Topic: Looking for a working Power Antennae for an 87 or 88 TC. (Read 1383 times) previous topic - next topic
Hey all, I am looking for a working power antennae unit specifically for an 87 TC, but I am thinking that this unit was not exclusive to just the Thunderbird/Cougar of those years.  I just don't know what years or what makes will cross reference with mine.    I haven't had the time yet to determine if it is just the tooth cable and mast or if the entire unit needs to be replaced.  I just can't get time from work long enough to devote time to the project.    Would really like to have the parts on hand when I do tear it apart so I can put it back together at the same time.  I have found several on Ebay that say "will fit Thunderbird" but none that are specific.  Found several for the LTD/Taurus, and many for the 89 and newer cars.
Thanks
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
I am getting ready to pull the one out of my 83. I was told it worked when I got the car but havent powered it up yet to test. I do not plan to use the radio so its being pulled to save more weight.
If you can verify its the same unit used in a 87 I can verify mine still works.
Brian R.
88 2.3t Ranger
10-80,  Have you checked the CoolCats site? At 1 time they had a chart of parts that crossed over from year to year. Not sure if it would be listed but worth a shot or Eric may know the answer. Good luck on the search.
 S O L D
I have one. It was on a parts car and I ran it up and down a few times to make sure that it worked. I will ship it to you for $40.
PM Sent
