Topic: Fast EFI and ram air...... (Read 12552 times) previous topic - next topic
I have been thinking..... I have the GT40 intake, X3Z Cobra computer, 70mm throttle body, 24# injectors and so on......It's a good set up. Now here's the thing..
I drive my car probably 10 miles a day 90% of the time. I have thought many times about my hood scoops actually being functional. Which led me to think about the Fast EFI setup. I'm simply THINKING about the swap, topping it off with a '71 Mustang style ram air induction air cleaner that would seal to the hood. Something different, and functional. I may or may not lose a few horsepower over what I have, and either way, not a big deal to me at this point as I don't race the car any more, and I like it's self learning capabilities. I've got more studying to do on this swap. I know I can sell my current EFI parts to get some of my funds back. Well, except for the GT-40 upper, I'm keeping that. The lower is T-Moss ported, plus the other parts. I kind of like the idea of opening the hood, and seeing the big blue air cleaner with the rubber seal on top and fabbing a panel to mount under the hood for the air cleaner to seal up to. Painted to match the hood of course and carefully done.
Any opinions on this swap?
Not sure on the swap, but calling dibs on the Moss lower....;)
Mike
I'm still trying to decide. Still educating myself.
Ive been looking into FItech for later on down the road. Their big kit handles 1000+ horse self tuning self learning all in one and power adder friendly. I think in the long run you'll see some real gains replacing the dated factory style fuel injection for something like fast or fitech. I think its mainly up to your preference. I personally think it would be really cool. It would be a compliment to your hood
It sounds cool but you'll probably spend $$$$ and not really gain anything. It'll look cool though, so there's that.
Do a Vic Jr efi and a 4150 throttle body.
http://www.stinger-performance.com/universalparts.html
The PIMPx system is very capable and will do anything you can fathom for the most part. It's essentially a Megasquirt packaged to be used in our Fords.
The idea originally came about to have good performance, and make my hood a functional ram air hood. I do like the IDEA of having a '71 Mustang style Ram Air induction air cleaner assembly. So I'm trying to see what the pros and cons are.
I think its a very cool idea, I myself had thought about doing this. Fitech, Fast, Holley, Edelbrock all have these swaps now and are fairly reasonable..........I say do it!! :D
I'm sure thinking about it. I can't do anything til January, but the idea sounds better and better the more I think about it. The whole idea isn't really about getting more power but retaining good power, dependability, and doing something different.
I do wonder what can be removed if the Fast EFI systen (or Fitech) is installed. Does the Main harness get pulled along with the computer and lket the new system do it's job? And, does the computer effect anything else in the car that would need to be addressed other than the engine management? I have to learn more before I can obligate myself.
 If I do get the system, I'd get the "master kit" that has everything, fuel pump, O2 sensors, etc. Start from scratch.
Quote from: Haystack;463554
do this vinnie save you some cash
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Then what about his mass air sensor?
Another reason I kinda like the FAST EFI setup. I'm going to do more information seeking. As I stated..... I understand the SEFI style (an injector at every cylinder) may be better over all, but if I lost a few horsepower, I can live with that. I am ready for something a bit different, and that air cleaner and actual ram air sounds like a really cool idea, and the self learning FAST computer also sounds like a good idea.. I also like the idea of not pulling the intake and air intake to get my valve covers off. LOL.
90% of aftermarket stuff is sd and uses a map sensor. Sefi also have virtually no performance or gas mileage benefit, so most are also batch fire.
With the ram air a like a 70's car, it would be way easier to adapt a carb style throttle body. More power everywhere and cheaper.
I went carb for the cleaner look and it being cheap as can be. That was around the time the fast system was still new and pretty expensive along with the vic jr efi and they were almost the only options. I have the same round about idea in the long run with fitech. They make re-pop boss shakers. I dont think you'd be losing much in the way of performance.
