Topic: Lowering springs for my 88 Tc (Read 4416 times) previous topic - next topic
Can I use fox mustang lowering springs for my 88 TC.
So, we do have a working search function, and this topic has been gone over and over, and then over some more.
Take a few minutes and do some reading.
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Geee thanks for your input..I research alot but it was just a question a simple yes or no would have worked. Thanks alot
Last time I checked this forum was to help ppl. I k ow it's a on going topic..I also know I'm not the only person that's wants to lower their car..So I was at work and when I had time I was looking at springs for my car.. Yes I should have researched on this forum but I figured I would get a yes or no answer..It takes less time to type in yes or no than it does what was typed in..thanks
It takes the same amount of time for you to search as it does to complain about me suggesting that you search for a well-discussed topic.
It's not a "yes" or "no" answer to that question, and it's been asked by lots of people over the past couple decades.
I'm not going to feel bad about suggesting that a member who's been on the board since '13 do a little searching.
Well I not complaining but if that's what u had to say then u shouldn't have even responded. It's just a question..Sorry I wasted your time
But thanks I'll go through the forums and research
Do a google search. Put in the key words you want, then pute :site foxtbirdcougarforums.com . The forum search fuction kinda sucks.
Thanks haystack..I was trying to find what I was looking for but Im not finding
Anything that I'm needing..Some ppl think it's so ez..
For your TC, you want to stay away from Fox springs on the rear unless you have modified your lower control arms. IIRC, the springs are too short and the load rating too light--you'll drag and bottom out.  You may try SN95 springs like the from the 1994-1998 Mustang GT or New Edge springs instead since these have similar load ratings.  Make small cuts as needed to lower.  I was planning on switching to 99 GT springs, but haven't gotten to them yet.
Daniel
OK..Did some reading..Sn95 springs are direct fit but I was reading and most of the swaps were n v8 tbirds.
My factory TC should I use v8 or v6 sn springs
Thanks Daniel..I posted my last post b4 I seen your post..My only concern right now is v8 or v6 Sn95 springs..My bird factory 4cyl..I don't know what the difference is between the v8 and the v6 springs
If I remember, the SN95 GT springs may be a little lower than stock TC and the 3.8 springs will drop an inch to 1 1/2".  If you do lower the car, don't forget to get caster/camber plates like MM sells.  Your front tires will thank you.
Thanks for advice..I'm just wanting to lower the front a little..It sits to high. I wish it say like my v8 bird did and I wouldn't worry about it. I probably b going with v6 springs. Thanks abunch
