Topic: Made a walk around vid (Read 3155 times) previous topic - next topic
Did one for my Ranger a couple years ago and glad I did since its wrecked now. Going to do these for everything I build whether its my own or customer jobs.
https://www.youtube.com/watch?v=kJd1E6ZhLto
Brian R.
88 2.3t Ranger
Very nice car!!
+1. Very well done.
 S O L D
I really like how this one came together.  I'm trying to figure out wheels for mine, I'm digging the 17s.  I originally thought go 15s but you may have changed my mind.
Quote from: ZachReynolds;462370
My only issue is Id stay with a 8" width up front. A 9" wheel puts the rim barely outside the fender lip. With a 245/45-17 on a 9" rim it stretches the tire out just enough to clear. Not crazy about the look but it was my best solution
Brian R.
88 2.3t Ranger
Nice video and thunderbird
Beautiful car. Very nicely put together.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
