Topic: Jacking and supporting (Read 1995 times) previous topic - next topic
As I have no information on this other than using the factory jack can you confirm where to jack and place axle stands for front end work also the rear if I need to let the rear axle drop.
lift here thread in body and appearance section by me
http://www.foxtbirdcougarforums.com/showthread.php?31788-Lift-here-fool!!!!!!!!!!!!!!!!!&highlight=lift+here
for out rear,, look directly under the car just forward of the rear wheels.
there will be a flat pad area ,,, thats where you lift for the rear.
you would then add your jack stands in the same general area,, you will see once you stare at it
dont use the metal pointing down seam like most ID10Ts do.
