Topic: Check Engine Light on 1983 Cougar w 5.0 Where is input/plugin for meter/tester?? (Read 2011 times) previous topic - next topic
HI all I have an 83 cougar 70.000  miles on V8 motor My engine light came on I wanna know how to check it Cant find input for meter to insert/for clips etc--Anyone have an answer?? My name is Leo EMail Kingleoromeo4@aol.com Any help is appreciated!
Quote from: leo boogie;463406
That's a EEC-III system, has no test port... This gives code retrieval process...
http://www.tomco-inc.com/Tech_Tips/ttt3.pdf
AFAIK back in '83 the engine light is only signaling low oil pressure or overheating... Has no idea there is a computer controlling engine operation...
i agree with above if your EECIII system.
confirm you are by telling us if you have an electronic module on the side of the distributor.
if yes you are EECIV and codes can be pulled
If no, you are a duraspark system
You are certainly either a carb like dual injector CFI blue top system or a carb.
83evtm linky below for your help in the future.
the engine light coming on may be a real fault though..... respond back
Quote from: jcassity;463441
If light was on because of oil pressure, engine is probably locked up... My bet is we'll never hear from him again...
BTW AFAIK only EEC-IV system in '83 were the Turbo Coupes, still I don't remember seeing anything before 1987 that had a actual check engine light... EEC-IV expanded to all lines in '84, though NA 2.3 Stang half motors & some Canadian models were carbed as late as '86...
My brother has a 83 Bird EEC 3.  I will have to look at it and see if it has a check engine light.  My 81 had a dummy light that come on the dash.  I don't remember what it said, I think "engine" .
Mike
