ4mn8OLaC8a5s/N8mRGmgka2ZfPfIhaMOD82cDG9CqlK0lv/V/63NLwh0t37fp p8nva2Gubpkt4obtbwswAMRfkYIycdPSvQbPw3qFrpIvLyzmttN1GFmje42xpNtYhgD35B56iuDs/GXhGKyu4NStPEN3dLKp0lkuESCCPPO4A5Lds/4V7vpHxG8J GPDrpf/D TxZa6vDG2m3GpeJZFW2kb JYkT5888FuMmlOLpy1Wj/ruZxnGdrP vuPjL4r6dzHJbGCIPJs zI5LYX It369q5Px9qWmeK/AtjGrappmv6F5EKacblHtZ4QpDSABAVOQOpOc10vxi1iN9VQQollKAWa1UZALHPGO1edeNo7XRvBHhC/F6kut KoJ7i4s1x/o9qspSIk5zlwhbHoRRh1B1oP7V9BVk dpbW6nh pSMsdtbAKGgT5yp4Ld69h8CJBpvhbU7 6EqGW0LIwGB5hbC/UbQ35143awyahfW8GcyXNwqgntk817brsYg03TdAtGCeY4kvSoyFRRgZr05QjCJwpucl2MfTdEv9e1fRPDulRT3upeKr GO3tuMsXcKoz7kj866vR7zWfAPxQmtdXtZdN1nwF4qa11HTmYgr9nkwyH8FkHvXof7PXlw/FPw14nmT91pOvWj2gZc7UgkDDH4j9K9y/4KSfDgfDv9r3X9csbcQ6D8WtDsvEGjMibVeSWMedjt99ZD NfJ5pjlicZLCNauLl9zSa 7U9TC0FKlOfWNvT tj4q/aG8NReFPitrj2SbdN1S5S/02RehguBuBHqM7q9x/Y48daV4P OXgqHxJeRWPg3x8t14V8bXNw4WKPTNXiNu8rnsIZHim54zEPSuY Otp/wkXw3 GfjRcyXNnaTaNq1zknLW53Q5/wCAGvnfQZzJAIySSYz5QxzvXkfyrmpt1sFCXVaP1Wn/AATSvze251o3qez/AB58E6n4H8beIvDGq2klpqnh7WLmy1CCdNrJNFIVYEfVTXk9r5dzYQSSLmS2Z4iy9RkZU/mp/Ov0N/bE0keP/B/wW/aNspFuR8bPhtb3PiqePJx4m06R7LVQx/vyS2ouPpcA96/OjSi6yXlspIYwF4f99Dkfyr9AzSUc0yeliEtWtfXZr77nlQhLD4txXwy1Xz1PZtXX/hI/A9vfKC9xBAu4xnkOmFf9MGvWv2R/2nPEfwd8YWNmdQuRo0lyq3tpJMdhXPQivJ/h9cR3emeINHd3KFFubUMMkrIuGA/HFeO I7GbQdftrmP5FuWEkbA4yQcHn8K/NcRgcLj8LPD1Fp0PUUpxkpxdmj 5bwXoXwe/aA G2n LItM0q9lm0wGSdFCyK 3lGx/XNfj1 0J4b8BaB4s1XTNB02CUQTMpEZBK4PIJHWq//BPD48 IrPwjrHg7TZZbifUdGc2ryPuS32Ll5Tk4GFB/SvkT9oL412WieJdbW3mae6 1yebK0 S7kklifqa EybCZhRxFSg22o6L9D6CeNWJwClPSV7PY8A1DUNY1w3epSHfPHGRcCS4 Zh6xhyTxngDjjit/wAOaVaaVBGslxrGk6vqCqZ11q3VbZkO1kfepJx1OCpzxXynpHx0voFK6vosF0soAEljJ5RAHU4II/lXq2l/HTwXqOmNpeoJd2PmxkSXF7B5j4OOBIp4wB6V pUsxxVGNpw a1PBjGin7r1Pq/QNZ0TRdHMOkX8RvF aPVL9sTQS/wDPRdsnrkgEAZ65r2T4QePvDmmatqGo/ES41bWtOhtrg20nhS2U39xqDxN9nAZjsVfM2l2Y5CBtoJIr8/tHfQ9Ru0m8N JrG8Cx5Nk7gseenPJP516b4fnv7XVoppGjtLNHD3McOI4zGOSAgI3EgYwOTXVSx1GTvzfp Zs1K2kbt/d8j9ANW NvhjVfD2m GrWcw6fpV1Le67dXcUdpqUkpPlpZw3Z3bvky3yqeZCcfLmqnhnxj8GPC/h HVH H2t6trdpNK/i7WtX197eKWWVw1tBbhY12bVR85Zi2c4ULz8gp48vhfrfmPw5E0f8Ax5WT6PGFXPG6MbSN/A5bJ/Cql94uvov JfbzXVrp0bb38P3Z8 2adl2vMcgqJCC3IX5QcDArupYhOO71MZc8NYvX5XPr7V/i1da9fa/rzaRZ bc3cZiNrqUkkzrhFht7f5nTy0VEVVcsRgE9Ki1rwP4Y Jr2 p JtYuND1Kz0D/TIbbS4Ik 3K7LEitEQm0rsLOw3Fg3BOCfmfRPEHhuxhtU1PR5pQ6bmvPD sSAWUWf9ZKzllZz2XAA pArq/PV7mG40LVYdOhtbaSbTk8RWC2fl264KyyHhZJHLfLu9AP4q6HUcp3tfzZjFQS1b/r8DvPFnwY1DwxJqeiprC6wdN1WOOdLHVgRcXJjyBGyAiVUwwJ4Hy9RkV51d E9HsyzKmuG/ik/0jTGVWeVio3FMLgEHOc9qojVbFNXNpYePVu9QjRALiYTYtoyAXO0LtdzlgeexPoa hvB3i3VbayP9p EvBl/cCxK6FqmtMqQW8L4Zrq4QHMjsuflypAJJJIweadJSldv5WNqdTlXvbnzxF4V8D6omoIkOs6TqdlbkteLYx4abbnacNkKO75rz6xtPMNxapeRQm3jLySWChWdQcck5Lfn1r6Il8I6p4lSPxLcjRrWy1ITfZrjT9KGnxpbR8llTgszscKrFuMVmHwPZXWs2VtpOpW qeINRsonvfDVvaKJkmmYLDCGRjvkKlCVxwSwxkZrCrRnKPu6v1KjOPPZu3y/4B5C mTTrPqOjwWt3bWti0r29zLHJNgna0zIAq8sVwvJya5m0sbjUI4kl2SONzPDKilXUA4AyODxpuppiesXpXd6vpNxpeovbaxZ6jompxSzeXtudkShBkIJMDe7YwEGTyPWtW78P6tJoj6vPregyG3uI4bbQ3Znu7mZxvRPLRdpAH8WNoPVq56lDEThqvv/AMyvaUoa30 48ku/D12sEV5cQS6fKYd9hAs C4YkZHGQBz1YVzF3FPZyQypIwui5RpkUt35G4nnJ75Ne0anpusactxrmsaTOVhYPeBQogjkcFVyEOME5ICnBx FeWeJLyyWztjBperCSRRJJrFztkjZccCNF5TnHX1rzqmHr2ty6/l8zf2lKL5kzK1/xp4htjHYf8JLq0FrDhZrG2vhI0gODvwG2jHTC1U0XXprS5czWd7qqTyqLa5hBml3McqGAGdxzXPDUod0zQW0c0KAGQsmJE6YDAcnnknJ4/KrBvrG7uvMmWQKEIY6YAiNI38Xy9ACOBx FcUsDWlHllDT u3 Zsq8efnU9f601PaITJctcWxgnhuYS4a0kQrLFg/NvTqpyccjvim3elNf2dw91asCiKIpZZVf94em1sZ6enH6V53B53MkGoXL2nkeRJbIzyyTRl922QlvulgCeg4zjNdDYzXC28McEl1pojujHMiXe8SRjkBlCkeoABzxzinSofVYXjLZ lv6 Y5NV6iTXQi1WLUtJtYL3SEFsYoyihNQfMcRPICMxUAkk/LipLfRxqW3XLCwfWLOOzSbUYNOXCwgHbL5rLgqWYj73XPpjPQ6vqtpDqBt59S0zULcy7ItPs4TFIUHGXTA2EE56dM8nrU40rSM2l34WudRt9ea4lj1HRNKEkUiqAmDuCskhLyDA5PHOMivUw Lqcqbeq/H1vb70cc6EFV5Vt/Xr9x5DaX o6S1xHbRLbQSyA3aXNxshlZX3DcoI34OMY7 tdEL6NIJRdQRC4cIXltLjzdzuM5GDtGAc4IXGOueve KdEsb/AEg22lXOqs9zbQzas0liLVBqGWCmRt5G0qWw4xls8c14Utnq g3kF3dLdqsbB4b1UEo25IDfKSDyO R1zXo0qlHFK7VpL8TCVGrRaV9O56KuqWahrS8t1Sa5uQY7dUYxKCATtcsTwAc845rUGv6Vo91Yz2 lfZY51Pm3EVo0Mc8OcFvMVsN HpyetYya5ouqu8l7LaYthibym2yT8fM64XaSxxkEAEDqCa1YbG5jtov7AtZdQtLk7YTLeBZizkgARIGUHI9T1HTisZwpKfv6X37DhzNe7q/xPQrd9Fjt7U3Gr3FhHdEkXUduGg27cgFkdueTkAA9OtbMGitrekXs9hc6drtraKpFu14Y7hGbgOIWAkZM8EhSB69K8EL/AGW4a21iDfcxIYjatMLeRHAxjHKkdevPuK3NMupzNaW9vf3FuUlZhBazeXLAxc48ts/eCqDvXIGQK5Z5fGndx/4BpCvKWmh2lhYGK6kuPLhjs442iuzf3aFUycBSSwODnPYD36Vk6jHBJba5Y6dfyW1pZSQynTQhhlP 0gBKOBkHKsrMOcYzi3faprUEVwuox2Osi8QSPDeARylycmRpQ3zqM8btzHFY9nq/hcpDPDYatba/HODf2l2IxbFBn5Ap5A6cAjPPWtKMpw3RM1d6u1tR6eItbWaytw323VEtx5OsXdst3cQFhjEfmAsuATyMj 7g81m TcXcomTdaC0dYtUnhQTJJJklTIASAxAOMg9D1rrG8TTNo0nh6C20zS4VhBGrf2Ik89wu7OXnLF4VH91No6jBzXl17qV3BKsuo3LzTByI9QkiKBQMgbZRg/QkEdRXpwXPqjjqNJtanZadJf2sNxCC8BuLjcsJkID45DeWwOT6ccegrNn8RfZr2LSpImv5rWYm6E0ezGQCRuOQxH4fj2o6fqH2u4t9QvZtP2QMog/tN2HmsCvHmI2cZ5O4qozXplg/huHS7rWG0aK4ujqBiltb 7e40 GTblWN1GxlYMQcIAoxj7w4DbjzWZhHla8jpbHQrWyg0 5udMutFZ4xNBHfad9tiu2YAKsasVjAzjhm/wB7dnbVtriRpbzWPEN3e2WvrBL9us/FcQm384jFjFEFAXByOY41HAU4GeZ1b4i KPEl5rd75usalrmv63JPrWotqvn21xMeeIlVVxgkZdeFwMACsfRbXWzeNq patp0P2Vk e7BvZWl4KLCD8x7jJKoACM9q0cmlbsEE6kr7fMSVbjUTHbaNpwsUnlXz7pybpdynlpWYDaN2csSAvt39qtx4W0XRYNA8PXOm OvGF/cxpb3WjWTXOmwTYDuixyKPPfO0Fs Xw21ZM7hxVx4/S7i1XQrrRrrSdP1OZZfEmtbuttstuffzf30iLlfNiby0ZBIpYIW2x4DbXZATw0fiiDToIrbw3FLZ/aknc6tp8xt78k5DeZMo3MCpYEKEUhsEMOaFytaGiUovT v6 87zxZp0mqxalDfPap4kCRJK2lbbeApEm7YVXiXbj5UTgYyMmvJ59XkNtBHfXV8G02QR77y5ZBCxPI2dV6dTVi/v9W1VYriNLm/a2mjS0lv58TeaD83lle7E4yQR0H0r3er6rfI1jckW17ZgNbw3VhHFOcDna2ApGc9SAcfnCVxczcbljXbLS0sIf7Qht9Xv5pRLGY3YsF7fODhjjnAzzUGl J3ukOl3VjcLbNIA8slu32o4yMEsxR1xg8gN8oAZelZ2jTx6S dbmvtI8/zFTUoIvPDvjC70J2uuTyynI5wGrc1TRrSEQ3S3tpdWN9tC30sk00JkYAj9yCspooge7DnkZFTZN6DfwK/4Hev4c0Ow0CGB/E322SebaDO2xoGJJUE7h5bAMCQcoCfvGp9d8MWGkaLp1joni z1K4N2 dLuoHWGMsTkwy429QMuhC56Z7eOR3HiG1mXTr 1gFsoIM0Vijy4YAb1yDnAAx0NbUceqPPHHEftkEAPzvb U4aMZPyKu0soxnIzzzUyk9hq6V11OmmS5j 2wuwi1AssOb2MhiD0cSsgWReRjPNc81tJa3Rs9SV5ZHlH2W9t5/kUDgFJHOY vRuB24q5a L78SJpGsRQ29mXVprO6jEe1 f9XLs3L1zgY3EDrxieaG0v2e70WadnZQzx6jdsrxA53KsgOHUnjDflk4pK1tNQXKt hl30NpcahfW0V7ealbxruX7SqfaMEDhmQnd3 YCt3wj4e0OXUNt263DSg/ZLS/mEaKQcrh8jeRg8cZ6dTXM/wBmTW91dRXen3A1CCciXTmhYKm3Gc5ZSvIbkcccirNv4n1SwtlezvFtV0 d5LS4t7KBykrcDaxBL4GeM5744qOZbrcu6UfM9SvvAtpq1xdXFh4b0S4t3ky7afHImw8kNguRuODxgfWuUtR/wilzLqVto9kYZ7kRMrXckJUqQTtKYbOdvBOORnIqvZ OvEEe7zdVur2a5ABee6klCyjOADn5up V8kdq1DJY6vbKbu9WyvJ7gskUlwQvnE9UdtowehUnI4Ge1UoxbG53jbY7RPE0 rC8il1h7UXKJ5i2lzLEXOMEtjI3KoznpxznoeK1GWxVpLSUx300bkT6vNGNuxTw/Eg3PnjcFJ45HeudvNOghuJoNJvLieV5ESGFBsJkLZZfl3EAgj5enrgc1KZJyiC60KeGe6lMc8lk2wKMZDtGMZzg4ZDx707aWZKcrf5Gpperafod3HqdhZnVZMbIL67v59ikAHIMZjJIyRhmzzjJru0l0zxPZQXl1ounpqsc8dsl9byNFbTSEEjegBMTgE/MPlO08DqfNbnxRppuIoLuCayhgRhLexz7mJUY2uruclvVcHrwa4661Se6kSWGGa3jVkaO/S4DOxIJUgdCB BHqKauSndbnpXiDR5dH8uyvNMMMjGNobuG5acEOTuLt5fOOew5B tUE1Oy0gTLYQWU8KxgXF3JcSjex7EFUPUDnse9UbLxxealL/Znicy IQ9v5cWoxTMZoAn3chRkqvpzjPA7HaFrZSZawt5tQtlRWnuNThkDPIQBkDcQPpz0P3elKbV7o0bjK2ljdsLyO2e31jw8893AluIL/SNR1LZOjsvKNtxvQkHacenesuTU7Ce 2TXM1vMsYEcOqW6lraVgdmQCvAYcOO33h2FbUdQv/D0juvmvY3VsrxR28CSRMehjk5LIvqu4nByMgmpUttL8VXt3qulxf2fqVlbg3vh6xkdjIqD/AFtsTkuuOqE5HU7gCQWW99SfelJdDubOz0LVJDNd6hbPd/2VKmn dM0UaS4GW2M4AGWJyDggmuD8QRNoslvCl1e6k1pJIoa1ZhbxTAfvUVlzvRlwRtPPbdisJPEeoWcumoQO qWkINsr3dwPPSEklgFwSFJJ9wemcnLrGzt/FYvJl0u3sruExtDAt1JmUepDA8nrkEDAPWp12G7clrnV6LeWsdlb3 o3V2sNpfFYbkQMpZuP3TSNtzGcj5s5HOT0NbE954m0yDzo9PkttOnlH2eG5j3wPyQGV93zDk/OG74OeDWK9l4nsdHh22a3 hSyMjWsV9FIhwwBMijGHU4 YjHA5qSy1jxLp2n3OkQWuumzmlP9pWtjchV8rg7XUqfmBKn5uOhx0qIzlFltSttex2OpRW9y y3ZoJYkQR/aZVM6hhzuIwWXcGwwI4HNU7TQi08h x2szW9uXvYrOYIxjXBd0WRwzYHJCnpk8jkY2pR3Vrcw26aXcRsbbfDa3V2k0h3n5W3ogA455x3 hoWc5iniLTLZy2biS2lE/wB1s9mA49fbHbpVKp7xnZt9j1rw/wCIPsDtZ22sPp5YrP5OnXckcUh9PvY6Hp1OT3Fdlb3Gh6vqNzPq93aJdXULR2UFkjNEJmTCI8RO0jdgk/L1J968Z04WFzN50WoR2lyJhJ5UYZUncY2mMLkKxyOAME mMV2kdzrGn2YmvltFkZwLWSXTlSVwckF8rknB4c/1q3NSVgjHld p6QltFoyD7RcSRfYgXubKWxeSOd8YDoRwcE8OO/0zU0NvDPaqsEt0Ptu/7Ks8v73II/dyAd/m4BP5cV59afEy nsF0/UZ5rq4tpAumzXloCLdEYnBQ/Ln8vfiuxl8XNdapZX1pbrp2qm1EuvQrqi2cKhsgNCEA8s4I4VupOMU/dtqHNez6mjZWOvu pW87m2jJQC5urtN0PIWNfMP3UOCchhj1qlrdhrVpBJZa/YXtmkwQR/2jp5Qy7cmOVGYfMvLfdyGzwcVp6j43vNZtrC3tbzT7ZdMT/QpdNs0t5mwD8ks6KHkIzjJYtz1ziuQlv7q8ljbUITLdzIg0  vbiRlwuAFyzKcDqCTjjHFQprbYtvmSK1u1zCsml6zZyPI8Z y3CFVilT 6D1xjH06Gr0WsGwhntFsL3 zpxGFAXzFhdeepGAMgc9eT1BNdMl7BNAdO8QPa5LbEtBYjch/vrg4XqckNk8deCKn9m3Gj3ctvcWexkvlWOLUmCs6tkxhgTvB24 cAehPTJezKlytadDEf7Os1repHcW86YP2i1ucMr4PI2j5cHvzXPTQx3LXMNhGZM3G55pJAHZgTghTH eSc8fWujvRPcC6lsUkt4x8/wBlYIIIsMckkknGT1A/nWZfWr2ixT3VxaeWpBe4tDvaNvXeBxzwO5FVZ9RJ30MN9EMsc 2IWM0MavFZy6iAoUHnajABeQepxk1lXtjFCkUw0yyeEN 8urYM7bc/MwRjtLKQBkYHFejf2xod9HbpqsDyzW07xi6MRkdV2ZSTCkrtJ/CuZvllVr2Swhubmycgw3MVrFHHkHDDJOQGyT07Ck7p7CbSkcdcwWUAEUkMhMigWbxjcWj567eMEj86saRE1xbXhmj1PyYXB0 50x44kVh1BG07ivccHHetJdWtb2WG3MK2k024RmK2Qtnsiu33Ae MDoO axLeyFhDJBcQX9zb/aH8l7apen 15Mx4YMMALyQM4z0Naxi4q3UjrodtKmdI2CyaRJtu 6u5TKtu 4AhhtJK9Dn3NZuowPIlvbxalIZHUrJY6K8VsvmIAA4kkjbcpHOOMc9K5izdrPzre5iulhlLACCcCNSB8pBJ5wR/k1JI2p6LNceXdW1obq1jWVIvJdGV2HKPsO35gM9DjI9aI/Fa4LmmrLWxueIvB t6Ai2FzaXra5emMzaLeFpZRkZ8zCJheqkZOTkY6HHnUVxBHrN/p0WqSW0Kp /mvNKd40wjLMDCd 4jJwcZU88Gu9u9Y13UNK wQSbobLEVwmmXEkq W43eWFjIjUkguBgnrmvENYsLuG SW2kaXCmVZlYtK4H3lZuCGxnIBx1q0rqxFSzd1 Z6Fp1lNqOkyQfZ9Flksot4vE1ZYyYsdMmbHIxkKM5rno7y5tr42ukadpsqp5co1FYN5KLnco3kgr8 MAc4Brm7LUp1haA3UkcFg5Nos9v5gKuRvVVO4fgxxVu7uVaJ1a0uII7iZWhn81gIwM7giKQADkHO3PAxx1hb2Y a1PRnX H28Valq0mnWc2rW0ztv00WN4YQJFPDKFXqGGRjGCPauf1 bU9a1RB4o1DV77VLciBrzVdWacjZ8qplgxAAAAGeAKbbS2Eqjy9V1e4uxL/AKHFPCEUE4BwxLDjOaq6hp8NxN9nTy7h5dzTXk7lPKlyflOQobnqeeDSkuUIpW8yrHO1neNDZyXE8drOR9pVGRWHbrg8jsa9Ot9FbU7FZLO1uJbldMae1Fpeeduj43RsFyVxnuwwcAjOK8qsJLnToWM5t1LzELNHNwpU8H 