Topic: Header panel question (Read 1700 times) previous topic - next topic
I'm in need of a header panel for an 86 bird. Are the Cougar header panels the same and interchange ? Thanks
Same, no. Interchange, yes.
I put a 87 cougar front end on my 87 tbird after I ran into the back of a Cadillac. All the turn signals and everything are in the same place.
For the 83-86 years, the cougar side markers are more vertical as is the grill. I am pretty sure that everything will bolt up, but you may need the bucket and side marker to match, as well as the grill. But it will interchange for sure if you get a "loaded header panel" and swap it all over.
Thanks. I'll keep searching for a bird panel..
you can do what i have done dozens of times.
use this link.............
http://www.car-part.com/
then start talking to all the yards across the country till someone finally gives and ships one out.
HOLY COW. Thats a great link, thanks. Im a huge car guy, never seen that before
