Topic: 85 5.0 fuel pump specs (Read 2084 times) previous topic - next topic
Doing my EFI swap, and wondering if the 5.0 cfi pump will handle the EFI system?.. I do have a better pump, but dont want to drop the tank right now if I didnt have to to get it running.
If it's feeding a SO engine it *should* be ok.
Since SEFI only pulses one injector at a time, where the CFI pulses two, seems like it should be good.
It'll start, idle fine and assuming it's in good cond run OK...  You could start and idle the engine on a motorcycle pump...
Thanks, I'll give it a go with the pump thats in the car... I'll just need it to start and run at this point
