Topic: 351W (427W) w/Canton oil pan ishiznitting steering rack (Read 5716 times) previous topic - next topic
Just wondering if anybody who's done a 351W swap has run into this issue and how they solved it. I thought the Canton was a stock pan with the "T" welded onto the rear sump area. I'm using the Chuck mounts that I bought years ago, finally they're being put into service :hick: Looks like I could shim it with maybe 1/8" thick washers?
You could do that, or maybe some offset steering rack bushings.
Quote from: Tbird232ci;462654
Car is already lowered, so I'm not too fond of lowering the rack. I read of someone putting rubber belting between the mount and k-frame to raise it up some, I need to see how much can be gained doing that. At least hood clearance doesn't appear to be an issue with greater than 1/2" there now.
Could you just space the engine mounts away from the frame to get some clearance? I don't see why it wouldn't work.
Is the 427 going to be NA or is the KB getting bolted to it?
Quote from: thunderjet302;462666
No KB, this engine should make 600 flywheel N/A.
Yeah, somebody recommended using this stuff to shim up the mount, though I could just weld on some sheet metal as well.
Today was really annoying - I hadn't been able to bolt up the driver's side mount - turns out I had to grind away some material in the middle of the mount to clear a boss on the block. I got that done, then the ed lower part ishiznitting the steering rack - geez!
X
I'll have to separate the mount cuz I'm not unbolting the top part again! More grinding tomorrow.
X
I'm so tired and there's more possible issues just waiting for me to discover them.
So I used the Maximum Motorsports rack bushings and lowered my rack due to the Canton road racing 7 quart pan hitting the rack on the 351W my Bird and my car is in the weeds.  You raise the motor and it might find the hood.
http://www.maximummotorsports.com/MM-Steering-Rack-Bushings-C86.aspx
I also have a bumpsteer kit on the car so....
Quote from: Aerocoupe;462682
Interesting. I'd definitely need a bumpsteer kit. Funny, at the link you posted, it highly recommends against using offset bushings on the rack.:hick:
It seems that if I stick ~1/4" PVC pieces under the mounts, it clears the rack and I still end up with 1/2" above the elbow.
Unfortunately, I'm still dealing with the inaccuracies of these mounts - drilling out holes, twisting this and that, lifting and dropping the engine, yanking it this way and that. My ribs are ridiculously sore from hanging over the fender. I've wasted 6 hours fighting with these ed mounts, knowing that there's a dozen more issues I have to deal with before I can start the engine. :mad: Can't imagine anything I'd rather be doing to mutilate my 55+ year old body. :punchballs:
X
Should have used a Fox Mustang K member and mounts at this point....
Quote from: thunderjet302;462687
What is the benefit to using a Fox Mustang K-member?
Ohhhhh DAMMMMMMNN this is basically my 5-year plan hahaha :burnout:
Quote from: Cougar5.0;462689
From what I've read there is more clearance with the Mustang style mounts between the pan and rack when using a 351W block.
Although using a non stock pan could throw that out the window. When I had my Mark VII (it used fox Mustang style mounts) the engine sat a bit higher off the K member than my Thunderbird.
Quote from: thunderjet302;462694
Maybe, though most of the advice I read on how to deal with the interference with the steering rack on a 351W swap was on the Corral. The comment was "hit or miss" as far as interference goes. I dunno. I think I'll be good once I shave the shims I made down a tad.
There's something else amiss. There are LOTS of Type 6 mounts out there in service.
Those lower U-brackets are the same dimensionally as the stock lower U-brackets. You have an older set of mounts (As they're zinc plated and not powdercoated), but those brackets could be the very EARLY style, which were a little shorter and only had one location for the main vertical through bolt.  (At least that's what I remember. The last iteration had a siamesed hole to accommodate the Fox (86-88) and MN-12(89-92)  differences.
If you have a set of your stock lower U-brackets, you can modify them. A 1/2" hole in between the two smaller bushing mount holes, and a welded-in reinforcement plate will suffice. That, or you can use a large OD washer under the head of the bolt from below.
I have extra of those large OD washers if you'd like some. You can use them as spacers under the bushings as well as a combo reinforcement plate/spacer, as mentioned above.
Quote from: Chuck W;462700
Thanks for the info. I'm guessing I jumped on these as soon as they were available, so early sounds right. There is only one hole for the vertical through bolt.
I got the driver's side on, which was the one being the real pain, I just need to somehow get the passenger side PVC piece (between the u-bracket and k-frame) the proper thickness. I wish I had run a drill through the k-frame holes like I did on the driver's side. I'm just having an issue getting the bolt to start in the nut - it's barely squeezing through the slightly misaligned pieces. Are the long bolts 3/8"-24? I've tapered the bolt to aide in getting it started, but I'm having a heck of a time getting the 3/8"-24 die to grab the original threads without getting hungry. I think I'll get it after work, just having the issue getting the far end to start, though the front allows the bolt to slide right in easily.
NM, I see it's M10. I got it in, just had to take a little more off shim
