Topic: shorty headers for 5.0L **solved** (Read 1643 times) previous topic - next topic
I have better than GT40P heads from the D2OE casting with 1.94int & 1.60 exh.
Need some shorty headers from someone here if your willing to let go of a set.
your size outlet matters somewhat although a set i got from Turbocoupe50 with 3'' was easily adapted down so im pretty sure i can work with what spares you might have.
I do not want the stock mustang shorties, the runners are a bottle kneck on our ext ports.
Please if you will call me if you have this part, i am having trouble loggining in here consistently to check PM's.
 My home office number is 304 772 3411, i am scott cassity, located in Gap Mills Wv 24941.
thank you!  i saw those also, friend of mine siad the openings are nearly the same as the Stock OEM shorties.  I have no idea why either when the BBK's i got off tom were larger.
Theres some equal length bbk's for sale locally for $175. Look brand new, used for "mock up".
ended up buying these,, gotta do a review yet on them but i like so far.
SUM-G9072
Headers, Shorty, Stainless Steel, Polished, Ford, 5.0L, Pair
(Mfr. #: SUM-G9072)
