Topic: Back in a fox. 1988 Turbo Coupe. The life journal. (Read 120602 times) previous topic - next topic
Reply #60
So it's been too long since I've made an update. Unfortunately, it's because there hasn't been much to update.
I haven't done much with the car other than drive it. I did get into a "speed altercation" with my co-worker in a 2016 Ecoboost Mustang. I ended up walking him by about 2 cars at double the posted speed limit in Mexico. I honestly think there is something wrong with his car, but it's been fun having the entire shop in his ass over it.
This is the busiest time of the year at work and with the social life, so cars have taken a back seat. My garage is full of Christmas  so not much has gone on there. We are hosting a big Christmas dinner at my house in which I'm not pleased about, and we just hosted a party this past weekend where I learned that shot glasses fit in the garbage disposal.
I have managed to score an okay deal on some Maximum Motorsports front control arms. It would have been a screaming deal if the balljoints were in good shape. The boots are missing, and the grease is contaminated. I'm hoping I can drill and tap for a grease fitting and push all the garbage out. They also need new bushings, which I'll probably replace with delrin.
We just recently got a few inches of snow here in Maryland. While it's unfortunate that I couldn't get the car in the garage for the winter, it did make for a nice photo op.
I'm also bad for randomly buying toys that take away from my car funds. Prime example:
It's a 1/5 scale Redcat Dunerunner. Has a 30cc gasoline engine on it. I bought it used with a few problems I didn't know about. First run and I broke a left front shock, and found that the front driveshafts were missing. I have those coming, in addition to a bunch of hardware that was vibrated loose. It'll do about 40mph, which isn't all that fast, but it will eat up a lot of real estate really fast with how big it is.
Reply #61
Snow is just frozen water. Letting it outside isn't the best but, as long as you don't drive it with salt on the roads you're not doing any permanent damage.
Are you going coil over in front? You need to in order to use the MM front control arms: http://www.maximummotorsports.com/MM-Front-Control-Arms-1979-93-Mustang-P389.aspx
Reply #62
I'm not going coil over yet. I found the arms in a Facebook groups for 145 shipped. The guy thought they were a different companies product. I just stuffed them in the stash for the time being. I have SN95 springs and some inexpensive shocks and struts I'll be using for a little while.
Reply #63
For  $145 Why not. Stash them until they are needed.
Reply #64
Oooooooooh 1/5 scale GAS BUGGY.
If I ever get another R/C it'll be one of those. Had a Traxxas nitro one, was fun but I always longed for that simplicity. And cheaper fuel LOL
Reply #65
Quote from: ZondaC12;464212
Don't do it. It's the worst hobby ever. Parts aren't expensive, until you decide to build something. Those 5-12 dollar parts add up fast!
Honestly, electric is the way to go now. With brushless motors and LiPo batteries, they're faster and easier than nitro. This gas buggy does maybe 37-38mph, which isn't that fast. I have a 1/8 electric buggy out of the box that is just as fast, and with gearing and programming the ESC, I can get about 50mph out of it.
Reply #66
Electric is definitely the way to go. I can get almost double the perfomance out of a Lipo that I can out of a gas engine on my model airplanes.
Reply #67
Quote from: Haystack;464330
And no mess, no tuning, no fumes, no glow plus, no spark plugs, no receiver batteries, no mixing fuel, no pistons and sleeves...
But, I do really enjoy this 2-stroke. It does have a neat wow-factor. I have a nitro car I need to rebuild, but I just haven't gotten around to it. Everything else I have is electric
Reply #68
It's getting to be that time of the year. Finally getting off of my lazy ass and getting a little bit of work going.
This past Saturday, I spent about an hour cleaning the garage. It pretty much got over run with stuff that't supposed to go in the shed, or never quite got a winter home. I didn't get it organized or anything, but I did free up enough room to work.
A gentlemen by the name of Heath has designed some motor mounts for the 86-88 Turbo 2.3 cars. He sent out a few prototype sets of mounts for a discounted rate for people to test. I was the last person to receive the mounts, yet I am the only one to get them installed so far.
The mounts do bear a strong resemblance to Chucks mounts, but they aren't remotely the same.
I started off trying to take a bunch of pictures to do a How-To type ordeal, but it's hard to stop what you're doing to take pictures.
