Topic: Electrical Issue on my 1983 Bird (Read 2033 times) previous topic - next topic
Changed the battery and either as a result or by coincidence the headlight switch is working but only main headlights.  The 15amp fuse keeps blowing as soon as you place it in the fuse holder.  Any thoughts?  My gut feeling tells me its not the headlight switch, but i am open to all thoughts.  The car is a 77K mile very original and well maintained survivor.  None of the wiring is cut or hacked anywhere in this car.
This is the fuse thats tripping.
4   15A   Lt. Blue   Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay
Check the condition of the brake light switch, under the dash at the brake pedal. Most of mine have been melted on my cars.
If you have autolamp feature, you will have a small connector along with the big connector on the headlight switch. Unplugging the small connector will take the autolamp stuff out of the picture.
Otherwise the with the headlight switch off, the fuse 4 circuit ends at the headlight switch.
That's a weird one. Seem like a coincidence but I think I'd check the headlight switch first.
tbirdregistry.com
26480
27373
