Topic: WANTED: Automatic floor shifter control rod (Read 1526 times) previous topic - next topic
If anyone is parting out an '88  automatic tbird or cougar, i need the white plastic shift control rod that goes inside the shifter. Ive bought a few on ebay but they are always the wrong length or fit. Has to be from a tbird or cougar... Mine is broken so i cannot use the shift  at the moment and it looks like sh*t.
Thanks! :bowdown:
X
X
How does the handle come apart? I saw two xr7's at my last junkyard run with floor shifters.
Push in the button, then twist and pull like crazy.
If they are 5.0 XR-7 cars, buy the shifters, shift cables (shift cables for the 5.0 cars with a floor shifter are super rare), and shift cable brackets. If not, just pull the handle, remove the plastic pieces, good to go. Grab all of them. Others will need them.
Yes yes i nee that plastic rod, or the entire shifter if necessary. The  was tough to get off but it comes off eventually
I have a COMPLETE floor shifter setup, cable, brackets, console trim, bought it from vinnie to do an aod swap from my t5, never happened. Would take $100 plus ups, paid more when I bought it.
Buy it Gary, all of it. Then hang on to the parts you don't need at the moment. You'll be glad you did. If you don't, I may buy it back.
up for grabs...
I'm getting a floor shifter and cable soon.
Will be available then.
Nice 88 Cougar turn signal markers as well (curved lights next to the headlights)