7nB9D2rUtNYuYJFnVL9Wtiskc7REjcCMYkUrgY9KG2o6DT5dDft3S4jFpqCJ/o6zeRby3YtZZARwqvhgRkcD736Y0fornicatesf G447NdRjsor8Rywt5TCbbjdvHOcZIDbMj1rlJ9T03WNTZ77FpBMdt7Kjee4J5RgpH94885/lVu1uY9Lkms7hUu7aeImArY YT2zlSrqcDOMgDnrScW3cuPvO/Y5q tA8v2vRYVhvFugUuYJfLJXpja3f/gQ gqK8v8AxOiy6Zqmv6vd2dm58nTdR1R0 zsR95IzkAc9uOldBbfaLYvbi1LQGRJosOc4YAEBT1z3X39K14bHT9S0y6hs7VtR1hJmmjW0tWYCBFJkO0E42qpPpjPTFZtRm7Dabexw mzXAhJurd5kmkIijjtlaSTA4YOByOvWtTw74a1C/wDEej6joyQaeZNSiRX1PxFa2z72IXrKyhByeSMDvXrPwxudHfXPDlxd/DzStUuNMvraeS/t9SuLeOWOBg8gkU7lBZFZThDjOcHGD9V P/hPP8QIvEcPhf4F6pol7Lrj30C6VeXtxDb YXItkRrJNoCYOSwB2MQPR8jua04RqJ66/wBdjzLS/h/pTWE0/iLx18N9Lj093N9Z3PjJbq6eXLDaIbbzDnKkdFGACcZFejWlh zd4duYpb74ra1qcr6VDsuPCPwvnngkdwS8b/bJbcgoQo3BWB3HGcc Y JfhZ45 HXhvTrXxJ8L9d0F/F9gNR0fV77TL6ef7AxKBolYpF5ZaJ/n2sSQw3ccMt/hd4p1bw5pWr TY2FhqKzR2d9rXiix0 2ZoU3PGkc20qRtPVjvJ2gZ69MXOL0/Gw5uSdmkn81 b/Q938MfFP8AZr8JXOjz2vwX JXj28mWQTT6t45sdJhmlY7VaOMWE6hMF8hmzyCCuOV8WfErRtK8Oy6tofwP E2h/wDCM OD5tp4v J9xrN7d4zIsT2MN9GGttrKrSRRKGK/K3UV414I8F6BeWmp3niTWPClqnhC/sxcC28UXNzDeea P3ZsoZ0KxgZf5lbBGzJyK4/4mX2iQeKodO8JHQ9Y05ZN9xeadZ3EaTbWOPKW6RJBkY 8Mn9A71ua/X1BVXGm03 X5qx6hcftB/Efxfq2rXvhvQ/hn4Rtr1IvPTw34Bsbe1hZCPLFvLdo0kXONxDgt3zzWf4n8cfFLx7fQXPxN8a6rrBivmXyINUtIoV6bvKhjaNQCoAyo2n1rxaSXx/8O7mO41jwxrWj2uvwGbT7HU1ubVLqAr8kgHmpuUbgwI4PHBqQ/EKyubq1gXwZqVvLFYNDdahp/jy6VrifyiPNdZA6g79rlQACAVGM5GNW71k9SaU6bbUm7rq7v/M9wuPhvbzWqLouneJgl8olSC8jjuDK eGCmQ4BPTJP45roE DHxLT4b JdT/4RO91Dw34bvbeXxNrEWiwF7CSUFYlmkV1cq2AcKCMjmvA76z1NPB0/jH 0/HELJfJCbtNCijsQ AWRLgTZ34YdVyQQa5CfxCdR0yS ubrVdQnlu0WKTWPETTXRbBySxTI nNKPI4K6TQ4T9nUTkrr7v0Pbr/w3L4QMb N9E1OxOqaBDPoVrDKXgu0kPyvJKLo Ucc4OTkcqK4TUNQtLizs7PRPDVxZ3HmsJ9QvZmu3dlJ35hYvGFOfTPvWHAb S4RINEkWGGybY0uZoiCpxgmP7xPfA tS HvH qeEh4Zvz4S8O6la2U8qW82p GbW4D7gQxl860dWxkYJDEdjWspoogermc6nNstPl/wDDlltDcTXz/YIES54jOm7Yt6gfc25dQeeAQPpXHvcG0v76aOOxv0vV5tphv2Bj0UNlh JFew Ib3xF4nv/7UbwnoNqNf1LEFzY6NFplq235QFWKCJAxPcdTjpWFfnQ7NYodV0K00a/sm8u Wwme5 04ckuS5lUvtwAFKj6GpnCV9Oo1bkur2PO7q70eGVY7iwRiuVla6L3I9lAAwOwxmpdH G2n NY77U7rSNLeQR VYac00UU05Y7f3af6xsZ/hB4 ld9NaeHdRkuLjWYwcWTNZhZTp5ducKFRJAWGSQWKqcAEjNcXpV5DZeKbCLWNHuNR8O akkOk38ptfOBGB  QPxz6OB6dqIfBdEPmizivEXwd1nwRp0 o6Lp2paRqNvOFuNMuR51tIrAEBcrlSQe/bFcdo/iTT9Yc6XdW7aV4kgh5t528tCARgq2MEZJ9K 49f8SaBpvhS6 w6T4lW01eRL2HSZPFElxa2 x2ijjaFYYoy4AchwmdrDGMkV8 eNfBPh/xbJpTeHRNdXdpbs08MMC299A3Vm3j/AFkY/MDkgVFalCMUzRJTfuvVHnZtb25nnuUsUeWAbpVtVx8ijnI989q5e98NaZPKb2OPUlkmj S1WAShZOp57da9Ant9a0aKa01BZX1OxI33CSsfOQjGMdwK8e8ReIr 11KGKFpF2QbpY4mwoLHoVHX8aKMpQd1uZVIpq8jrrHwroun2Bvb/AEa6u3Evllrk7FJ7Y28E1f1C2urcr5yGPwxZQGSMQsAu32GeuR61xulapearex2jxzrK WAil8tQRycr34pfiy09t4ZjBhS0SQIhWBvmbHOcjpV1q8pS5WtWTSgmrxZ85 P9Zj1rUby9 zx27zS XbiSQAJHnCnH0HNeNa3cQz3zpbT3E1rAgjga6k3MAoAOPbOcV0Gq3zTyTC5Z3EcbFGL9T2579axLHSReQTTETlLbJlngjLqhPTdWmHqUsNHml6E1IzrTtE3fA9kLnWY5QqKlovys7AYYjGT9Bk12V3M11dahcRLuaU RAC 449QfoPyrE0W3fTdOFzDcbZmgcll4LlzgZ9goNd18KvCd34x8ZaPom8tbrcmbUeSQqY3SZ/DA previKUIOpL4Ur/AHHLGk4S5er/ADPX/hjpD6Bqfh KZNr3JR2O0chhkfLX66/8FWfg1P4o/Yo/Zc/absrKWS48C6hpug JLsR5Jtb/AE9ZINxA6CSxuOv/AD0r87hZxT PLe1gs8vDKqW6bumOBjH4V/ZR8W/2OLj4pf8ABD740 DJtN 0 JPDvwf03xBpcbQlnTUNLt47ogH 8IvtK/8AAjX5TXzGK4nwlWWim7P/AAy0/U mybDupi3Q195NfPp J/Cx4ejbxV8GPiD4XIWS50aKHV9MQgFi8B2zEH/cCV8jaRM1tdldoBikDKCfxr6n/Z/1TyPEmnaVe/Nb61DPpt9HIfvCaNosN/wMJXzV4m0uTw54s1bSJV2PY6lPAwK8/I5H64r6jD03Sq1aL3Tv j/I4aiboqTvdaa/16n6W/CjUIfiL w58V/h1Oizar8B/iza JtEQ5Mh0fXrdLS8Ck9I47iw084/vXOe9fmxMBY6yGIKrDdYYDjjOCK 4P2DNftp/jW/wu1ORf7F/aB8A6t4MvIZTlW1O4i8zSDz0I1KDTh9MjvXyB8QNHn0fxJq n3KPDcWV9LHPHICCrqxBGPUEGvteHZfWcnq0G9Yu69Jf8FP7zzMVH4Zdnb9V Zt B9QTS/EtrFIAI5ZpbOdZG4COPkPP1FbfxK0VLvw7JfRLi40LVSJc45hk5/Q15hHMwuoLhSyNc2SSRMf e0J/wDrV9EWYh16KW1mIa28U6CcNjIE4HHXvmvkMWpYbF839aHXSte0nofXn7BXjO08I E/ip4uvZokh0vwZLBD5r4Pmy8Db74Br80fih4vl8SeLNZ1DzGaO4v5TEN Btya9r GPiG70b4R/GnQ1cxXFm1hJIm7nYJWRv8A0IV8lXkiySySHl3Yk 3 NeblmCVLHV6r3lJfckv8zoq1W8JCn2bKpdCuGJHPAx1NBZdjYAPTtjj60xlPOcfKOMHNB3fId2MEfT9K9e2hy6Xt0FSSaJ/MieSNxyrqxWvR9F K3jfRPLji1iS8ghUKltqA85QB2GeR dcLAsbQuzHJH3h3qo6EscYK7jgVEuWpozRNxV4n05ofxji1LUNPi13TIoZbggLcWc3ybs90 vHWvfdMePWbUyaNfOJraQtcw Vztbknnt dfnKjyxyo1ujtIhDAxnoQeDX0v4K Lth4PubLUrp3nlktAl7p8OC5YdP8 9eNmVfNcDyywq5r9P62PuOGcJwzmeV4hY6r7OtCzi7/ABLqrNatdLan0VI2pWm2 sJwgtnXbc2jAtuznIXoevfIrrJPGWpzTLfXcml393ej/TX1TS402sOBIqLhSQCeSODgjpXxZ4n InjbxJe3OpeFtKvdCsCzSwSRs2QB1OehFet/s/8AjOfx/c3uh JZRc6hYqJILlol3MpOMsOhwa74ZliqeGVSrBab2d2vU8D z4YjFOFN3T2ck1e3qfZugeMfg/Y6XbxQeBdQGu2UaLpmpaneNc28s4H7yd8YYlhkgFSBuwOnMn9v6RrJnsrrRLwaDIRM8Wj63mJpt3ytMJA3lKckY 8Tjr0rjL/4cX6SC50 5ErGPAJba6gdNoPA/CuH1jw94i09t8kS3ESyACOZ2AXHTBXHvz61vh Isspoogee7O77NmdfK8TQvzQf3f5aHqV5Jba Lq/17xRHoVhaLINA0O4vpZ5dqA4d0IGwHgKrBc4z7Vy/hjX5rSbUIPDlvqd3fQCOOw1d3nge0i3lpJ1CkAyPkYB 6vbPI41b3U1KtqF3NPJA/8AoUN3b aAQMAAnJJ5OODWwniPU9GgtbaHU9Xitp7hp7gwXRdiXB3A8ZVh2OTgdMV6dLM6Emle/wDXc8 eEqJN/wBfPc9e0nx1r