Topic: Turbo hood scoop water block (Read 2561 times) previous topic - next topic
Hi,
On the turbo Coupe model hoods, what does ford have in place to stop the water from rain or whatever from entering through the scoop holes. A picture would be great, so I could duplicate it onto my hood.
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
They don't have anything to block water. When I used the TC hood on my V-8 car, I used to fab my own baffles that blocked the scoops. Bolt in style so no mods had to be done, but the ducting was removed from the bottom of the hood in order to work on a V-8 car.
There's a large plastic duct and boot that directed airflow(and water if raining) into the intercooler...
As mentioned, the scoops go to the intercooler, not the intake so blocking the water is not necessary.
Wow, Kind of think that allowing water to go to the intercooler wouldn't be so great since water could cause so many issues with rust and deterioration, Etc. But, in the picture above I can see the duct work is quite large and I imagine has drainage of some sort to remove moisture.
I installed a pair, but I moved them towards the center of the car more, instead of being closer to the front. I guess I will fab something to block them off in the winter time and open them up in the spring and summer for ventilation. Thanks Guys.
X
1988 Thunderbird V6
Interesting change
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
Never blocked mine.  Always made sure to have the distributor boot Installed.  It's never been an issue....
It's not like the engine bay is waterproof.
