Topic: 88 5.0 dash harness. (Read 1552 times) previous topic - next topic
I've been chasing an issue with my guages not working, narrowed it down to the dash harness.  I need one from a car with automatic climate control. Thanks in advance.
I have one. I will ship it to you for $90. This is the entire fuse panel side harness that runs from the engine bay, all the way back to the trunk and includes the dash wiring. The dash wiring doesn't separate from it. It's a pretty big harness. X
the car has been 5.0 swapped I forgot to add that, I had the gauges working before I swapped in the clutch pedal assembly and T5 but now they don't work. I probably should of posted this in the electrical section first but thought I'd try to locate the harness first.
