Topic: Blow thru carb turbo (Read 1426 times) previous topic - next topic
Been throwing the idea around of converting to carb and doing a blow thru turbo setup on it. This may be the wrong forum to ask but was wondering if anybody here has had some experience with anything like this. I know we have cast pistons but i think i will be okay if i keep it under 10psi. Just got done with the HO swap on my 87 cougar. Will a 255lph efi pump work right if i plumb a larger return and add a bypass regulator with boost reference. Was going to run a msd btm for ignition.  I was looking at those on3 turbo kits or building my own kit.
Quote from: Twister2gt;460680
I blow thru a carb on my 509 BBC boat with an M3SC ProCharger. It can work well if you purchase a carb from a company experienced in building blow thru carbs. I use a Holley 1000 CFM DP built for blow thru operation by CSU in CA. They can provide a carb specifically designed for your application and have lots of experience with blow thru set ups. The engine will have to be tuned in much the way as a multiport injected engine and will have to have similar fuel and ignition system upgrades as well.
Cast pistons are a risky proposition. Modern Hypereutectic cast pistons are actually pretty strong and provide excellent noise and oil control  but can shatter if subjected to moderate detonation. You can detonate a naturally aspirated engine with a bad fuel, too much timing or just a bad tune up. Adding a power adder just increases the risk. I personally would build a forged piston short block for any blown application. I don't care how low the boost is. Consider MLS head gaskets a must have as well.
1986 Thunderbird Elan 5.0 EFI AOD, 3.73:1 SN95 rear, 17" Mustang Bullitts w/Firestone WO Indy 500's. Future plan: 349 stroker, C9 block, forged dish pistons, Scat 9000 crank, 4340 I beam rods, ARP head/main studs, ported explorer intake, 1.72 CC RR, Vortech V2 supercharger, Mr. Freeze Meth Inj, intercooler, TFS 190 11R CNC heads (66CC), BBK shorties with 2.5" duals, 4R70W Transmission, Taurus fan.