m6FJL4n8IX1v4Ktb82t3rlk8gkiaRCGgVjIQZ3XkqGPA5GDXNa2T8RPEOi3kEUNnY3ESjTtViZoxFFD8uJHduMAhWK8k4C9hXmEOlrq9tbol0G0e0n3PEl9kRluGOzby55y2dxAAFfSVn8QfCuh2a FPhrpNrJBHoxXUtX8UWL2t7d3aozSXBtwxWKJAQkaCRicbiAWYD0ITpShdPU5/ZOEk2tO3f8jnJtP1Hw/wDY7PS9X8JeJZ7uLz7qxt7lftkDJuQrJI5aNVYcgfMSGAJzwPC/EcuvpqQ0 /h/sy2s7lmm8qzMTpK3zFpGwWO3rxzjGMV9MeHNIsraaz1HxZrLQ6c1o9zNbak0Q1LhMo8cciHJJI2kE44yBya5DWz4Z1aDWLXw/wCCr7Vte1pJJz4iOoy3c8MgQOE2/IglO0hmCuOT36ZTUbX3/r5GqmoX/JXPkzWL200fUZZ9Culm0 0bK3UyNBLd7yfnEW4OBhT8wHAODzitCxtpdYtGuLXTVjttMty qTQqXG9mwGG0bj/Dwx4Oc1tXFx4RuIr5PEGyLTLMb8TXAivrqTYQYomEb4GefmwAD1Jrp/Dfh7xL4wtV1nwUutaP8JdJvnttI17WZVgR7gqGa1kuEjWLzNod8uVBVScmuJ0HOV7WNKdSLjvf vwOM0yCe3e3ur6G 35VYy9sq7dowodcccYyRz713MWpPY2bLJbaS8i2xG2cP5qpuDNIg6Zbpzu79ODXnK3UVzqt80uvzagmmXQ8m9W6eYyPkqerfMny8tnJBABrurLXY/3qI5kW5ZVWQWxVU3E7Oo3FguSeoAOOTzSlhas4apMUK9NdWiaxvYryGTdo1paXBRQt2VZo3aRhukf5cldvGMnkcdhWnplxaaHqVrONLW bTHMixmNrRXkYncCqHftXAwcg8cgZqlpF7pyreXk9uG/flDEIgJIArfwrtCsyr83JHQcCpLgruOq2sTT2yYzLcxiW3YdfLDfeDkhs/L2PODzhWw9RJq1k/wCvU6KdbVNO9jvvEuteGoZLiDS9IFrfyLHcyeINE1SSdJrjLNIsSzR/LGy7TslEhyrMGUMQeC1HWdQuLJJ9BvPsV LRra5iFiiJPE/3wWQhsk9c8EY4qPV9bvJbvUNPsIrS6vXkgEQ02yhtTDCemxQoLZJQZHJ71naVbvp2q2F7JbXGLT5tVlYkgJgAkpt6545yOM5FTRwbhHe/4/mKpilKpfa/lb8i3qPhaLxDI99fytBf3untcTS3NmgtridUICwLGBtUtwST1X1zVC21F/DrRPG8F5rFiyLp1xPPFPZxYXa4Nu8bCQem444HBrWfornicatesNbyatDDNp0emynelw2J2BJwwj6EYHOePXrS2 m6fqgmine7SRoxKkstsh8/K5AHVgSCMDbgeuK2p1JqnaorLsZz5dOTfe/9f5HnZuIpCsk lrEzZEsttMwt5FPRjG38XB6YzntgV0GnR6RqLrFbal9geC3V5ntlaACRTkkgk7yCeo5wO1dDLpsl3MNHis5r 9dTJLb6TI8/krCoyzqQoChRn5d33TjHbUt7UxW10bGw0 6kt2iFyjvvgJPJUHKkAMVU5BOejEcV1yqxjC60/rzOeMFUld6mJqWo6/dS3d8b2fWZQI/M 1zj7WqKVUccB1JPGRjJHJbrzAlsNQ1ANqL3dvNEBuWRQsmWHAUHg5Jzzjgc16FfQajp8bXOs G7NZ/tAcTRb5hCqkg8BQNucZYnI6 9YGqxWVzLBFFd6PcWsF4VhiL4P7xATiTlwg4xuBBJ6msk4T1a37Gkqfs15eZFaeIXsI44JoZLmMEAzmNoZHRQd0fmjpweM8EjpSQ6vaPHNbXulXySszfYdTEsU0RkxwHEiMNoJY4yMZzViK6heG2XTYLjUmurdo7XTJUXy1IUkeZKVy3zFuACcY Y9KwrWaw1KGbSrhr 1nNtI9lbWMiTQMSfl80HouMgnPy46GhU50ndLT uhDkp6NkD Cb2G1stQsVt9YubrTXuptP0mOZbu0ZCSw2mMbsKNxKB0x3HOMK0uTAxNxPcswP7/yZXjzjOEIHykj3XrXQ3tjdC2t5Vso1aAiR5I3DOABnazDlRhc gFaL6tYPbC21WzXVL5iHtNXS5U3CMFJKuVAMiHPVySNvFdEaiqnPOny62L meJodP0 O1sdM0aRb0g3F9qKZvlI 8IguEVSGAyQWHZhV95b 0dY75bxWNwTafaBvljj7YIyR/vcntgV51ZMdGlhkuL2DW4nhKx2du0kcLE8OHAQEYBHIU5wea1kuLOGKCW3e 0GZrbfdxuu6PdvxhSBuAIIwOvHfNatyRnG/Mm0erWcNkJZNPuJNS1LQJYgbiOKXyUdMA V5jqGBDdRz0yM9abq3grTI9OeHSo00aK8uMxWmqW5LBmBKhWkII4xjknHJ7E8PbSJreqiPS7zU1u4iG0y4 yhgztwFMiP8vPqDj Xd6VbanYxW0uppN4m1WKVrgN5QntFfGT5ko2scEtu24AI61nzN7midnpsbsfhLxB4Z0/TNTlePUrO4jRlFpeCR0kJ QvGwDKQcHqMZUcNXL3uim81OfURaX1pqzKJYLVrN7iK6xjzF8l2yMEMdysRxjHepbjxTqlxqOpahfXvk27FHvobCEQLG2fldYDtwBuIBOcAnaMnNdJdeK7ZorC3S2mTSbOKIrqNlEIb2dGx5jJFIDkEKBubbnABwBgu1mKNS5g6teWWqCxtJ9KjtVgj3Jp2mWzNAwC8SFCfvEljx6ADpVWHQ7VLN72W5k0zTnucWzQztJOx5 Xy GTgHl/lPfBIFdHcz HRazppM rXs oGOSzjt/wDR4rFgr5UqwO9m UBldcc8Hdgc5p2lzXpuVg06/luI5ctKrCRQvLEeWuCSQuQTngH1zQ ZIaspOK/U5y m0nSpo7ay 361ZyKSk9zGkKpI2MHYjuowR32k4HStiySeazuNStZtPhurXYY7J0MiuVA3FYiWPTGTnnsDio9SN4zSW9zpsNrcW6K7W8VssM8eVwNxZQBnI U/ngCubeFLjUEkMn9nZUbLeRwssrrgHBHykHnpj8azTs9QckolmK51/VNRaOKW1tpfnmiZUt4YsRpuK7iAF4XGw/MTxgk86skOuXVrHNqSS6fpDzNuvYYo1gR3XORt5ZuMcA4GR6isF5FjaaSFTbOWzE9qGIHP8a5xzz2798Vp6dHqbW 7UY0vdPWEK9w8/nMncGNiMjgDKt04wRmnyqLbQlN312HxWN/cGFbiexeN NO8uTc0jN90BsnIx6HaM84PFaN5Y6ZprT2t27pdxgCexM5V9xAIOMHcp5PC4x3HFTpnTLBVtdXhubWdybW0gtmG9EYsDKuf3bjrkMWGfTmqFtcwXmZUhFpq0LPKkzW6tIxY8t5jHI4PUgkY6nOaVkynNQ2KJtljuVt3tZrYhDLKhuAqtxldu5ehGODn6jNZl1PZO5uHXLb086O4U/KvUtktjjjBPGOnrW1d3etWYihurWCw88loklidTIx53BlUgEAjkbevQ98u ZI4S5hurm6MG0wSWrCLHckAjHsR NNWQk5OV7FO3vJrEzw2d6EOpkiTazISCRgFuwI7vuHuDyGZaAzCCWW2ADi5lh8xkUdi2BhgT0dOPWqN0ls8FqY4LmF2UyXCq Tg9NiA5AHPIY57gVHa2twbOS2iV7qS6lDLJFaP5ibQceWFIB6jIxn2pW10LSsdNFFJdGK3gkbUZklBlmMUYIXH3gHIMnPfOR6mtUwxf2h9m064tY5pI1ZzDdhoJjgBlJziNx3DHqOe1cDsu0lVYNQuIY3jZbiNS6OgYYJITnac4OPfI9btzpk lWUd3qEkWn2MiNnULoeUsrIASu7OHYeYvTnBGcdKcYyYXcdjqNP8MaYk1/JdSX8V9DIyx2ltb4ZwVbLMuPm2kjO0ZH5GuTTX9S0S6MUD3lwschVoPtWA4YYBQ8hWxjJH4jtW4vir4dN4XnmvfiLpT67psjS6PbBc74lRsxecoDq 4IEVkx8x Zcc N3fj/wZGLhYdXuJmKEOBYnbIx6ng8nHfAP1rohSrtXtp5mUp03K3U hbfWLICW7e/uLuK9BjS2nnww5Hy3GxQcrwyyjjIGQcnFzSVe1l 0RJf2UFvMZFlW4RCiocu3muNr5BOGHB4yK ebLxx4Jk0fULpteh/tO3eIWVje2Mu VSQHUkRlWAA7kHkYJ6Vu GPHVjeakk2lz2l9NEgL20qgNECRu8kFPkHbBUgZOc9aqrgqtON9PvT/Jmaq0pK36f5nu9xpMniXTNT8W6NqdtaX0byJdKjr9luW4GYgCfLcgklGxu5Kn EczZ2ur20tsmqGSFLgsZ2uLdXTquAzFsAkAeg4HGcVy1kLayu1u7PVNOjMl4VfS5MoWUEFSQyhCG3Y4PGD04r1261vw/q/mRStLo0AyZ9PsYdyBhkfISxLKGOTklgc9sVyTjOO6OmDhKFv6 Y59VtLi1ghgiWS70xnEluIY2intx/CU2gOeeuS469gakmk1e3ku9Si1e4tTe20aTQf2k7SIhxtRgW3bcZA78dO1cne6c kxWL3ZvoLMxD7BqNg4kguFLn94rhgBtzgqT27HiulkTwyn2aQ IxJayoQl9I/zxFcArNGu4nBPB796ylF2uPmintoadzqEkqLLJqN68K2yIILi9kmGBwu5sjpgYOKr7LiVBunYwbCZpJ1A2SHoQS2PTnBGKxIDBaCaae5guluQ7JcTW7bU6gAlSARgg4Ix06Gsy3unmiubuEhNMt32h4ZAmGz2Qtkg8/SsoKpfUr3HHY6G2h0q1SN59QWWeW8dJIEtSzpgD5 