Topic: c4 or aod (Read 2190 times) previous topic - next topic
c4 or aod
looking for opinions on witch trans would be the best to use c4 with shift kit or aod with shift kit its goin in 87 tc with 351w thanks
c4 or aod
Does gas mileage matter? I did my sn95 t-5 swap for $400, start to finish in a weekend.
If gas mileage doesnt matter, buy whats cheaper. The aod and a c4 have the same gear ratios 1-3 and I doubt you will need od while trying to go all out.
c4 or aod
thanks for reply I have the c4 and aod just not sure what one to use and gas don't matter it's not dd
c4 or aod
Sell the C4 and sell the AOD and get a 4R70W out of a V6 Mustang.  Put an electric controller on it, set up the shift points, and forget it.  The AOD and C4 will require mods if the 351W has any balls at all or at least that is what I have seen with a couple of cars my buddies have had.  This is one of the controllers I have seen on some conversions as well as it seems to have a good rep on the forums:
http://www.usshift.com/usq4.shtml
If both of the trans you have are stock will you shift kit the one you keep and buy a converter for it?  Do they need work or can they be used as is?  Hate to see money poured down the throat of outdated gear.
c4 or aod
You can build an AOD to take a decent amount of power. It's just going to cost $$$ to do so. I have ~$2k in mine but it's far from stock and probably overkill for what I have in front of it...
c4 or aod
thank for the reply I did put a shift kit in the c4 the aod is still in parts car so still on the fence
