Topic: The rusty old game changer. (Read 5803 times) previous topic - next topic
so, im finally getting to getting this car in short pieces.  the body and front stub are absolute rust.  i was scared to get under the car to undo the engine mounts.  but the 302 has been extracted.  the engine doesnt spin, so im going to rob it of all the accessories, and i do believe its a roller cam engine, so im going to nab the dogbones and spider out for another 302 build.
The engine harness was an all you can eat buffet for the mice.  im not sure if i should attempt to keep it or not.
are the swaybars any better ( bigger) than my 87 Tbird with a 3.8?  are they worth torching the brackets and setting them off to the side?  or am i better off looking for different swaybars?
I also still need to gut the interior, grab a few other odds  and ends off the car, but i hope to have this thing on the trailer by Sunday night.
If the face hubcaps aren't in too bad of shape, i wouldn't mind one. My 83 someone took a tire iron to it trying to get them off and bent up the metal where the plastic cap pops out and the allen bolt sits inside.
The swap bars might be alittle bit bigger with the v-8. Some of the earlier 3.8's didnt even have swap bars. Car should also have a double hump cross member and the tail pipe mounts for dual exhaust.
i'll inspect em and set one aside for you if they are decent.
will the AC parts from my 3.8 car be fine when i put a 302 in, or do i need to grab some special parts from this one?
3.8 and 5.0 accessory brackets are different I believe.  I would either use a TC front sway bar and a Fox Mustang V8 car rear sway bar or order ADDCO front and rear sway bars. Sway bars are like springs though and they do wear out due to cyclical fatigue.
Those side view mirrors in good shape?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Quote from: Moonmount;462006
you already asked, and once i get em off, i will nab pics for you. :)