RtGSccHPfHc jeG9St5MRzSQm2iBwZo5Jg0qg XuDLgMOncDjPFeERTSea/26P90ZFKP5J3KhyABnquR FeneEJ0jhcG9iiJMjJ9qtwFLfwjIGc4x8wGR9K2jzISdj0Owm02W9e61HUUEdy5hS3tGKtbz7Rt85MHKgk5x05I9tGA/8I82q bog1TSzF5aajDcESI4JGUfb/qzycMp68Yrhku7qGaS2ju7WCSRSXN0yggZx84B5GehHI7elXDrk6RHT7kSSWjQpmSNd6ZHdc8so5 X/wCvVqLbE7LRne6LeaPqEMh1GBLW3RPMube2XyzIoAO7PzNk7f4BlfpzVu7TwtqbTDTLrzpjau1vDd3IiQnIIRppWEfAU8bg3TivLVhSa6RrK4hhjjXeZbWdlO9T2Ukcc8j3IrUi1OO5nhtruOxtpJB8zWen7RMuRuHy4 Y 5yM9alP3Q Hqel6f4j0HVIm0m6uzbQJA/wDZcaSLcfZplGNsjACM5YAjDYI6ZORWpP4j0q3zpy2sGrzpDiCznkaK0mZvlUQpDg5B Y/Oq5Hfv5fb6daJc3wtFi0y5gQNcNcxBritish cigaretteBzyGQhuckYye3appbaWzuTdSgXN1bCMy30MTSNArEDzTtyNucYHvgVcYzYr8r8ifVPEcmpywq3nWjQRbJLQPsTYvJCA7sYJPGTnnOe0cOsxzGTTo55xHGFBnngYwpvHKEt6juBwc98V0EV74Z03R9P8Svo9hqlvaXCNq01zciN5UEgBdY94B5OC3OOeRWLc MvhZp5/tK78U/D60Z0kMUN74hBkIC/wDLYREkk4IwXIOeldVPDV5OyX3GM6tCK1kjMGg6sZbhNJkudYtMssTR2ZxIOCQyHnjPGRW/pej Ki0bxwzwxXMQMz3WnzqiKp2qGxgLyMZzt4NeU3P7WnhPw7Z3MGg2lvrt7cM5hOlaQbhFfI2s0jBQCMD7p5HWvnjxr 0t 0B4wS5t7Txj4n0DRbxfLbTLDWXRGiOdqNCr XgZOBgkE8GvpMBwdxFmVPmo4eUl3szgr53lmHdnJX9V/wAE tPFniDw14D0rUNT8dRi2ht5yLcWkoaZ5iMoqxs24o2RyAABgkkdfG9R/a1 HEWozT6Fpfie2gjTdbNPa2aEyt/rAwGflyWwOwHvkfEN/pPiXVFEWpX o37R5LzXbq8jE9Szk7mPuxOOlZ8PgS5mdV2THPZioxgfSvoMN4acUST58NP7rfqedW4my StGsl P6H2reftffDxTfpB4X11IXJFrNE0YLjqC6ljyT2yVHYd68 k/a1sfIe2tdB14W7gCSK918bJQDnlQmAAcEDt6mvniLwBeHA zykbeu8c8fSo28ESozCSyugVXgs/X1x8tdsfDXiG13hZW8/ HMFxLgZL Oj6e8PftX EbO78zX/BOqatp7xND9lj1ti8akcOrDZkqc/KcAgnPrXfW/7Qfwq8UWumWv2l9BltrlvKstahk8u2VywbyysmwZVIicdT3OK KovAEsoDLYXQVj0aYgY/KtNvh5KqxGOzZlYZZhMTgD/gNRLw04jqfDhpJ ppDiLA7OqrH3s1v4M1eZJtN1CNWlhWWCKzkR7YcAkBvMO7J7kAnjgdK2/Dnhmw1aWeOaOTTppAXhe6iV45FUj5PMyMHPquOfxr8 tO0XV9Enhk0 XWbJ7e4EqfZNUKxhwMbihXaTgY5HIr3rw78fPiH4cupp9c0yPxRBJGAkf21LQR56sIY4gjE ny968uv4b8W0E5fV20ux0UuJcslUSc0fX0XhzSZ9Lhsp4vGTX1k4ci10Oyngij3/vCjmeM9AOCMDJxXPX58JW9vKt3oWuanZvHi3vba6 zyQEEA cux COwPrzxXC Gv2jtBmup5Lm41Dwu9xcM0ya9odvPbgs dq5jdFVcnGSRXvvhnxv4C1vxdLYeF/Fui6naa5otrBc/aHsN/24iPzzH5csEaJv80KS4wpG48kj5LFZVmOCk41qbg13TX6fqetSzDBV1dVF8v6/M8VMWnzRP5SRW mmclYrrUGURLwA SuG6jkkGq neGtFkurN7jW47O2mleOcwy2dy4wCVwhuI3bLbc gJPbB9f0rwXeeNvFl94V0jwympapr3mf8I5qd5cRWMPloS29280xqxCsAS7Lk9ScGvOdU8Pax4b1GfTde0e80a9IdVN3aRNMu0gsP3iEjBHGApx0PXPA4vsdCklC6ZymsOtrb2tteAzxxTkyEgDIB4H32XHINNstNt77TjqMOoWtnNBeKJrON5RKi4OHZQueoxkBgCRnqK6TTEaa6u7WSSBpZhumsjpe/zY1YFTG7Y5JGMgjcDzwcDmNZFjpU32qM6zbB9XkadLSMweVgExhPnIK9cjtjg1EYyb0FGTs2dJqek JNPS2v9Z03WbW4NjDNHDrsjuLmzlXKSISqnYQSR2569a5Oe2vb/P8AZmkrNGI/N8yP94IV/wB4HgA49x611Nxq3hi98OW0EOs I01aBZE wXFolxYTIH4MW9la3JBOQFkyRnIzxw7T Tc3R0q5uYJzABJbTqBGM8MB8xAz9FJqZXizTmU9l Zs6ZcXGkJPCJ7qKMyK89qtyFhO0k4znPr7817j8M/Ftjpnia21fRtFvr 6s3kuI7dtJg1eGExsDiMTJsGFxkOrdPTkeHWN1prSTWmpW/2AxyOr3OkXkckJY8fNl/l6 ozWlplhr/hyaw8R G9Y1zSDN5v9natp0U1u5TJVv9ITaSMjHBNR8K2G1zq1z0/xHqt34v8AEOo3upWs2mW0jeYJ9K0EWdujPKzMGigARR8zYAHIUKOldtN4Z GUfhG21Lw1qXxH8Q3VhrES JLy98HPb6JBuiB8tZllc ZuDKN2wsoBwOleeWPxQ Jnh/WrHXbv4gXviCK5jiFymqXE15HK4RliE0NwCJWX5l3EHA6Gu41rX/ihdaLJ45tdJs5dNudYju7/AFFPB1s8Mt3KWb51mtyrAFCCi5jBB4NbRqOWjKuubrf5P9DZ0/x78ONJ8F694StvA15r saldh9F12bXhbRWLBAGb7PFF8z5GcO/Q4PTJ5Tw74k8F GdM8VQav4aXU/EF54dlh0K4m1BFENzM4Zrho3hYMNuVAGw5wcnHNDwl481bTNG8S6bYppVkmsRRfb5Nb8EaU8hJbc/kzywFo88AeWynHXgV6p5 jjxBbT6Pe Kri51TwKlp4in1WTSh50IjiEEUBibZ5SvbqDvJfCspoogemqgoyjq7JGkKje7s15f8A Z7jw4fDN/ai6TSpGv7KO4gg03VoLmJVmXpen 15EbHy3weUbDA9QK6nT/DGiw6LcaxbxXU2ptdGKc RL5dszKSPm8vY27a/G4/dr07xjo/h DwX4S8ZQ LY9Z8WeIUnXxfpGr3p/tBXUkJIcK67SGwGZvMyrHaARWCzeGF8HaHaR6eL3xPLe3P2y4k1G6dVtWjKrGEdgijPJMYOeMntSleSu pnJKE/dPNtQ1e5Xw9NozR6fN5ttGElTRE87JIODJnI6jkcnpWppxt7HQRYXOk6ebnhZJLqGSSQMoAJV1kXH/Asgema9SvdBt9M8P2d/LaeB7nTRJZsmlw Ngbkuwjbctr9pDnGcMduFy2cbcjwq/v47rUzKsE8H2jU5Wt5Vfzo1VpPuAZctjjnrUwiu5L9x6CS6fab7678u0vZjKpieO SL5iMcKRliOOK2dDit9MspHvv7E3GB2igu9GS5AIYZTIjYgn1I7H15mvLXRJJNTt5jqdvLalj5UNqpO/1YM8eFPsGIrMNro9tapeG5a5svIG63kjjXDtyQyhjgAj6/wAqTjePUqno1oTXfigaRa6fIUtraNT5qT6NI8c6MxIC4WSMA5x2FZ03iPW/Gd9/aOv65rWoRRQIsb3t99okEfZAZGZmIC8DPFRxQJePZFI7NQId254PMUc9cFMH8aghsiJEshC5ldp3mlW8ZQzrjCBFcqCeo TueelEb8vn95LS59tzZawS9/0S21Ke3eVEEceq3ACnLDAyFG0 uQQOuV612rx2i6rbL4g/tLwrp0sTrLP4bzc2skiJ8mG8xiFJGGLM5UPkKRweU8M O7iz1Cae80C0uWlngS4u7q3AQgNjbLAFEUi8NzIiOOok7V1aPY6jd6tf2cT6Z9ksgzS2fmkI3OF5d9oIPsMcVTvGOo4qLdnujoPFPw9vtS H2ga1aR F9X0jX9SKxJaeJdPmvkMQAZLmEfvYWOdwMiAN/CCBx8tQm3ttTms0E1o2namVgFlc/PEwbghl6fgPyr6c8MaVqStpmv6JqaW8GgN5mqavp2nBxbo5wWuNqyIuS20FwPfAr0pPht8OfEPhi61nS9U H2t MZ9SSOTw9b6rcQaldFhkzoi2whx22mQMSehxXUpU61Nwlp5mcl5pP8z5mv8AWvD8ktvpPivzrKGOxU2PijRbQXTFn5BuVDKeM87QWHTGa8Z1D4eaTrGq6lqdh458M3Sx3WPKk1pLOSXrgqlwUYg46beO/Ne5fF34d2/hlZ4JZrnS7yecqfD2qwyE/ZycrJFNjDLkEENsI9CDmvn7w5Y6TLfLp9zp17JOIpJBEl2rgoDyQGBIz/WuWnCdJ2bLqTS0R19z8PbbwpcIL3WfDBf7XsuLjSvFltqUWcjBQ27NwcY3ZIOa4v486hptroB0 xvdP1pWJK3NtGwQMOMAMobjHUgV2d5DoC25vvJu9Pt96pb2wkW4UY7OMAg546HrmvmD4zX9rC9rbQbYiobdcIPmkb/a9MdMAUVqcJ1Vd 