Topic: Engine kit (Read 2494 times) previous topic - next topic
Engine kit
https://lmr.com/item/TFS-K514350370B/1987-93-Mustang-50L-Trick-Flow-Street-Burner-Top-End-Kit-Blk
https://www.stangnet.com/mustang-forums/threads/stock-302-block-trick-flow-top-end-kit-whats-your-guys-opinion.781650/
https://www.youtube.com/watch?v=Z9mWj_JFSvo
mustang guys really like it and trickflow is top notch id say go for it
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Engine kit
Right now I have a 70mm MAF, A9L computer, BBK shortie headers, 19lb injectors, 96 2.5" Cobra cats and "H" pipe, dual Flowmasters. I will be going to 24lb injectors, 70mm throttle body and EGR with that kit. Does this sound feasible? Appreciate your input.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Engine kit
Below is the tuner I was looking at.
http://www.ebay.com/itm/SCT-Performance-Custom-Tuned-Chip-for-Your-86-93-Ford-M
Engine kit
The 96 Cobra was a modular motor car so the exhaust is a bit different than a Windsor motor car.
Engine kit
I bought that kit.  Best thing I ever did was pull out the camshaft and go with a custom Ed Curtis cam.
On top of the other supporting parts mentioned, you'll be wanting a higher stall converter if you're running an automatic transmission.
Engine kit
What was wrong with the TF cam?
I've got a 94 Mustang 5 speed in the car.
Any recommendations on lifters and push rods?
