Topic: Diff oil d8dz-19c547-a (Read 1868 times) previous topic - next topic
Can any one confirm the oil grade I have 80-90w gl4 as a cross reference also what is that bloody big chunk of metal that hangs under the diff was a real pain to get the filler plug out.3.8 cougar non slip diff.
I think most people run 75-140 in their traclok 8.8's, it might be less critical on an open diff 7.5 tho (which I assume you have). As far as the anchor attached to it, its suppose to dampen vibrations, I've always removed mine and felt no difference, but I'm sure Ford had their reasons.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
75W-90 will work too, that's what I run.
Ok thanks for the replies will be using 80-90 as have lots of the stuff and going to remove the lump of metal after a run to see if it actually does anything except make the car weigh more.
Supposedly it's to dampen vibration.  I've heard they were ratio/rear specific as far as weight, although I cannot confirm or deny it.  I do wonder if they stop gear whine....
Took mine out eons ago.....
