Topic: 88 5.0 Engine Harness, misc parts (Read 1048 times) previous topic - next topic
Just picked up a 87 roller that turned out to be an 88. Typical.
Anyway, I'm sure i can mod my 87 harness to fit, but it would probably be easier to get one from an 88. Anyone have an 88 5.0 engine harness extra?
I could use a automatic floor shifter console trim plate, 85-88. Screw holes are broken out on mine.
Also would be interested in a full set of blue door panels in reasonable to good shape.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
