Topic: O2 harness needed (Read 3399 times) previous topic - next topic
O2 harness needed
Today I'm looking for an O2 harness for an 87 5.0 that connects to the main ecu harness
O2 harness needed
Is 88 different? I *may* have a spare in my parts pile.
O2 harness needed
Quote from: thunderjet302;459654
I'll look it up tonight
O2 harness needed
If it matches this connector, It will work...
Wiring is the same for 87-88
X
O2 harness needed
Cool. I'll check later.
O2 harness needed
Quote from: thunderjet302;459659
thanks
O2 harness needed
still looking for an O2 harness... looks like 86-88 would be the the winner if it has the connector from the above post
O2 harness needed
You can re-pin any harness to match your application so I wouldn't limit your search to the SD versions.
Good luck
John
O2 harness needed
Quote from: Skunk;459713
Good luck
John
Ive been looking... I like to work with the forum first when I can
O2 harness needed
Quote from: daminc;459660
thanks
Forgot to update. Apparently I sold the spare harness I had. I am unable to locate it in the garage.
