Topic: What trans behind a 5.8L swap? (Read 5399 times) previous topic - next topic
What trans are you guy's running with the bigger small block swap? I could go T5 or because the car is automatic I could go a C6, AOD or 4R70
:burnout:
I'm gonna run the TKO500 that I had behind the KB blown 306.
Sticky tires and a stock WC T-5 = broken T-5 parts.
Tremec TKO behind my 351W.
Stock s.o. plus t-5 equals broken motor mounts. I replaced 6 in about a year. I have been known to be hard on stuff though.
So what about automatic? Anyone run a AODE?
:burnout:
My car makes a little over 400hp to the wheels from its supercharged 5.0 and I started off with a fresh built 3.35 T5. I race the car with 26x10.5 MT ET Street R bias tires and gotten a best 60ft of 1.61 running 12.00s at 116+
I blew that trans up after 4500 miles.  I bought the G-Force Street T5 with the 2.94 box and with a .59 overdrive.
http://www.gforcetransmissions.com/tran_gt-5.asp
This thing is a beast. A little louder than a stock T5 but I was able to step up to 3.90 rear gears so the car pulls like a monster in 3rd & 4th gears. Its rated to 600hp/500ftlbs and cruises 80mph at 2200.  I have $2600 invested into the trans and the new clutch disc to complete the swap.  I really couldnt find a better option at that price level and without changing 50 other parts on the car.
Brian R.
88 2.3t Ranger
deathbypsi. Good to know. For now the car will just be cruising around with a basic stock 5.8L with a 5.0L HO cam in it running Fitech Go EFI. Was looking at keeping it auto with a AODE or V6 4R70W and a trans controller. I am looking at the cost between swapping to manual or keeping it auto.
:burnout:
