Topic: How to do a AC delete on a 5.0 (Read 5385 times) previous topic - next topic
I want to take the whole a.c. out of my 88 tbird. Is there a bracket a can buy to do this and not have to remove/ relocate my power steering?
Not really. You could just undo the lines and leave it in place if a relocation bracket is too much work.
You can try to find the PS bracket they used for dealer installed AC. Not sure how the belt clearance and wrap would end up so you may want to search some of the mustang forums.
John
Cougar and mustang brackets are a bit different. Would require a mustang bracket along with the new bracket. Won't find a dealer a.c. add on either, all 302 motors had ac.
It won't work unless you use all the bracketry from the Mustang 5.0, as all of the Bird/Cougar 5.0 sits differently, etc. (closer to the block and heads)..
I went through the same thing back in 2008. I never was able to find one, so I took all the lines and condensor out, I plugged/caps the fittings on the ac compressor and ran it.
Quote from: 85CougarCobra;459920
You can do something like this:
https://lmr.com/item/LRS-8511A/mustang-50-ac-eliminator-kit-85-93?year=1993&gclid=CMvq5bOV7dICFRGBswodBJQOHg
Not sure if that is what you are looking for or not as it does move the power steering "up" a little.
You'll need the Mustang power steering bracket to go with that as well.  Cougarbird ones are different. That won't bolt to the Cougarbird one.  Ask me how I know.
Quote from: V8Demon;460675
Ta Da! https://lmr.com/item/LRS-9998926/50resto-mustang-power-steering-bracket-79-93-5-0
On a side note if you're doing a 5.0 engine swap into a 3.8 or 2.3T car they have all the Mustang brackets available, which will work in a Thunderbird/Cougar  https://lmr.com/item/LRS-10313-K/mustang-engine-accessory-bracket-kit-hardware-7993
I'm subscribing to this for when i'm lookingot get the engine back in next fall.
I have an oem original AC Delete bracket with pully I'll never use.
304 772 3411
