Topic: my new red '87 turbo coupe (Read 4277 times) previous topic - next topic
hi all,
I've taken a long hiatus from older cars since my last '87 & '85 TC that I had in 2010 and 2008.
Here's my new red, '87 TC that I picked up earlier today:
Nice.
Looks like someone put some time/money/effort into the car before you bought it.
Nice score, I want you're interior!!!
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
I have long thought that the Thunderbird's leather raven interior is among the nicest interiors of any car, especially the seats.
Nice car!  A lot of work went into it already.
Daniel
Nice score!!........now we need some details :D
Awesome!  I saw this on the Philly Craigslist ... looks like a really nice car.
Quote from: thunderjet302;463184
Nice.
yeah, the work that was done to the car by the owner who sold the car to the person I bought it from was pretty competent with cars.
Quote from: gtbird;463185
haha.  not going to lie, I really like the velour interior myself, especially since the car doesn't have AC
Quote from: BornInAFord;463186
Daniel
I think the interior this car currently has was from a parts car.  I dig the velour interior myself..
yep, that was one of the appeals to buying it because it had a lot of the work already done that I would want to do to it eventually.  I'm not a mechanic so the labor costs to get someone to do it for me would of been a killer.
Quote from: flipnbird;463191
gosh, it has a fair bit of work done to it.  honestly, Tbird232ci probably knows more about the work done to it than me!  I sent him a listing of the car (which didn't list too much of the work that was done to it) and he was naming off stuff left and right that was done to it...  I'll try to name a few things:
- front mount intercooler with large 3in piping
- aluminum radiator with an electric fan
- cone air filter
- ported and rotated upper intake (as far as I know)
- 3in downpipe that goes into 2.5 single exhaust (not sure of the ler yet - it does have a nice throaty sound to it)
- 5 lug conversion using spindles from a 96-04 cobra
- cobra front/rear rotors and disc brakes
- maxim motorsport camber/caster plates
- 18in HP design cobra wheels (235/50/18 up front, 275/40/18 in the rear.  The front tires are too tall as they rub fender wells and will be getting replaced soon)
- auto meter gauges
Quote from: 85CougarCobra;463192
yep, that's where I got it!  thanks!!
some things I'll likely be changing over the next year or so:
the car's power steering was replaced with manual steering from an SN95.  while the engine bay looks A LOT cleaner without all of the junk, it doesn't make driving the car as fun as it could be, especially being that I live on a narrow street and when I pull the car out of the driveway, it's a real PITA.  I've been talking to Shawn about this and an EPS (electric power steering) set up might be the easiest and cleanest looking to compliment the work that already went into the car, while making it easier to drive.
I'm a tall, fat, handsome guy...I'm pretty sure the driver's seat is sitting higher than my old '85 & '87 TC did.  The rear tilt button to drop the rear of the seat (I believe) doesn't work - when you press the button forward, you can hear it click, as if the seat in the front is down as low as it can go, but nothing when you push the button backwards.  I'm not sure if that's a sign that the seat track is bad or what.  My buddy Brian has an '87 or '88 TC with fully working power seats.  I'm hoping to sit in his within the next month or two to see if I sit lower in his than in mine.  if that's the case, I'll hunt down a fully working power seat track or find a manual track and go from there!
Quote from: 85turbotbird;463214
I've been saying it all along...
:rollin:
I just sent you a link to one a little bit ago. Should hook you up pretty well.
Yeah...this is what happens when I'm bored and unsupervised.
Very nice car.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Looks clean and well done.  Nice car.
Mike
