Topic: 88 Cougar XR7 5.0 (Read 1936 times) previous topic - next topic
88 Cougar XR7 5.0
You have one pic of cloth seats and the rest of the pics show leather. Which does it have?
CoogarXR : 1985 Cougar XR-7
88 Cougar XR7 5.0
Hi sorry, car was originally leather, but it was all cracked and dry, so cloth seats i took out of my 88 tbird, same color though.
88 Cougar XR7 5.0
Why does where the IAC should be have a block-off plate?
Also, what is that box along the frame rail where the stock air box used to reside?
88 Cougar XR7 5.0
Hi; with the headers and addition of the exhaust and the gt40 intake, it wont idle correctly it surges ive done all the checks and resets so i deleted iac and just set idle where it works good, that box is the alarm module.
88 Cougar XR7 5.0
I saw your post.  It SHOULD idle fine.  You haven't done enough to mess up the idle as far as the parts changed.  You have a vacuum leak.
88 Cougar XR7 5.0
Quote from: V8Demon;457500
Agreed, unless engine cannot produce vacuum of approx 17-18" it should be able to idle just fine... Hi-perf cam, late ign timing or leaks are the usual cause of low vacuum...
88 Cougar XR7 5.0
It was pcv valve it had a crack in plastic, put back on iac and did resets, no surging now.
88 Cougar XR7 5.0
LOWERED PRICE, plus giving extra parts.:D