8FKbjB2Wh4dp gXfi2HVNO0a0l1DxDaRC4ttOtMmSW3QM0 xerFRg4HOAT2NLp16umeFNat4vtEU95cL5hYDBA 8jDqCD6j1rmV1XUdE1601fS7250/UrS5jmsr6ylMckUinKsrDkEH0r2H4oxQahZ/CjxXJYWumaz4t8HPdeKBYII0upYrqaITvEMBWkSJGOOpJI61zzi681BvTdP01/QIVPZXkt0cbczpY2ml2REUghtVmufKlDhgeQCRnB6DHavvH9lnwimneE9d8dahAIL3WUaHT1l4Iizucj2LYH/AAGvgDRLWTUtd0e1MHnjUtUiQWyDYWhVuRx0B6fnX6jI39k D4rCxH2W2tLDakCcDOMn9c14XFeJlSwMcPF2c3 HU3y2g6tfmf2V5HWfso F4PiX 0v4K0KZZJLK58Y2w1Rk b/RY33y7vT5UPNf6d/wj HHh9v2b9O8BazZRDT/ABl4VuI/ENpKgCeXfROskeOwEcpXHoBX eD/AMEPfhPP8YP20NGE8b3FnpUjNfIQcEO4D5H/AFyE/wCVf6NnjnxIngbwbBbW6qZzDHa6XbgcmQrhR9ABk/SvyLPqtRZ3GKfwJfefRZJRh7Z1r7M/x9PiT4K1L4I/tE/FX4aXiSWurfDX4napYvHIMbXtbllH15iH515z 03pMVj8RrnWrQbbXxNYWmpWzK3y/vo1LYP1z dfp/8A8Fp/gv4k C//AAUt Pz6nY3UNl441TT/ABPaXMlodjrqsInY7/UyCYY77T6V cnxuM2t/Dn4d6v1GlfbNLnJwT8jZTJ6/dUV w1a/tszhXW1WKf3pP8AM4MypcmLrQtpe69N1 DPIvBPivUvCHiLw34v0S4a31fwn4gsdU0m5QkGO4t5lkRgfZlU/hX1R 3Vo mJ8cvEni7w9brB4Y KVjY LPDSxj5Fs9Yto71Ix/ufaChHYoRXw/p0hdEizw6lOnrX3P8AEa6/4WL yF8BPG0gM sfDPXtc8Da7dty7QRyLf2Bc 0WoSxLn GAAdK l4bq wzdQe004/qvy/E erwdTDtN f3fjtc Mo5FFpbThVLWOoAkE/8ALN8A5/KvYPCOqyRaQkR3PLoGq5TacYhc5/qa8asl8yS7tJMg3VswjAHO5eVrtPCGob5mgaRlXUdOMcxABJli6ceuM15 e4aVLENNbP8Ar9SqNVVIJo9Is41g8W NtDQqtr438I3Jh44aeMeauPctFj8a T7gkySo2QY3IAr6MvdVexuPC3iYnfJoupxreLt5MathwfqtePfEXSF0Dxlr1hbjNob5pbB zwSfPGw9irA15WF5nUafW33rR/odU7ypvy/U5tQMFSpyOgNMMUj5RFLNn5SBk/gKme4sogWDPct252IR/XvVCXU7l8iHEKnjMIwR NdCjN2sjKOqNCO1aA77iaK3XHzIzZP5Co5rmygUiCFpznIaU/L VZO2af5mLnPXJ5NXILEMSCrZBzz0zTcYxfvMfLYrvfXs3yqdsZ6JGNo611XhPS1v7wq 1byNfMtg3IfB6YrHFsB8v3eOcnH5Vr6VePp17a3aAh4JAwUEjI noawxfNPDSjDR2PZyLE4TCZ1RniI81JNcy8uv Z iHg5NO8XeFrN5LO1D6dF 8jVNuOMOuK T7Sc/B344wXQBj0W9vsMN3y/ZpTz/AN8n Ve fCLXfLv5ba3kK2upRiaBS3ynPDj61zf7Svg 1uNDt9Yt0CajpM24oowXgf8AwNfnuQ4z2OYzw1T4Zfr/AJM/UPETKFgasatLVQaafeL1X4fkfe1hdR3VqjwsCsigxkng575qSeCKR0ZwJihCqjH5frXzf zb4/PizwXY295J/wATLRdtrdMzZLBRlD68ivp5kLIwJ5GCAD1/GvLx1CeDxUoM8vCYhVaUZrqZF/oGlzx5ns4JZAh2fuQDj0DCvNrjT9OsLiV7OK3BY5Kzxl1G0Y29enFepTXsiuqFGfMZChZB97vXn93Zs9xNNNaTxL5RWFWGTk/ePHbNThsTXw821J27HfLBYfE0rzjt9/8AmeMa74g8PPey200L6dJLIPLLQ7bUSdeAuAvOe3FdDZapNbSxS2kttePC Yhbuk9qu7G5ghyMkDFee OdKuY7m5kuYAi3KBoo4shQU78968 t55Vsg0M8sMkB SWJypAPuPevpKef4rCU1L4l6muScDYDiebpQqOlUj80 3Zr8T6y034k L9O1ebUYtSudFuYbQv52ixxRgqQQxCbcFiCRnP6isLUfHeq6iLxLTUwl3dbWmuZbnd5UPAwI5c7C2BllLE9BgHB afE/wAWvEGq KWvdNddOtIdMtYJLBIFMTTRph3xjlmOTn3rpdI IkTi2fWdKjuTMnz3MeNwPuhGOvpivoocS/V4RdVWUl62PksHwBm cV8RHDQ5p0X7yvZvXdJtfmbTI02rjU/F0V9qujT3ST6hbQOA9zEjAFckExp975gCc9q5vxx4wstfv73SPDNi/h3w81yxtdLtJy0hUAhUdwoLLzgD8fautja21O2MOm319e2xBE1hl0lEYywUFOQMknHI9a88jn1fw9eXd1pkUzATgpOG8ybzO43Hnt9etenhs5wWKnanJP5nz2ZcPZxlLUcVRlC 14tX 9aljT9HEESGFrOcm4AlS4bZnPAXJI3YOT/s17F4ct9N1WKSws762029WUBmWQrZRAlQ7uxBIUHAyMlj3ryzR9VtHmja9hjs3jGLm2jPzIw5PBIznP8ASvS9K1bSp7yKDTdJdbWaONb2y06aWJWlRTsdij7txbHygYAHAJ5r16eIUo25tTxZ03CW3yOtt/Gmk En1fTLbSdVju9VS7sdXSVPI2aWyDeEmAO1pAGEnyqNnHO4gcZf LYrKwTS9JtrGG31KWN7mSG5N05jySSGPRyxIyB8oGPWtjXPiRp/h23vvBln4H8KeHdRh0d7bxFqeoD 0L24m3OxZvP SE/MigIm4bAchiTXlPhvRNR1gw/Z3lkjiU7vlL9iSox3O09fT0qqkozaREG072/Q9x0vULTXILtL6KGwig5iNnaRIqOoJGZGVnJ6H7xPNTazMskWm6HbNcGa2s/LW7vo0O F8HBf LoMF8EAnHrVzS/Btn4l8NldL1TTrXxLbvIJLN5RGvlooaVMkgBhtySOcYAya4uOPUrkNalGmurZzsspAfs7pwN4dhhSAfvuc/pXRSw0ZRuOVWfNZHoFpe2ekLc Jb1fCmsaZdJdW7 EVtLsNtCArIsnCja7kqqs3zJ8w2nDSXV/pd3ottD4g8P JfDei2lmkok8PyJKWDA7ZpkdMY3SgbwcgEDBNcJJa6dDJBbyQ3Fy0M7rK1tqToUzgrmT7rRg8bhsJycA9a0rebRYo9UgsmFs88jgaWty2dxOcM z96oAx8 BnmuSvhaUpXad/LT9f0N6eKqxjZSTXpcykutQt9JWygsZr7RLyRnF8lvD1wAW87Blj 5jGdvPQZNSapJJLqa6nZSnTLa38qS3vLnY84MYG3fuCCRcqSAEIPvWVHDLezRWsFra6ZNe2s32ZtX1FbWNCik YWZwO3XqxGBnpWTYeJz5sVrqUsdtqNpcDy7y3R2EkY2oFjKg4C7WbOAfm6cVSpU1K8Vd9SFOd9WXLy/17XNUuPtt3dtc6zCVmhS6 zwXMZYbFUBhltxBCYx0xnpT30KSa280Jb2 2EJLc3Ey8qoHyyJvyXGOuOuK0oI9G1F5ZbeWYzzkeVHcgQhJ2OSpRG3AjA68GktfFssdw2nayNHYmWOKGaXSPnEa4Gx9pRQAO53tjoa1XOvgVrEtw3kdVNLqurWvhqziutEnvbGzMVpDcm2Y21qpDZZlQM7bUP8ArWyozxjmvP727N814JNUsmECN59p9nfa0iHaHWMbY2PzPyAep4PfRm0qB45fFFjcxR2mm3MUclvHYyLHE5LEMzoy8MEGApJ4PGAay/tKXYe/exikuba6chRbM0EzEk5JkbcGBOQFXBPWjklHf vkL IvXUSLTraWNpI72RLCKbEV/d6ghukYjOzqu4n 4i8A9Tikt7a50 af7LfQXbXMKxNavGkxbJzuRFJYgYxvABrpNN1jTrbTLm6bRrS udSYReRc3wgWOIlPMURxFDuJHBzkBuADhjz oeDNaW0l8RWumXFtbXeqILHR7e0uUmtYmLHesrAq6BvkG52diOeQaTiqmu33CUrPXUz5xdazdrDcP9luLm4SOdryz z27H5eC4K7R3JbgZB45q9rWsWM1ja28GhT6Q9pOYo7uPUf9EnjQDeqgKdxBAJZXBIPSuVXXbu1lk0 /wDMvLWWZZWXlpiVA cNtzv4HGeKs6vregTaZYrpmrSG jyk2myRukTRkltzTMwOQSR7cdjVwpTcbhOdlozoNM1wx3K6zItq9nbyFrgzW7QxDeMbWmjCycfL1U w9eh1DxTdR6TY2djr9jcwieZ7SVlCqoB4jiusfORwcNtwf4STk O6bZym5tTpbXZa1xvtkuSY5AwzgSbhxgk5BI4JIHNdpeaHo99OmqeGbJ/CIu7OIx6fql6moSMyoFlmikAVGVnVieFKlgozgknKoPU55Rc21f8AM7MX/wDazRWviGaWyuLhIZLW51NFW4uJAcMySgDzCwA Zt3Q4J4FbN3bXl3cWMNvc2s4luk yxCHzLlYgpDAzKSxOFH3un0rzux8MeIrq402KKEX0doM3d8s6x20OVLGV1lwFwik5yvAr6A8OePoPAgsLj4aW1pe P7TUYprPx1HbBZreRQAYrWGRWWRl4IbIAbccMdjKm13BJJWt8jp4dEi8JW2zxZfR3kenov2XQdRtVaFvNGPNyFwp5ACuGfIGU24rBivtYS9jWyW1trKW6L2el6reRyWVkSchrieQkBc7GIJVchSegxQ8dQeJHk0XT/FPiu11G OmI15az7I5LJCzMtuzgFQpDM5CDlnbPzZrib6G9spoogeRNSAhu5lFlbMwigZVA2 ZGzbSwDN1ORnPfFPpuP4Xtr66GNqOu6hr2rm61a6u9TuLkM2p6xqG aSRnP32ducZxy2B078HE1mFxqEljDY3QMUYaEn5PMGAQ5UnABBByK7Gx0mVZ40eIBY5R5ojDNbrKMkBxg4I6 gHYV65rXw9juvDsQvG0zVdSkjZnSwu/Mvo33MD5qgMUkG0t5ZJfZhmADAmU1J6D9nJWV7Hz3Y6YltAHvr 4ify/9AVtsxRu 4nAx/L0rQgsbyBXW0aCJshvOtbkRseOVwQeDk5A4rQsdBhkjEKG4e5jtWktLi/unt7Vip ZHXYSjDqGxg8gYPXvNEt4lAik0nSnuoF3eWsTMtxGF5BMpXHBHIXng8GrUVfexMYSSsjhLKC4m 0rBbojSE bawbYyYwpzwF VevHI4zwea2LXQLLUvKhNvJDOhQ6ZbX9/GsP7wgbhK7Yi5wc8gd89a6O11PQHnYCK006e2gkNtc3S/aHQZwUZMhWXk9sgE8EYFbUiR2djE0FksEMUJY3izA2NwCxAkt9xVdwPG3BOVPI7TypbMrXlemxwVzpXiXSrlbdVe3tIwsr2kaARHHJK8Y7ZOCBznHIqyEmeS2k1rSLm4tryZpG0icIGl5ba8Em3A7DncP6dWnxO0nw7pK79e0 8jWJJSL wjilgmLYVomaUMSFz8uNme2cV59r/AO0n4MtrKKzsvCU19rEc0jX1/DHFbwTAqQjfMMKe52R4Prnmu/C5di8XL9zTlL0V/wATCrisPRilNpHR/wBheGJrN7m7srnQpDGrW8VtBJJ9ry3I4GyNwFbLF0U44GeDozaDowFkvhfw/wCI5L51WZ4NR01DIdqBnlIhZ8ADcQ2QSMHaOcfK sftCeJrxbe2sdN0uws7eQtMAPO86QZxIVCja2MfdPUE9TXnmofFPxlfxNb/ANpiFWLhri3tVWXa3bzDk5A43DDe9e3h C87xL0hy rRzTznCJaa/qfT/wAUPirpfgh1vNZtbK/1qSIxQWdpdJJJdRBSsZwE2IiBUzuBJxgEGvh/4mfFTUviJrVpq39jJYxWmnJbQQtIZCQpJ3MeBk7uwAwAO1Qi3t7iV5rhZLmR3/eT3Mpd29ckmpjbQqy XBEPm/uj/Ir6bD HNZpOdRX8kcFTOlukecLcazcELFbA/SJc0Aa/ISFjlXbwABj lenhWWTckSbtvRFHrzVmKzmuMZQ4B bnp9K9Wl4dYaKvOp9yRzPOqk5aQ 9nk39m69LneZDgcksf5Zq1baFrkM0VxbymCZHDRSxuQyn1BByO1e2W iKYy0kQ3MMg4ORWtHpkMUbExxqQMDC5J9K9CjwJlVNXcpP7l hE81xLdtEebR6h8QYIraJddnszBIHWeHCvIwOQXb Mg92ya6 Lxz8TTbSpca9a3801ykxu9R06N5QV3fKHAHyktkg9wPSta6slliOEbcB8o244rn5rdkOGAbYce5H cV24fgPhybtKm/vOWrmmMgtDsdH JfxHsjcx299ZwRXUWy5t7K6liSVDgsGUlhzgZ45r1XTPi7oywahNrHgfWLnW77bI q6brVmsCzlv3n jG2A8sjOEVlxXgdrHJGykhhjknb39K2bdVxv3bAM43HvTxHh1w5W2Ul6S/wA7ipZzjqbvf8D6D1P4n/DmXS9OMGi6suvTzStq97YaQ1n8gACRhUcxt/F0Qe5Nc9J45 Hs9tLJFf8AiS3mt7jba2U/hyVmePk5MgIHZRggdfavJWS2XG6UMrdQZP8AOKpzvaDP7 NCOo8zk/j NcUfCvIqjX76aXy/yNnxBjk9Yo9Qu/iv4ahulew0fXbuIWihzLpWGJ2 uAODnt2rO/4W/DE4UaFr15HHIr2withDh/8AayeoHHHWvOPPtAAGlQKDkqknb1pGv7PYGEsZKkDiU9K6afhNw7fWvK3/AG7/AJGX smO6R39T2GT48WVxeCe78L IptiAqkVr8xcjkmQscY56Cuksf2hNOFrHbz EPETJbmRlTyk2sx6AEsCvQDJzx VfO66tZoSAcbVOSjc0g1bTzuJkyxGFI5xWq8KuEofHipffFfoRLiLNVPSB9D6h 0p4kEIt/DPhabTY7mDF6L6 ijy5PI TcWUDGDwc1zfiT40 N9deE6Vpvhvw1H5SecAr3bl8YZlYbCAcZ53HJPOOK8bTVdO6kg8/eUnIxT/AO2tP52kFl 7jPc16mB8PvDnCyvUm5 s/wDKxx184z6o7pWv5P8AU9Yh Mnxdjne4g8ZJpztvAOl Hrc7QylG2tMkhBIJ5zkdRXP6r4j8XeIITZ IPGHirX7R25stS1 d7c46fuQwjHT 7XCDXrFCcMGAOWz VTp4u02NwrIhXb1D8nn9DX1uXZd4b5VO8IU0/Ncz  VzyMTLPsYtXJ/h Rr2 jaeUkRrNFjzkooJQt2ypODUkejWcKu8FjZgD7zx2wUgj8KzY/G mIXwCTsIByG2mph4z0 TcvlTOH7r6euP89K hhnnA1GV1KC9EjieBzqS1v/AF8zbjO3ayleEAK45z2/GrQmmQkMcHPBkJP5Vgw LbJD5g02Z1BwQ8uAw7dMUHxZEWG6yiCA/KklyMAdxXUuOeGKMtKyMnkOY1E24HU28jwuS4DbgQyhev09KuC6jDnFuc7B8ytx eK49fGCIrLFDYx/3czhiKb/AMJVG4DM9ipOQ2HBJ/Wn/wARL4bpaKrf8SP9Wcc5X5fxO  0QKiFfNYkcosmTn6kdaSa9WRVDRTFMn5vMXnn6etcF/wlVtkYntEVVOflViD69aY/jK2X5VurUgdTt7e1YvxU4aS0qfgbrhfGyXwno1teQoXjhQ7W7Ox/mOtWZ9QnYgAJHz0HBz3PevLl8Z2kZDrqFtHn7xWDgfjnrVhfGNnIAp120jAHy/6MM81hLxT4b5LKoV/qrj3P4bHdyTTSDJdWBHZsfrWdOJHON4GV6Z/QmudTxXoakrJ4nCIW6DTGPPbHNWv Eq8KgIW8VXoJAMhGglvy brXn4jxQ4aa0qM6IcLY9Jrl29Sw5nXIB2Lz8qrnFY93YpMAZ4YZ1DEuZIQc5rSfxL4M3DZ4i1 YBORb Fhnn/trVKbxP4MPym78ayoOS8fh FSG9szV5WI8R GJw1nf5HbT4ZzJP4dfRmQbGKAym1V4G5ybSdosDuDtIzViDX/FmlMG03xNrlrslDIjXzSxgj/Yk3AjHt7U5/E3gwLEv2Xx1Nj/AFpNlboDz9TioZPF3gEjD6F46YnHH9oW4yMdf9VXy M4p4GxUGpwjK/91f8AAPVw SZvTaabVv8AF/kdxY/tBfEjTJonu/8AhGtYWF84uvD62jtg5yWtmjBP1Br2DT/2xNNvJNNg8Z D75NPs9QLyr4cuFcxwMCJEgEpIXduOcjknqK ULnxR8NZSceHvGyOfueZrVsdv/kEVzja34JDFxoHiKbJ UPqkafySvz3MqXAuJTdJcn F2/Vo9jDrOqUt2/W/wDkfof4E8RfBH4w6uPDWhfERPhne6nqXE/xPsJ47BE byl822SUDoilnxhmBBxkjqfEPwU8SaWkd3o80PjK2t72RZtR8MzLewOsZGXZ42LIvK437CcjGa/MFvFHhy3ctY EL0E/xT6uTu vye9dFoPxo InhLWbDX/A0/iHwxq lTJJp oaXrU/mRMpBUqc8YIB49K Ex Ay NS9Gpddn/wD3aWIxbj79O/pp/X3H2HqSasmpSpezTvJC5R2vY9xaYHB5wcfn1rXsYtbkuJEjF3PZRybNQexcPJbxkfN8uBu7HhvrXzprn7Y/xg8a6vHqnxJ0jwl4wuxGUmvbjw9Fp13KNxYvLLbohllJ5Mj5Y9zXrNh 0z8M7/AEPToY/BV34T8SW9601zerrMk9tKzHjCyq5QIOAu/a38SmvAmuXT v0OyLjLdNfL/K56docGjeI76507S/FejWjQtm2g8aTRaMs7KcBPNZhGzEkfK0n9a9Um8FeONJbSLGHQ7zSrfWkVNP1Lw7qBubK uevySLMI5CeR8jtzkDn5R8u65deAvEl1ax ENRv1guIVbV2eeCdGnZiWaPYAQuMcbRg9qd9s8RWZOh6Dquq/2LIPLgtQ8oj8w9HMRON2CwyOxok0lsTGUami1/r7vyPoPX9V8S2 jLZ3mpeLbmzstpktb1nlj80nazBSVPUAdDjGMmqceuXutQW2lXN5cXQsbR1tW/saOOS3Uk4V5AylvX58kdq8gtfih400aOz0o3unfZ7V0VorvQLUhwDkbt8fz4OOGyDznNeueG/i94gkitNKu/DOiXcGsX6fadYs7NLK5DIW/ds0SjdEyuyleARj0GIlNtIuEYxj2PctI1ywvfBvh3wr4o8d2ZsFkvBaWWnzypHYKUkaJriKLTn81jI7AETOwDYO1eR87X8CR69Go1hLy3UPHlITuA6DYsgVTkdj leoXviCOW1sbL
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Replacing Intake, throttle body- questions?
