Topic: My Thunderbird Died Driving On Road Please Help (Read 2152 times) previous topic - next topic
I was driving the Tbird this morning and all of a sudden it just died without warning, car is an 84 Thunderbird with a 6 cyl motor and has a carb with throttle body fuel injectors ,I pulled the fuel line to the carb off and fuel was being supplied to the carb
I then disconnected the main cable that connects to the base of the carb and tried starting it again and it started and idled for appx 30 seconds then died on its own , any clues on what might be wrong with it?
Fuel pump, fuel pressure, injectors?  will it keep running if you give it some throttle?
pump going bad is my guess had the same problems and the pump completely gave out not too long after
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Ignition switch
Test for fuel pressure and spark. The most common problem in our cars with stalling (especially if it restarts later) is the TFI (ignition) module.
CoogarXR : 1985 Cougar XR-7
