Topic: Carbon Fiber Hood (Read 3172 times) previous topic - next topic
Carbon Fiber Hood
I would love to have a carbon fiber hood for my 86 Bird. Every time I lift the hood, it feels as if there is a cinder block sitting atop of it. I know of several glass hood manufacturers, but has anyone ever made a CF hood for our cars? Back in the day, I remember all kinds of body kits and such that have since been discontinued.
1986 Thunderbird Elan 5.0 EFI AOD, 3.73:1 SN95 rear, 17" Mustang Bullitts w/Firestone WO Indy 500's. Future plan: 349 stroker, C9 block, forged dish pistons, Scat 9000 crank, 4340 I beam rods, ARP head/main studs, ported explorer intake, 1.72 CC RR, Vortech V2 supercharger, Mr. Freeze Meth Inj, intercooler, TFS 190 11R CNC heads (66CC), BBK shorties with 2.5" duals, 4R70W Transmission, Taurus fan.
Carbon Fiber Hood
http://www.hairyglass.com/thunderbird.html
Id try giving this guy a call. you can also consider making your own, theres videos on youtube! I think most guys make a fiberglass mold of the top and bottom of the hood, a "negative" if you will. Then you lay carbon fiber in the molds, pull the epoxy through. Allow to cure, then you have a "positive" of the top and bottom. Epoxy those together and done. That's it in a nutshell :)
-Kyle
Carbon Fiber Hood
You could also change out the hood hinges with the later ones that have the springs. Makes lifting easier, and you don't need a prop rod anymore.
CoogarXR : 1985 Cougar XR-7
Carbon Fiber Hood
Quote from: kylesburrell;459023
-Kyle
As a matter of fact, I watched those videos. A very time consuming process.
Carbon Fiber Hood
Yeah it is! And theres quite a bit of investment with that process. If your sole purpose is to shed weight, you can also consider cutting away the "structure" from the underside of the hood. Leaving you with just the "skin" of the hood. But dont be surprised if its more flimsy. Then run hood pins instead of the hood latch. Just some ideas!
-Kyle
Carbon Fiber Hood
The big issue is the tooling. There are a number of vendors that offer fiberglass hoods that have the tooling. Would be nice if they could lay one up using CF vs. glass mat.
Carbon Fiber Hood
I never did get the fascination with the search for lighter hoods for these cars. A lot of fiberglass hoods, including the one on my '86, are actually heavier than stock. The factory hoods just weren't that heavy to begin with, folks. Weight savings with fiberglass might be 10 lbs. Mine is for show and clearance, not for saving weight. So...unless you're a hardcore racer and shedding every pound possible, you may be better off stock...just my $.02.
Carbon Fiber Hood
Come on, $500 plus prep work and paint to save 10 pounds? Where do I sign.
Id rather buy another car then a hood I wouldnt want anyone to lean on so it doesnt break.
Carbon Fiber Hood
Not sure if any of you guys know Ethan in Ohio that autocrosses a bad ass blue/black TC.  I watched him make a CF hood for his car and it took a long time to get it perfect and he told me he had over $1000 in materials just to make one hood.
It looks totally killer now but when I inquired making another he said not a chance.
Brian R.
88 2.3t Ranger
Carbon Fiber Hood
Quote from: Haystack;459042
Might be easier/cheaper to loose 10lbs around my belly lol
Carbon Fiber Hood
Im gonna weigh the weight difference between the stock prop rod and hinges vs the spring 87-88 hinges. Then im gonna weigh power vs manual windows and seat tracks, just to see what the difference is.
Carbon Fiber Hood
There's definitely some weight to be saved in the power seat tracks ...
Carbon Fiber Hood
I'm just saying, if the only beef is how heavy the hood is to lift, swap in the spring hinges and be done. Makes lifting the hood a breeze.
Carbon Fiber Hood
I talked to Ethan today to see if he would consider making another one for me. He politely declined. Said he doesn't have the spare time and wouldn't touch another one for less than $1500. Said to make another true double sided bolt on hood there is $450 in fabric and $330 in epoxy alone. plus all the hours of labor.
He told me if over this winter he decides to make CF fenders for his car he will consider doing a hood for me.
Brian R.
88 2.3t Ranger
