Topic: 4R70W Transmission (Read 3634 times) previous topic - next topic
4R70W Transmission
How many people have upgraded their AOD to a AODE-4R70W? Experience?
1986 Thunderbird Elan 5.0 EFI AOD, 3.73:1 SN95 rear, 17" Mustang Bullitts w/Firestone WO Indy 500's. Future plan: 349 stroker, C9 block, forged dish pistons, Scat 9000 crank, 4340 I beam rods, ARP head/main studs, ported explorer intake, 1.72 CC RR, Vortech V2 supercharger, Mr. Freeze Meth Inj, intercooler, TFS 190 11R CNC heads (66CC), BBK shorties with 2.5" duals, 4R70W Transmission, Taurus fan.
4R70W Transmission
My AOD has a complete 5.4L Econoline 4r70w stack, but a mostly factory valve body.  Swapping an AOD-E or a 4R70W will require the addition of a standalone controller, as well as modification of the shift linkage (unless you have a sport w/floorshift).
4R70W Transmission
I'm aware of this.
A lot of guys run the Baumann, PA, Hughes and others make controllers.  I am more interested in what one has to do to modify their column shift, crossmember, exhaust or anything else.
4R70W Transmission
Ive been running one with baumann for 30k miles. Works awesome.
Tried to get column shift to work with custom cables. Gave up and installed floor shifter. If you have to have column shift, I was gonna try to retrofit an explorer column shift system next. Floor shift is way easier though.
The factory crossmember works slid all the way back. But isnt perfect. I switched to a stifflers crossmember, looks much nicer and fits perfectly.
My exhaust fits fine. Ford shorty headers and summit or jegs h-pipe for auto fox.
My trans is a stock from a 2002 3.8 stang, with a b&m holeshot 2400-stall converter.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
4R70W Transmission
Quote from: a77cj7;459274
Chris
Chris,
What is the major issue with the column shift? Routing, obstructions etc??
4R70W Transmission
Aod uses the shift lever facing downward for floor shift and up for column shift.
4r uses lever facing down only, range sensor is above it.
4r column shifts are cable based. Aod are linkage.
So basically 4r lever is in wrong position and shift pattern is reversed for our column shift. You might be able to weld or bolt a lever extension on to make it work, i didnt want to mod trans.
My plan was to retrofit an explorer column shift, since it works perfectly with 4r. However, seemed like a ridiculous project, so i just swapped in a floor shift from 96 mustang. Doesnt look right in console, may switch to an actual thunderbird floor shift or see if i can get bezel to work on mustang shifter.
Chris
87 Thunderbird 5.0
TC 3.73 L/S rear
4R70W Transmission
When I installed the AODE in my '93 Grand Marquis(that I think was actually for a '93 MK VIII 4R70W), I had to swap the lever from the original AODE before the linkage would hook up... Problem is I can't remember exact difference... Other differences were smaller converter so I had to get a different flexplate, and the tail housing used a larger yoke so I swapped one on from the orig trans... That was new Years day '08, AFAIK that trans is still going...
4R70W Transmission
Google search yeilded this:
https://www.7173mustangs.com/thread-how-to-4r70w-shift-linkage--16146
87 Thunderbird 5.0
TC 3.73 L/S rear
4R70W Transmission
Quote from: a77cj7;459418
Chris
Its good to know what to expect ahead of time vs. an, Oh Sh@#$t .
