Topic: Stripping a 86 5.0 cougar. (Read 3487 times) previous topic - next topic
I am finally getting around to stripping the car. It's an 86 302 with about 350k miles on it. Body is pretty rough and so is some of the interior. Car drove fine before a broken oil pan, but the front end is all worn out and the shocks and and struts are junk. If you need any electrical or sensors most if not all is there and worked. Both motor mounts are shot with broken brackets.
Let me know if it can be any use to anyone. Located in grantsville utah, 84029.
I think Jerry will want the O2 sensor harness.
Also, how's the charging system wiring up by the dash on the driver side?  You know, the bundle with all the fusible links?
I'm looking for a radio/temperature control bezel.
1986 Mercury Cougar XR-7 Turbo-charged 5-speed.
Owned 22 years.
Quote from: V8Demon;460023
I believe all the fuseable links are good. Old and dirty, but should be good. It was a lower option gs model, so it might not have every one, but I can pull it all out and take a pic in the next day or two. I did a 3g upgrade but I left the stock charging cable taped up. The connector was melted as were the wires up till they splice from two down to one wire.
Quote from: CougarGal;460029
It was the standard cable operated heater/a.c. panel. I believe it has the rear window defrost as well.
Quote from: Haystack;460056
So is mine.  I need the bezel/surround that runs from the dash cap down to the console.  I've found several out of T-birds but they have a different pattern on them than the Cougars did :(
Owned 22 years.
Quote from: Haystack;460055
That's what always happens.  Any time a fox chassis car goes up in flames, the problem is almost always that connector.  I hard wired mine and took the connector out.
Dos this car have the full console or the consolette?
 S O L D
Is the driver side door window an unbroken non vent window? I just broke the one on my 86 tc and need one baaaaad!
How much for the following:
Tab/tad sensors and mounts.
Headlamp switch
Power door lock switches - both sides.
Sorry guys I've been busy at work. Haven't had a day off since I posted this. I have a few pm's and stuff. I'll get back to you in a few days when I can mess with stuff.
Quote from: CougarGal;460063
Just so you are aware, this GS will have the simulated wood "Woodtone" pattern on it, not the "Black / Gray grid" pattern that your XR-7 has.
One of 1,246 built
Haystack, I'm interested the C pillar Cougar emblems if they are in decent shape.
Quote from: BCA;460482
Thanks!!  I didn't catch that it was a GS :(
How are the door lock actuators?
Owned 22 years.
