Topic: The saga continues (Read 2590 times) previous topic - next topic
The saga continues
Last night I was doing a 75 mile freeway cruise, out in the middle of no where, went to downshift for a hill and nothing happened. Milked it about 20 miles (straight freeway near the bonnevile salt flats, no exits and emergency stops only) popped the hood and foundy tv cable had fallen off. Ghetto rigged it with electrical tape and a tip tie, but damage was already done.
Pissed at the slipping trans, I just got it home and placed an order for the brass bushing. Today I had to drive the car for the morning shift to do school lunch at work. While I was pulling up to a light the engine shuts off. I look at the guages, the temp is pegged all the way in the red and steam starts pouring out of the hood. I pop the hood and the fan shroud is broken and the fan is no longer connected to the water pump. The fan clutch didnt fail, my couple week old water pump  came off the pump.
Now I get to do a water pump, 3g conversion and an electric fan/radiator on thanksgiving. Probably gonna start looking for a clutch pedal and just throw the t-5 in while im at it.
The saga continues
Holy !!! That sucks........big. Since we are celebrating Thanksgiving on Saturday, I'm going to go try to fix my brake line. I don't envy your situation. GOOD LUCK!!! keep updated.
The saga continues
Wow on the fan explosion :(
You sure the trans is shot? Literally they can survive that for a little bit as long as you keep constant speed and treat the pedal like it's made of glass. Fluid all dark and burnt?
Try adjusting the cable all the way out? If you tighten it all the way, the extra TV pressure might band-aid you for awhile if there's any friction material left in there.
The saga continues
Got the car home. Swapped in a new water pump, left the fan off. There is a bit of play in the clutch, so I left it off. Car started to overheat as I got home, a whole 10 miles away. One of the heater core hoses is ripped about half way through. Had to buy the $40 water pump because they didnt have anything else.
Fan I still in one peice with no cracks, fan shroud is gone, didnt even bother messing with the old water pump to see if it still turned or how it failed. Radiator has a bunch of marks all over it but no holes.
Gonna throw a new hose on tomorrow and we will see how driveable the trans is still.
The saga continues
I was wrong, replaced the heater hose and as soon as I put the cap on it sprung multiple leaks. I was ready to give up on the car, but ive changed my mind.
Im gonna troll junkyards for a clutch pedal, throw in a new radiator and fan clutch in it with the t-5. Only way ill get my money out of this car is if I can drive it.
The saga continues
Oh noes!  I feel your pain.  You wouldn't believe what I've been through with my XR-7 these past few months.  Hope you get yours all straightened out!
1986 Mercury Cougar XR-7 Turbo-charged 5-speed.
Owned 22 years.