But anyways, I had to jump start the car, so I had it running while I finished moving some stuff out of the garage. Drive it halfway in and put it on ramps. I laid under it, and looked at the drivers side mount and remembered that it wasn't very pleasant.
That's not too bad.
Those two aren't bad either.
That's the cheeky little  that's a pain in the ass.
Long story short, all of the bolts came out easily, other than that front bolt. I had to use an open end wrench, and when the bolt backed out, it would back against the isolator. In the mean time, my jack crept down and put pressure on the mount. I didn't realize that I didn't have the valve completely closed on the jack.
I had the jack under the bellhousing with some ss of wood bridging the pan and the bellhousing.
There's the new mount and the old mount.
I knew that  was broken.
New mount in.
So at this point, I stopped taking pictures. The installed pictures were actually after I had finished and was getting ready to take the car out.
The passenger mount was actually a bigger pain in the ass than I expected. Part of it is my fault. I tried to do the mounts one-at-a-time. With the drivers side mount installed, there is very little flex to get the engine jacked up. I had to unbolt the drivers side mount from the k-member to get the engine jacked up. Even then, I was wrestling the old mount trying to get it out. I then realized why I remembered installing Chucks mounts was so much easier 10 years ago...I ripped the A/C out of my cars! I actually had to prop the mount up at a wonky angle, and remove the two 10mm bolts to get the mount plate off of the isolator.
Installation was much easier. The mount almost fell into place. I did have to fight and play with angles to get the bolts to start, and there was very limited finger room for the front bolt. I discussed elongating the front hole a bit with Heath to maybe make it a little easier to install.
Passenger mount installed.
Once Heath gets all of the feedback, he is going to make some revisions and send new powdercoated brackets and hardware. When I do this job again, I am going to do things a little differently. First, I'm going to loosen all of the bolts. Then, get the jack set up and remove the crossmember bolts. At this point, I can jack the whole engine up, slide each mount out, and then set the engine back down.
So how does it drive? I wish I knew!
I cleaned up and went to test drive the car. Start it up, and it died after 2 seconds. I know it's low on gas, but I had it running even on the ramps. I fired it up again and it did the same thing. I tried to use the throttle to keep it running, but it dies as if the key is shut off. At this point, I fired it, revved it up and hopped it off of the ramps before it died. My two thoughts is that I may have broken or damaged the ground on the accessory bracket by the drivers side motor mount, or smacked the TFI and made it stupid. I had tach signal, so I feel that the TFI is at least "working". My girlfriend was going to help me just push the car back outside but she was finishing up dinner, so my curiosity got the best of me. The Trans Am barely fits in the garage, and the TC is 9ish inches longer. After I almost pushed it out of the door, I drug it back in.
The  things fits! I have about 4" from the front license plate to the wall, and about 8" behind it to the door.
I hooked up my battery charger/tender, and will get back to diagnosing the running issue another day.
Reply #69
Good to see you making some progress Shawn.
Reply #70
Looks like a few cuss words were probably uttered, lol.
I had to rebuild my jack, the cylinder kept bleeding off, and it would go down.
I'm surprised, I'd have thought that the TA would be a good bit longer than an Aero Bird.
I've gotta get some car stuff done too, one day off a week sucks though.
Good work man, hopefully you can fire it up soon and take it for a spin.
Reply #71
Codes man. Scan the codes ;).
Reply #72
Yup, codes.
My guess is a shiznitty parts store fuel pump. 4 out of 5 ive laid my hands on were bad out of the box
Reply #73
Quote from: thunderjet302;465078
I did that before making this post. The codes were completely irrelevant to the issue I was having.
I ended up spending about 10 minutes just looking around the engine bay. Started at the grounds that I know I disturbed. Traced them up to the battery. Nothing there. Went to the other side, started by looking at the engine mount, checking the work I did and then noticed that the intake tube popped off when I jacked the engine up. Problem solved.
I still haven't driven it. A bit too much weather and salt happened recently, so it's just sitting for now.
I did realize how little time I have until Carlisle, so I'm going to have to dump some money into the car and get some stuff in motion. I have a lot of little stuff to do, and a handful of bigger ticket items I'd like to get done. Either way, the car will be there, but it may or may not be uber stock.
Reply #74
Well at least you checked the codes :hick:.
Glad it was a simple fix for you.
