Topic: Fan replacement (Read 1804 times) previous topic - next topic
Fan replacement
Noticed the fan on my 86 5.0 has some cracks. Tried searching the usual places for replacement and can't find part # or source. Any info ? is it the same as the mustang ?
Fan replacement
Seems i read a Mustang fan will work. It will have more blades but that would be a benefit. Someone else may chime in .
 S O L D
Fan replacement
Quote from: dcs13;463723
AFAIK the Stang fan & T.Bird/Coug are same...
Fan replacement
Quote from: TurboCoupe50;463725
They are very close but not quite the same. Thunderbird/Cougar/Mark VII fans are 7 blade fans and slightly larger than the Mustang fan, which is 9 blades.
That being said the Mustang fan fits fine and works well. I've been running one for the last decade without issue.
https://lmr.com/item/LRS-8600A/86-93-Ford-Mustang-Fan-Blade
Fan replacement
Thanks guys. Guess its a common issue..
