Topic: Proportioning Valve Thread sizes (Read 2127 times) previous topic - next topic
So im looking to replace my proportioning valve with little modification as possible. Does anyone know what size the fittings are for all the ports? Or does anyone have any experience with an aftermarket one that bolts right up?
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
Why the replacement?  Have you already swapped to rear discs or put bigger and better brakes on the front?
I think the prop valves on older Fords used standard threads whereas the later ones (90's and newer) switched over to metric threads. Not sure about that, or the exact sizes, but the Maximum Motorsports website might have some info you can use even though its geared towards the Mustang brake system. The Tbird's hard brake line routing goes under the engine on the K-member rather than along the firewall like the Mustangs did.
I believe the proportioning valve has gone bad (valve stuck) because brake fluid only comes out of the front bleeders. Plus, an aftermarket adjustable one would allow me to tailor my braking distribution since I have skinnies up front and meats in the back. I would like to mail order the fittings and lines along with the valve, so im hoping I could get the exact sizes of threads.
Thanks for that info, but not really needed (excuse my rudeness, its early and coffee aint done)
And, I actually just replaced the master cylinder a few days ago. I replaced it because I thought it was the reason for having no brakes. Turns out, no.
