Topic: Axle bearings (Read 2512 times) previous topic - next topic
Axle bearings
Alright so I ordered timken fc66998 bearings as they said they're the correct part but they're definitely not way too large what's the correct bearing for the rear axle?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
Axle bearings
A little info on the rear end they are going into please.
If it's an 8.8 or 7.5 then a BCA 5707 is what you want.
Axle bearings
Where is the rear wheel bearing located on my 86 Cougar?  Is it behind the hub?
Axle bearings
Behind the axle.
You have to drain fluid and pull the c-clips in the diff before you can pull the axle. Then you need a tool to remove and press in the new one into the axle tube.
Axle bearings
Pretty decent video showing how to replace the rear axle bearing and seal.
https://www.youtube.com/watch?v=VXEqzMVRRso
Axle bearings
So I have a lot of rear end noise in my car, it's driving me nuts so I'm having the bearings replaced,  is there anything else that would make a lot of roaring noise other than tires?
Axle bearings
Let's start another thread to address any issues other than the axle bearings and seals.
Axle bearings
Lots of things can make road noise. Anything that moves.
