Topic: opininons (Read 3615 times) previous topic - next topic
opininons
i have a choice of buying a rear differntial from a98 mustang from a junkyard for 250 bucks
nowim not 100 percent sure that i can swap the axle from that rearens into mines without and problems but if you guys say its a direct swap then it is but if i buy it and the shiznit is all beat up inthe casing what thats my ass any advice i really want to convert to 5 lugs
Re: opininons
If you don't want a torn up part, buy it new or rebuilt, plain and simple.  Used parts are always a risk.  For more, translate the following.  It'll be the most research you've ever done.
01010011 01110100 01101111 01110000 00100000 01100001 01110011 01101011 01101001 01101110 01100111 00100000 01110011 01110100 01110101 01110000 01101001 01100100 00100000 01110001 01110101 01100101 01110011 01110100 01101001 01101111 01101110 01110011 00100000 01100001 01101110 01100100 00100000 01100100 01101111 00100000 01110011 01101111 01101101 01100101 00100000 01101111 01100110 00100000 01111001 01101111 01110101 01110010 00100000 01101111 01110111 01101110 00100000 01110010 01100101 01110011 01100101 01100001 01110010 01100011 01101000 00100001
1987 Thunderbird 3.8. Sold :(
Re: opininons
Quote from: amooset
 :giggle:  :giggle:  :giggle:  :giggle:  :giggle:  :giggle:  :giggle:
 :rollin:  :rollin:  :rollin:  :rollin:  :rollin:  :rollin:
Re: opininons
well, at least y'all figgered out WTF he said...
I'm gonna look for a Stupid-to-English translation book, so I can see, too!
 :disappoin  :flame:  :yuck:  :bs:  :locked:
Re: opininons
My opinion?
MORE COWBELL!
Re: opininons
Quote from: amooset
 :flame:    :giggle:  :giggle:  :giggle:
Re: opininons
Buy a Mustang.
Re: opininons
Buy a Mustang.
He's already intent on ruining one car.  Don't encourage him to ruin two :hick:
Re: opininons
Quote from: Ifixyawata
Buy a Mustang.
NO!
Play it safe buy a chevy.
Re: opininons
Not just any Chevy.. a Chevette!
Re: opininons
hows bout a berlenetti?
Re: opininons
I got it a Yugo!
He woldn't have to worry about what would fit they never changed a thing in the entire how ever many year run.
Re: opininons
Christ, you make my head hurt.  Do you have to repeatedly ask which side of the toilet paper you need to use when you wipe your ass?
Well, if you had read any of the other posts on this subject and done some reading you would realize that your 87 or 88 TBird has the 7.5 housing.  Also, you would have read that the 87-88's 7.5 housing is wider than the early (83-85) 7.5 housing (which is the same as a Mustang), which is the same as the 8.8's.  The axles do not interchange between the wide and narrow housings.
This is the last time this is going to be said ....... if you want to use a 8.8 housing AND keep the 4-lug then you need to use the axles and brake backing plates from an 83-85 Tbird/Cougar in the 8.8 housing  to get the bearing surfaces to mate up and keep the track width.
Re: opininons
hey don't knock chevettes, my folks had one for 13 years.. had 250,000 on it, the front end finially just fell off it, only thing ever wrong was a valve that went bad.