X
Ok. First, you don't calibrate a throttle body.  No big.  More importantly, Even though the Explorer GT40 intake is within 10% of the best aftermarket intakes available, the E7 heads I assume you're running are the second most shiznit heads you could run.  That awesome intake is going to yield almost nothing.
Two reasons why:
1. Your heads are your bottleneck right now, not your intake.
2. You're going to max out around 260 on 19# injectors, which is probably 20 past where you are now.
You're about to add more air, but without heads, you're not going to add much. What you may do is max your injectors trying to match that extra air with more fuel, but that assumes you have or WILL add 1.7:1 rockers which would put you at about 100% duty cycle WOT on your injectors.  100% dc is a deadly proposition for fuel injectors, and in some cases, piston crowns.  You need heads and injectors to go with that intake, even WITH a stock HO cam.  A HO cam, even a late one (10 additional degrees exhaust duration) will max at around 300 without forced air and lots of fuel.
See if you can get the heads from that 97 Mountaineer.  A 97 may still have non P heads.  If it has non P heads, it will have internal EGR in the intake, which will make your life easier.  I'm not a fan of P heads.  I have some, and I don't like them.  I HAD early GT40's at one point, and they were better.  Get the heads, find some 24# injectors, and swap the sample tube in your MAF to compensate for the injectors.
Bonus:  The head swap will eliminate the need to block off AIR injection ports on the back of the heads.
Lastly, that's a sick clean engine bay.
The stock lower intake is a biffer restriction then the e7 heads from everything I've read.
I think he should bump up to at least 24# injectors along with the explorer intake as well.
Thanks for the quick reply and the honest assessment. Somehow I knew this would not be easy on the wallet. The only thing I've collected so far is the intake, which is like brand new, the smog pump delete, and the 1" spacer. Didn't want to buy anything without more knowledge. Glad I asked the questions.
Ok- new 24lb injectors, either late model GT-40 heads or aluminum heads. Any preference on aluminum heads? And more than likely a cam, lifters, 1.7 rockers. Preference on a cam?
Next will be a throttle body and MAF set for 24lb injectors. Is 70mm good? Right now the intake is at 68mm so I'll have grind it out no matter what.
I don't want to half ass the work on the car. I'll do what's necessary. Any input will be greatly appreciated.
The way this is looking I might just end up pulling the motor. Might look for a new one depending on cost. The car runs great the way it is. Really fun to drive. Here in Nevada I don't have to park it for the winter. I won't take it apart until I have the right parts to finish it.
I'm kind of buttstuff when it comes to my toys. Especially the TC. I'll be able to clean up the wiring when I take it apart. See any problem with deleting the TAB and TAD?
Thanks again for the advice and for keeping me from buying parts that won't work.
I will be replacing the upper and lower intake. Looks like it will take me longer than I thought.
You don't have to delete TAB and TAD, leave them connected to their vacuum solenoids, but delete everything else and the EEC will never know.
You can look around for used or remanufactured injectors, and iron GT40 heads aren't difficult to find, nor expensive to buy, and head studs are a worthwhile investment (just be sure to use thread sealer on the bottom row).  On the other hand, cam swapping gets pricey.  I'd roll on the HO cam for now, and wait for a good deal or opportunity.  When you do a cam, you'll want a double roller chain and new lifters.  For clearance, if doing a cam in-vehicle, you'll be pulling the radiator and condenser out, though, you don't necessarily need to have the heads off.  Some guys around here really like the Trickflow Trackmax stage 1, though lots of other guys have good success with the FRPP letter cams, do your own research.  If you do the intake now and heads later, you'll be buying intake gaskets twice.  A last note on heads: If you choose GT40 P heads, you MUST MUST MUST upgrade the valve springs and retainers or even with stock rockers and an HO cam, you'll bind the springs.  This isn't a thing with earlier non P heads and you get a larger exhaust valve, not to mention less compression bump, which means you don't need 93 octane.  I've spent some time in northern NV the last couple years, and I've seen that in most places your premium gas is 91 octane, which combined with the elevation in most of NV is a motivator to not go crazy with bumping CR.  If we had knock sensors it might not be a thing, but it's a thing.  Once you have done heads, cam and intake and swapped injectors, you'll really want to seriously consider having a tune done.  Getting a tune necessitates MORE spending on parts, as the EEC IV isn't tunable on it's own.  You can get a TwEECer, a Quarterhorse, or you can have a chip burned for you to install to the J3 port on the EEC.  Reasons to get a tune rather than try to rely on a calibrated MAF are discussed heavily elsewhere in these forums, and I'd suggest you at least look those discussions over.
I'm not going wild with this car. I've tried to keep it kind of stock looking with some horsepower. It's not a daily driver. I just started entering it in a couple of car shows and go to a weekly get together on Saturday mornings put on by a local dealer. My TC is the only one I have ever seen in a show of any kind here around Las Vegas. Most people don't even know what it is. I have had cars that you could barely drive around town and had to fix constantly. A 69 Roadrunner, new, 440, 4 speed, 410's. Also had a 13.5 to 1 383 for it. 64 LeMans, 4 speed, overbuilt 12 to 1 326, Offy tunnel ram, 2- 600cfm Holleys. Impossible in traffic.
I want to keep it around 9.5 to 1. I don't know why but gas here in Nevada sucks. And we get it from CA. I run Costco premium in it all year round. Timing is at 14*.
I will do my research as you suggest. This site is great as are the people on it. I've gotten excellent advice on some of my other work. I usually find the information, copy it to a Word doc and save it in a notebook.
I have plans to put her on a dyno. Already have one lined up at a shop here in town. The guy that runs it worked for Shelby. As far as I can tell it will run me $800 for everything. That way I can have an idea of what the car is capable of and a tune that won't kill it. I will go down and talk with them about my plans and see if they have any ideas.
Seeing as the heads are the weak point I'll look for some good heads, stay away from the "P" heads, and do the intake at the same time. You're right- I don't want to do things twice.
I'll buy new injectors. Limit problems and just sell my 19lb ones. They have about 9000 miles on them.
Thanks for your time and help. Greatly appreciated.
The gas is due to elevation. There is approximately 10% less air at 10k ft elevation. Since there is less air, you need less octane to prevent detonation.the gas would be the same or equal to 93 octane gas at an elevation of 4000ft or so and actually slightly higher at elevations above that. Its not worse gas, they just put less octane  in it.
I run my stock junk around 16*. In not saying stock h.o. stuff, I am saying stock s.o. stuff. We have about 10% ethonal. It both boosts octane equivalent and makes less power and gas mileage. I run it about 16* to get some power back, doesn't effect gas mileage or detonation.
Quote from: Haystack;463760
The gas is due to elevation. There is approximately 10% less air at 10k ft elevation. Since there is less air, you need less octane to prevent detonation..
That's not true, increased octane LESSENS the chance of detonation...
You guys get the "cheap" gas as higher octane isn't needed...
I'm at 2300ft in Henderson. I think the valley is 1500ft. No problems with the TC running premium all the time. We get CA  gas here. No choice.
I've been down this road.
If I were you I'd wait and get better heads, then just do it all at once. Skip the iron GT40/GT40P heads if you can help it. I had GT40Ps. The car ran good but it was a night and day difference going from GT40P heads to Edelbrock Performer heads. The car picked up 4.5 mph and .5 seconds from just the head swap with no other changes.
So that being said a 24/30lb injectors, 70mm throttle body, Explorer GT40 intake, and a good 165/170cc intake runner aluminum head (Edelbrock Performer/AFR165/Twisted Wedge 170) along with a stock HO cam will make good power and be very streetable. Much more fun that E7 or GT40/GT40P heads.
I've been doing a little research since I first posted. Thanks for the heads-up from the members here. Have you guys heard of "The Official Ford Mustang 5.0 Tech Reference"?. Been reading up on all of the different 5.0s Ford built. Learned a lot about the intakes and especially the heads. I agree- the heads will be part of the transformation as well as the intake, throttle body, MAF, injectors and probably the cam. Car runs great as is so I'll start collecting parts necessary. I'm not in the habit of doing something half assed. Other than the intake I'll buy new parts.
Thunderjet- Thanks for the information on the heads. The Edelbrock or Twisted Wedge heads look good. What do you think of the 1.7 rockers? Also I will be using the Ford 1" spacer on the intake.
After all of the work she will be going to the dyno and see what needs to be tweaked. I'll post here as I go along.
Thank You guys for the help.
