Topic: Electronic Climate Control - can I remove temp sensor (answer, yes) (Read 2138 times) previous topic - next topic
A squirrel chewed through the heater hose (maybe it drank antifreeze and died :mad: ) and I only have a non ECC replacement hose.
X
Well, I decided I don't care if it works like it's supposed to cuz I never use it anyway. I tested the thermal switch and it's Normally Closed. I heated it and it opened up, meaning I can just remove it and the system will work fine, it just won't wait until the water is hot before operating. I apologize if this is common knowledge. :hick:
I bypassed mine years ago due to not being able to find the heater hoses as well.
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
O'Reilly's sells the correct hose, if need be.
The Mark VII uses the same setup. When I had one that same hose split. I just got two non ecc hoses and cut them to match the two ecc hoses. Worked fine.
That sensor just keeps the heater from turning on before a certain engine temp is reached. I personally despise the atc setup. Its almost a deal breaker for me when I look at a car.
But yeah, just bypass it. Won't hurt anything.
Quote from: Haystack;462894
On the Turbo Coupes I owned I feel same , would turn blower on high long before any real heat was available... Seems more liveable in newer models, but still something I'd just as soon not have...
When I bought my white TC for swap, two things it absolutely could not have, EATC, a hole in roof and preferably no leather... Figured I could swap seats tho if necessary...
