Topic: Motor mounts (Read 1482 times) previous topic - next topic
Motor mounts
What brand motor mounts do you all have on your Cougar?  Does Ford make anything that will fit the 86 or is that a stupid question?  So should I buy Anchor brand or SCP  solid or hydraulic and if there is a old post already about this can someone direct me to it, please.
Motor mounts
Which motor are you dealing with, 5.0 or 3.8?  If it is the 5.0 then the only other mount other than the part store offerings are Chuck's but I don't think he is making them anymore due to time constraints.  You might check the classifieds to see if anyone has a set for sale.
Motor mounts
Quote from: Aerocoupe;457136
3.8L V-6 engine Cougar, anybody bought any other than on here?
Motor mounts
Chuck designed his own mounts due to the factory 5.0 mounts being under designed and failing especially if you wanted to make any more torque than what the factory motor put out.  With the 3.8L I don't recall much commenting on motor mount failures so I would just run with the parts house stuff and call it a day.  Hopefully some of the other folks here with 3.8L cars will chime in as I have not owned a V-6 car.
